Marvell’s SheevaPlug is interesting for MeteoHub (Linux)
ON1DQD
Post by ON1DQD »
I found this little Linux device on the net and found that it is verry impressive and mabe interesting to use with MeteoHub if you compare it's 1200MHz CPU with a NSLU2 266MHz CPU speed.;)
Power comsumption: Less than 5 Watts under normal operation!
The platform is built using Marvell’s Kirkwood series system-on-chip (SoC) design with a 1.2GHz Marvell Sheeva™ CPU processor equipped, 512Mbytes of FLASH and 512Mbytes of DRAM. The plug also features a 2.0 USB port to allow users to run applications that require a hard disk or other peripheral.
More info here:
http://www.marvell.com/featured/plugcomputing.jsp
and here:
http://www.globalscaletechnologies.com/ ... v-kit.aspx
Downloads: Tools, kernel, Compiler, Drivers, etc...
http://www.plugcomputer.org
Cheers,
Vaako
Regards / Grüß,
Geert - ON1DQD
Re:Marvell’s SheevaPlug is interesting for MeteoHub (Linux)
Yep, downside is that is has just one USB connector so you will need a USB hub to get USB stick and weather station connected. Doing that would compromise the minimalistic design of the unit und I fear it will add trouble with USB stick reliability. Let's see, if a successor will improve on USB ports and/or internal flash storage.
Another question is, if debian 4/5 is available for the processor architecture... I haven't checked this so far...
jwpyle3
Post by jwpyle3 »
I've got one of these. That slot in the side of it is for an SD Memory card. Why not use that instead of a USB drive, the SD card and can be mounted like a drive. Put in a 8GB, 16GB, or bigger card and your set.
B) James
P.S. I would love to see Meteohub ported to this device.
That is interesting. I had overlooked the SD slot option. Ok, I will get one to have a closer look.
...but it will take 4 weeks until they get it delivered to me from the US. Looks like they are short on supply ;-)
jwpyle3
Post by jwpyle3 »
Admin,
I would be willing to send you mine. I haven't done anything with it yet, beside booting it up. You can get started on it and send it back when you get yours. I have everything that came with it in the box.
I bought it to set it up with my weather station but I haven't had the time. Now that I found your site and software, I'm willing to wait longer to see if you decide to port your software over to it.
Just let me know.
B) James
James, that is a very kind offer, which will speed-up things. Please send to
Boris Pasternak
Querweg 35
24632 Lentfoehrden
GERMANY
I will send it back when my units arrive.
Thanks again!
ON1DQD
Post by ON1DQD »
Any news here about this device?
Geert - ON1DQD
Regards / Grüß,
Geert - ON1DQD
I don't have unit to test with so far. So no progress in the meantime...
ON1DQD
Post by ON1DQD »
Hi Boris,
I have ordered one and it wil be here over a couple of weeks, if you like i can sent it to you if you want to play with it? ;)
So let me now.
Thx,
Geert
Regards / Grüß,
Geert - ON1DQD
Thanks Geert. I hope my order might be served 12th June. They seem to get a batch of units then. Demand looks to be much higher than expected.
They also claim units might drop below $50 over time, but that will not include an integrated SD card reader which I will need for Meteohub to record data.
I have received my SheevaPlugs and started porting Meteohub to debian lenny on these units. I am still far from having it ready for production, but first experimental versions do run...
At the moment Meteohub runs from USB stick, but I would like to have it running from SD card freeing USB connector to get connected to the weather station... so quite some things to tryout...
First port to SheevaPlug has been made based on Meteohub 4.4 and Debian Lenny 2.6.29 (kirkwood). Still expeimental, but if someone is willing to give it a try on his SheevaPlug, please drop me a note.
Doucumentation how to install a Meteoplug can be found here: http://www.meteohub.de/joomla/index.php ... &Itemid=29
ON1DQD
Post by ON1DQD »
Love to try but i dident receive my SheevaPlug yet :(
Do you remember how long you have to wait from order till you received the device?
All i can do now is wait, wait and wait till it arrive.
Thanks for making this possible!!!
Regards,
Geert ON1DQD
Regards / Grüß,
Geert - ON1DQD
It took about 6 weeks.
Installation of Meteohub on SheevaPlug has become more easy.
Please follow these instructions: http://www.meteohub.de/joomla/index.php ... &Itemid=29
