Weather34 Aurora MKII Version 2022
Re: Weather34 Aurora MKII Version 2022
Does anyone have an explanation why the overlay window for the 5 day text forecast under ../forecastcharts/chartforecast.php is not displayed completely on top. There are some elements shining through, see screenshot.
Also, I can click the button several times and it opens a new window each time, normally the next click should close the window again.
Have you tried other sites?
I don't get that error..at least I don't believe so.
yes, also on your Site. It depends on how big the browser window is.
https://bdepoel.com/console/forecastcha ... recast.php
via simple update (I can fix that one has it doesn't require meteobridge data) https://weather34.comToTo wrote: Mon Mar 07, 2022 1:29 pm yes, also on your Site. It depends on how big the browser window is.
Change Log March 2022
* (March 8th) * Forecast overlay Icons ref Toto (Forum)
* (Feb 15th) * Critical setup screen change for PHP 8.1.2
* (Feb 15th) * PHP 8.1.2 requires the simple update file
Hi Brian
Thanks for your help and the fix
Thanks Brian, it didn't bother me before but you never know, on another device or screen. So it's good that ToTo was saw it.
Have fun!
Greetings,
Bart
Have fun!
Greetings,
Bart
- jmontamat
Good morning.
It does not work
https://www.seismicportal.eu/fdsnws/eve ... p;minmag=2
return:
Error 400: Unknown query parameter: amp
Request:
/fdsnws/event/1/query?limit=10&lat=41.425475&lon=2.149305&maxradius=10&format=json&minmag=2
RequestSubmitted:
2022-03-13T07:55:16.89129Z
Service version:
fdsnws-event: v1.1.0
Yesterday it worked.
It does not work
return:
Request:
RequestSubmitted:
Service version:
lorenz1982
- Expert Boarder
When 0°C is forecast, the message “N/A” appears.
It is not urgent, because the weather will soon be hotter and hotter
- 84CAAC9E-5F9A-481A-BC19-D1CCBD70A6CF.jpeg (123.72 KiB) Viewed 7752 times
- BD1A5FF5-33C5-4181-9639-5214C0EFCAB9.jpeg (180.17 KiB) Viewed 7752 times
- 44D1B805-106A-4A65-978C-52DB21CEA39B.jpeg (117.41 KiB) Viewed 7752 times
- jmontamat
jmontamat wrote: Sun Mar 13, 2022 10:01 am Good morning.
It does not work
It works now, it was weekend.
- jmontamat
Check your updates.lorenz1982 wrote: Sun Mar 13, 2022 5:16 pm When 0°C is forecast, the message “N/A” appears.
It is not urgent, because the weather will soon be hotter and hotter.
It works.
- Sin título.png (11.21 KiB) Viewed 7651 times
lorenz1982
- Expert Boarder
I don't understand, I've done all the updates.jmontamat wrote: Tue Mar 15, 2022 6:18 pmCheck your updates.lorenz1982 wrote: Sun Mar 13, 2022 5:16 pm When 0°C is forecast, the message “N/A” appears.
It works.
i've same issue...lorenz1982 wrote: Sun Mar 13, 2022 5:16 pm When 0°C is forecast, the message “N/A” appears.
To fix the message “N/A” if 0 Grad, I changed the weather34-forecast-tablet.php file, works for me.
- weather34-forecast-tablet.zip
- (2.35 KiB) Downloaded 267 times
good afternoon sorry for delay
simple update file via https://weather34.com
* (March 17th) * Fix N/A forecast at 0C/32F ref Lorenzo (Forum)
- jmontamat
Thanks Brian for being here.
