Envoy 8x not returning data. **solved**
BrentonSpear
Post by BrentonSpear »
I have a Davis vantage pro 2 weather station with receiver display.
I have the following in place:
TL-MR3040 -> Unpowered USB 2.0 hub -> envoy 8x -> ISS.
This was working on v3.9 for a number of years now.
Today I updated the TL-MR3040 to v5.2 firmware. Now I am trying to setup the meteo bridge again.
I have added the envoy 8x in and selected one of the "Device" options. Not sure what the difference is between the two:
Screen Shot 2022-01-10 at 4.01.22 pm.png (232.86 KiB) Viewed 1307 times
I have these settings in place:
Screen Shot 2022-01-10 at 4.09.45 pm.png (253.27 KiB) Viewed 1307 times
When I look at the Mapping section I don't have any options:
Screen Shot 2022-01-10 at 4.10.30 pm.png (101.68 KiB) Viewed 1307 times
So with these settings, I don't see any live data coming from the Envoy 8x or the vantage transmitter:
Screen Shot 2022-01-10 at 4.12.08 pm.png (67.33 KiB) Viewed 1307 times
What am I doing wrong here?
iu1jvo
Re: Envoy 8x not returning data
Post by iu1jvo »
I'm experiencing similar problem, but different hardware.
Meteobridge -> Davis Emulator (by anemos)
Without USB hub.
To resolve I need to connect and then disconnect the Davis Emulaor USB Stick.
Then save again the configuration to restart the logger.
BrentonSpear wrote: Mon Jan 10, 2022 8:13 am Hi,
Are you sure you have one of the very few "Envoy 8x"? I think you have a regular Envoy and then you have to select "Vantage" as station type.
BrentonSpear
I changed it to Vantage and it seems to be working now.
My home setup has the envoy 8x and I thought our holiday home setup I was referring to in the post also had the envoy 8x but maybe it doesn’t :)
Thanks for the response.
Brenton
