I found this little Linux device on the net and found that it is verry impressive and mabe interesting to use with MeteoHub if you compare it's 1200MHz CPU with a NSLU2 266MHz CPU speed.;)
Power comsumption: Less than 5 Watts under normal operation!
The platform is built using Marvell’s Kirkwood series system-on-chip (SoC) design with a 1.2GHz Marvell Sheeva™ CPU processor equipped, 512Mbytes of FLASH and 512Mbytes of DRAM. The plug also features a 2.0 USB port to allow users to run applications that require a hard disk or other peripheral.
 More info here:
http://www.marvell.com/featured/plugcomputing.jsp
and here:
http://www.globalscaletechnologies.com/ ... v-kit.aspx
Downloads: Tools, kernel, Compiler, Drivers, etc...
http://www.plugcomputer.org
Cheers,
Vaako
