Landing Page
Mora
Landing Page
Post by Mora »
After a power failure, I was no longer able to reach the MB pro red. I have now done a factory reset.
When I enter the IP address, I'm on the landing page. The 2nd LED flashes and I can't get any further.
The SSh access also works, but what can I do with it?
I'm grateful for any help
Re: Landing Page
Did the router also go down? Sounds like there is no internet/connection?
Mora
Re: Landing Page
Post by Mora »
Router is ok, everything online. Yes, it is strange that the 2nd LED flashes, but I can access the Internet via the router. The other options Reboot Lan Client and Reboot Wifi AP do not change anything either.
It then appears on the display "Reboot Lan Client" without any progress as if it crashed.
Re: Landing Page
What can happen if everything goes down together then reboots is which device is the faster to start-up. There is a Boot Delay option under System/Administration to ensure the router/internet is fully up before the MB boots but more useful in remote systems. If you have fully shutdown and restated the MB from scratch then this should usually work?
Appears you are trying to connect via the WiFi? If so have you tried a cabled connection?
Mora
Re: Landing Page
Post by Mora »
The MB pro red is connected directly to the router with a cable. The MB is also recognized by the router. IP address is 192.168.160.12.
The browser then asks for a username and password. So in factory mode twice meteobridge.
Then http://192.168.160.12/cgi-bin/meteobridge.cgi appears
and
Meteobridge Landing Page (FW 1.4)
The 2nd LED flashes on the MB display.
I cannot reach the actual WEB interface.
Maybe you have another idea?
Re: Landing Page
Still appears it can not reach the internet?
Mora
Re: Landing Page
Post by Mora »
Yes no change.
Mora
Re: Landing Page
Post by Mora »
Internet connection is not a requirement to access the web interface.
As I said, I can't get to the web interface, maybe you have an idea about this?
Re: Landing Page
Is the RED LED blinking fast?
Mora
Re: Landing Page
Post by Mora »
Yes, the red LED flashes quickly.
Re: Landing Page
Check out the section Back to Defaults on a Meteobridge PRO
https://www.meteobridge.com/wiki/index. ... ng_Started
Mora
Re: Landing Page
Post by Mora »
What do you think I do all the time? Except for the cloud option, I have already tested everything 3 times. I think the cloud option makes no sense in my case.
I have an IP for the MB, but I can't get to the web interface.
I'm grateful for any help, but if you can't help me then just leave it. They keep asking the same things but don't answer my questions.
So what is this?
Have a nice day anyway...
Re: Landing Page
When you force the MB PRO into REBOOT WIFI AP mode (is selected via pressing button behind pinhole), Meteobridge should show up with its own WLAN where you can connect with your laptop. Being there you can enter all credentials needed for LAN oder WLAN access in your network. When you press "save and apply and reboot" these settings are stored and Meteobridge reboots and tries to connect as said.
Alternative: When you select "REBOOT LAN CLIENT" and it is connected to your router it should get an IP from your router and then you can login there to setup WIFI or alike.
Fast flashing red LED just tells that Meteobriodge cannot connect to the Meteobridge Internet server to get most recent application code from there. To reach the internet the Meteobridge needs an IP in your LAN, proper routing by your router and proper DNS. Therefore, a lot of places where something can go wrong.
Mora
Re: Landing Page
Post by Mora »
Thanks for your help
Ok, I select Reboot WIFI AP>Display shows Reboot Wifi Access Point>AP but does not start.
I do a cold start>MB starts as AP>IP address 192.168.1.1>I start Chromium Web Browser when I enter the IP of the AP I get here and no further
Bildschirmfoto vom 2023-09-03 22-26-05.png (204.5 KiB) Viewed 5076 times
The same thing happens when you select LAN CLIENT
Re: Landing Page
OK, when you can reach the landing page this tells that Meteobridge booted fine, and is connected to your LAN/WLAN.
When red LED is stuck in fast blinking mode it tells that Meteobridge cannot reach the Internet. That means your router is not giving the Meteobridge a proper DNS resolution or it is blocking HTTP traffic to it.
Did you just power cycle the Router or did you change something on the router side in terms of hardware or configuration?
