Davis AirLink and meteostick
zakos52
Post by zakos52 »
I am thinking of buying the Davis AirLink 7210 air quality sensor. I am currently using the meteostick which reads my station data (Davis Vantage Vue) and the meteobridge which runs on the RPi4 (Meteobridge 5.5, Oct 27 2022, build 2881, FW 1.3)
I would like to know if the meteostick can read the airlink 7210 and to display the data in a diagram (metachart) as is done now with all the other sensors of my station.
Are there instructions to make the appropriate settings in the meteostick?
Re: Davis AirLink and meteostick
zakos52 wrote: Wed Nov 16, 2022 5:29 pm I am thinking of buying the Davis AirLink 7210 air quality sensor. I am currently using the meteostick which reads my station data (Davis Vantage Vue) and the meteobridge which runs on the RPi4 (Meteobridge 5.5, Oct 27 2022, build 2881, FW 1.3)
The airbridge is a stand-alone device. It does not receive data or sent data at the same frequency as the outside Davis devices do.
But any Meteobridge can get the data directly from the ip-address of the airlink.
Just define it as an extra "station"
Succes,
zakos52
Post by zakos52 »
Thanks for your reply.
Additionally, I would like to know if I can define a chart (metachart) for the airlink
zakos52 wrote: Thu Nov 17, 2022 9:23 am Thanks for your reply.
I am not 100% sure as I do not use any charts from my meteobridges.
But for your meteobridge an Airlink is another complete "weather"-station.
It has multiple PM and temp hum sensors.
The Airlink sensors will be in the same sensor lists as all the VUE sensors.
The Airlink sensor-values are stored in the meteobridge exactly the same as the VUE sensors.
Attached the sensor list of a Nano in a Davis Vue and sensors from other devices added.
zakos52
Post by zakos52 »
Thanks for your reply. I'm interested in creating a chart (metachart). I hope it can be done with the AirLink sensor too!
PS,
You can see on my page (https://meteovyronas.gr/en.htm) the chart (metachart) from all Davis Vue sensors
Metacharts can take any sensor from any connected weather station. No limits there.
