What NTP Time Servers URLs does the Nano-SD use for Time Synchronization
rzelle-K1TTC
Post by rzelle-K1TTC »
I need to know what NTP Time server or servers the Nano-SD is programmed to use and is there a way to re-program it to use an internal NTP Server
.. Ron
rzelle-K1TTC
Re: What NTP Time Servers URLs does the Nano-SD use for Time Synchronization
Hi Boris,
I should have addressed my question to you regarding what NTP server is the Nano-SD programmed to use. For security reason my network uses a local Satellite based NTP server. If I know the Time Server urls the Nano is using I can resolve them locally on my DNS servers.
..Ron
MGS
Post by MGS »
Have managed to find the system config file on my MB Pro 2 and the following NTP servers are configured
Hope it helps
Mark.
Screenshot 2023-04-15 at 19.24.45.png (76.99 KiB) Viewed 6686 times
My Weather Website http:\\www.harpendenweatherstation.co.uk
rzelle-K1TTC
Thanks Mark, I will see if I can determine if the Nano is using those ntp pools
.. Ron
rzelle-K1TTC
Hi Mark,
Where did you find the file with the config info and what was its name. I've been looking for a file with that info on my Nano and can't find anything that has NTP info in it?
.. Ron
MGS
Post by MGS »
Hi Ron,
If you SSH to the Nano SD and go to the /etc/config directory there is a file called system and in this file I found the NTP server setting on my PRO2 as below
Hope its helps you
Mark.
Screenshot 2023-04-20 at 20.33.28.png (447.61 KiB) Viewed 6637 times
rzelle-K1TTC
Mark,
Thanks that's where it is on the Nano so I verified it was using the same urls. I had configured my DNS servers with those urls to point to my local ntp satellite receiver and it also picked up the Purple Air as a NTP client. A win win ..
.. Ron
Anybody know the interval the NTP Time Servers are checked? Or is the time only sync'd at boot?
How difficult to built a user definable NTP Time server interface into the GUI? Some Proxy servers appear to block outside NTP links?
MGS
Post by MGS »
This may help
On the Openwrt documentation pages it indicates the default is 600s so if it’s not been changed it’s likely to be that.
https://openwrt.org/docs/guide-user/services/ntp/client
Mark
