Meteobridge Pro - Missing folders after reboot. **solved**
WETRHE
Post by WETRHE »
I have got a strange issue:
After a reboot, the "data" folder with all subfolders "charts", "export", "import", "scripts" and "templates" are missing.
So I need to create all of these folders manually after each reboot.
Re: Meteobridge Pro - Missing folders after reboot
Never heard of or seen that. Which Meteobridge version are you using?
Can you please share data from "System - Information" tab?
WETRHE
Post by WETRHE »
As the USB storage is not listed on your "System - Info" tab something with your storage is wrong. Please share output of "http://ip-of-your-meteobridge/cgi-bin/system.cgi?dmesg" to get an idea if the storage itself failed or the internal USB hub is causing problems.
WETRHE
Post by WETRHE »
Sorry, need to divide into 2 parts as the output is too long:
command: dmesg
[261872.320000] scsi874 : usb-storage 1-1.4:1.0
[261873.330000] scsi 874:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[261873.340000] sd 874:0:0:0: Attached scsi generic sg0 type 0
[261873.360000] sd 874:0:0:0: [sda] Attached SCSI removable disk
[262134.400000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[262134.400000] scsi875 : usb-storage 1-1.4:1.0
[262135.410000] scsi 875:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[262135.420000] sd 875:0:0:0: Attached scsi generic sg0 type 0
[262135.450000] sd 875:0:0:0: [sda] Attached SCSI removable disk
[262488.440000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[262488.440000] scsi876 : usb-storage 1-1.4:1.0
[262489.450000] scsi 876:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[262489.480000] sd 876:0:0:0: Attached scsi generic sg0 type 0
[262489.480000] sd 876:0:0:0: [sda] Attached SCSI removable disk
[262769.510000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[262769.510000] scsi877 : usb-storage 1-1.4:1.0
[262770.520000] scsi 877:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[262770.530000] sd 877:0:0:0: Attached scsi generic sg0 type 0
[262770.540000] sd 877:0:0:0: [sda] Attached SCSI removable disk
[263094.630000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[263094.630000] scsi878 : usb-storage 1-1.4:1.0
[263095.640000] scsi 878:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[263095.670000] sd 878:0:0:0: Attached scsi generic sg0 type 0
[263095.700000] sd 878:0:0:0: [sda] Attached SCSI removable disk
[263377.550000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[263377.590000] scsi879 : usb-storage 1-1.4:1.0
[263378.590000] scsi 879:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[263378.600000] sd 879:0:0:0: Attached scsi generic sg0 type 0
[263378.610000] sd 879:0:0:0: [sda] Attached SCSI removable disk
[263613.610000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[263613.630000] scsi880 : usb-storage 1-1.4:1.0
[263614.630000] scsi 880:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[263614.640000] sd 880:0:0:0: Attached scsi generic sg0 type 0
[263614.650000] sd 880:0:0:0: [sda] Attached SCSI removable disk
[264007.590000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[264007.590000] scsi881 : usb-storage 1-1.4:1.0
[264008.600000] scsi 881:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[264008.630000] sd 881:0:0:0: Attached scsi generic sg0 type 0
[264008.630000] sd 881:0:0:0: [sda] Attached SCSI removable disk
[264250.640000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[264250.640000] scsi882 : usb-storage 1-1.4:1.0
[264251.660000] scsi 882:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[264251.690000] sd 882:0:0:0: Attached scsi generic sg0 type 0
[264251.710000] sd 882:0:0:0: [sda] Attached SCSI removable disk
[264597.660000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[264597.660000] scsi883 : usb-storage 1-1.4:1.0
[264598.670000] scsi 883:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[264598.680000] sd 883:0:0:0: Attached scsi generic sg0 type 0
[264598.690000] sd 883:0:0:0: [sda] Attached SCSI removable disk
[264878.680000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[264878.680000] scsi884 : usb-storage 1-1.4:1.0
[264879.690000] scsi 884:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[264879.700000] sd 884:0:0:0: Attached scsi generic sg0 type 0
[264879.710000] sd 884:0:0:0: [sda] Attached SCSI removable disk
[265121.750000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[265121.750000] scsi885 : usb-storage 1-1.4:1.0
[265122.760000] scsi 885:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[265122.770000] sd 885:0:0:0: Attached scsi generic sg0 type 0
[265122.780000] sd 885:0:0:0: [sda] Attached SCSI removable disk
[265433.890000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[265433.890000] scsi886 : usb-storage 1-1.4:1.0
[265434.920000] scsi 886:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[265434.930000] sd 886:0:0:0: Attached scsi generic sg0 type 0
[265434.950000] sd 886:0:0:0: [sda] Attached SCSI removable disk
[265716.080000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[265716.080000] scsi887 : usb-storage 1-1.4:1.0
[265717.120000] scsi 887:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[265717.150000] sd 887:0:0:0: Attached scsi generic sg0 type 0
[265717.160000] sd 887:0:0:0: [sda] Attached SCSI removable disk
[266053.800000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[266053.800000] scsi888 : usb-storage 1-1.4:1.0
[266054.840000] scsi 888:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[266054.850000] sd 888:0:0:0: Attached scsi generic sg0 type 0
[266054.870000] sd 888:0:0:0: [sda] Attached SCSI removable disk
[266362.830000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[266362.830000] scsi889 : usb-storage 1-1.4:1.0
[266363.840000] scsi 889:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[266363.850000] sd 889:0:0:0: Attached scsi generic sg0 type 0
[266363.860000] sd 889:0:0:0: [sda] Attached SCSI removable disk
[266692.780000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[266692.780000] scsi890 : usb-storage 1-1.4:1.0
[266693.790000] scsi 890:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[266693.800000] sd 890:0:0:0: Attached scsi generic sg0 type 0
[266693.810000] sd 890:0:0:0: [sda] Attached SCSI removable disk
[266925.850000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[266925.860000] scsi891 : usb-storage 1-1.4:1.0
[266926.860000] scsi 891:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[266926.870000] sd 891:0:0:0: Attached scsi generic sg0 type 0
[266926.890000] sd 891:0:0:0: [sda] Attached SCSI removable disk
[267241.860000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[267241.860000] scsi892 : usb-storage 1-1.4:1.0
[267242.870000] scsi 892:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[267242.880000] sd 892:0:0:0: Attached scsi generic sg0 type 0
[267242.890000] sd 892:0:0:0: [sda] Attached SCSI removable disk
[267587.860000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[267587.860000] scsi893 : usb-storage 1-1.4:1.0
[267588.870000] scsi 893:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[267588.880000] sd 893:0:0:0: Attached scsi generic sg0 type 0
[267588.890000] sd 893:0:0:0: [sda] Attached SCSI removable disk
[267866.970000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[267866.970000] scsi894 : usb-storage 1-1.4:1.0
[267867.980000] scsi 894:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[267868.010000] sd 894:0:0:0: Attached scsi generic sg0 type 0
[267868.030000] sd 894:0:0:0: [sda] Attached SCSI removable disk
[268143.920000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[268143.920000] scsi895 : usb-storage 1-1.4:1.0
[268144.940000] scsi 895:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[268144.950000] sd 895:0:0:0: Attached scsi generic sg0 type 0
[268144.960000] sd 895:0:0:0: [sda] Attached SCSI removable disk
[268418.920000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[268418.920000] scsi896 : usb-storage 1-1.4:1.0
[268419.930000] scsi 896:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[268419.940000] sd 896:0:0:0: Attached scsi generic sg0 type 0
[268419.950000] sd 896:0:0:0: [sda] Attached SCSI removable disk
[268737.110000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[268737.110000] scsi897 : usb-storage 1-1.4:1.0
[268738.120000] scsi 897:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[268738.140000] sd 897:0:0:0: Attached scsi generic sg0 type 0
[268738.170000] sd 897:0:0:0: [sda] Attached SCSI removable disk
[269010.040000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[269010.040000] scsi898 : usb-storage 1-1.4:1.0
[269011.050000] scsi 898:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[269011.060000] sd 898:0:0:0: Attached scsi generic sg0 type 0
[269011.090000] sd 898:0:0:0: [sda] Attached SCSI removable disk
[269360.360000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[269360.360000] scsi899 : usb-storage 1-1.4:1.0
[269361.390000] scsi 899:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[269361.400000] sd 899:0:0:0: Attached scsi generic sg0 type 0
[269361.450000] sd 899:0:0:0: [sda] Attached SCSI removable disk
[269695.060000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[269695.070000] scsi900 : usb-storage 1-1.4:1.0
[269696.070000] scsi 900:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[269696.080000] sd 900:0:0:0: Attached scsi generic sg0 type 0
[269696.090000] sd 900:0:0:0: [sda] Attached SCSI removable disk
[269911.390000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[269911.390000] scsi901 : usb-storage 1-1.4:1.0
[269912.400000] scsi 901:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[269912.440000] sd 901:0:0:0: Attached scsi generic sg0 type 0
[269912.450000] sd 901:0:0:0: [sda] Attached SCSI removable disk
[270219.120000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[270219.120000] scsi902 : usb-storage 1-1.4:1.0
[270220.150000] scsi 902:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[270220.170000] sd 902:0:0:0: Attached scsi generic sg0 type 0
[270220.180000] sd 902:0:0:0: [sda] Attached SCSI removable disk
[270546.320000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[270546.320000] scsi903 : usb-storage 1-1.4:1.0
[270547.330000] scsi 903:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[270547.350000] sd 903:0:0:0: Attached scsi generic sg0 type 0
[270547.360000] sd 903:0:0:0: [sda] Attached SCSI removable disk
[270839.220000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[270839.220000] scsi904 : usb-storage 1-1.4:1.0
[270840.230000] scsi 904:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[270840.240000] sd 904:0:0:0: Attached scsi generic sg0 type 0
[270840.270000] sd 904:0:0:0: [sda] Attached SCSI removable disk
[271125.150000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[271125.150000] scsi905 : usb-storage 1-1.4:1.0
[271126.180000] scsi 905:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[271126.190000] sd 905:0:0:0: Attached scsi generic sg0 type 0
[271126.200000] sd 905:0:0:0: [sda] Attached SCSI removable disk
[271441.180000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[271441.180000] scsi906 : usb-storage 1-1.4:1.0
[271442.190000] scsi 906:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[271442.200000] sd 906:0:0:0: Attached scsi generic sg0 type 0
[271442.210000] sd 906:0:0:0: [sda] Attached SCSI removable disk
[271728.300000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[271728.300000] scsi907 : usb-storage 1-1.4:1.0
[271729.310000] scsi 907:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[271729.320000] sd 907:0:0:0: Attached scsi generic sg0 type 0
[271729.330000] sd 907:0:0:0: [sda] Attached SCSI removable disk
[272049.300000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[272049.300000] scsi908 : usb-storage 1-1.4:1.0
[272050.310000] scsi 908:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[272050.320000] sd 908:0:0:0: Attached scsi generic sg0 type 0
[272050.330000] sd 908:0:0:0: [sda] Attached SCSI removable disk
[272347.440000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[272347.440000] scsi909 : usb-storage 1-1.4:1.0
[272348.470000] scsi 909:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[272348.480000] sd 909:0:0:0: Attached scsi generic sg0 type 0
[272348.490000] sd 909:0:0:0: [sda] Attached SCSI removable disk
[272622.360000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[272622.390000] scsi910 : usb-storage 1-1.4:1.0
[272623.390000] scsi 910:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[272623.400000] sd 910:0:0:0: Attached scsi generic sg0 type 0
[272623.420000] sd 910:0:0:0: [sda] Attached SCSI removable disk
[272955.270000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[272955.270000] scsi911 : usb-storage 1-1.4:1.0
[272956.280000] scsi 911:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[272956.290000] sd 911:0:0:0: Attached scsi generic sg0 type 0
[272956.300000] sd 911:0:0:0: [sda] Attached SCSI removable disk
[273300.330000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[273300.330000] scsi912 : usb-storage 1-1.4:1.0
[273301.340000] scsi 912:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[273301.350000] sd 912:0:0:0: Attached scsi generic sg0 type 0
[273301.370000] sd 912:0:0:0: [sda] Attached SCSI removable disk
[273525.270000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[273525.270000] scsi913 : usb-storage 1-1.4:1.0
[273526.280000] scsi 913:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[273526.290000] sd 913:0:0:0: Attached scsi generic sg0 type 0
[273526.300000] sd 913:0:0:0: [sda] Attached SCSI removable disk
[273869.520000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[273869.520000] scsi914 : usb-storage 1-1.4:1.0
[273870.530000] scsi 914:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[273870.540000] sd 914:0:0:0: Attached scsi generic sg0 type 0
[273870.550000] sd 914:0:0:0: [sda] Attached SCSI removable disk
[274196.370000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[274196.370000] scsi915 : usb-storage 1-1.4:1.0
[274197.390000] scsi 915:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[274197.410000] sd 915:0:0:0: Attached scsi generic sg0 type 0
[274197.420000] sd 915:0:0:0: [sda] Attached SCSI removable disk
[274478.330000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[274478.330000] scsi916 : usb-storage 1-1.4:1.0
[274479.340000] scsi 916:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[274479.350000] sd 916:0:0:0: Attached scsi generic sg0 type 0
[274479.360000] sd 916:0:0:0: [sda] Attached SCSI removable disk
[274727.470000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[274727.470000] scsi917 : usb-storage 1-1.4:1.0
[274728.480000] scsi 917:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[274728.490000] sd 917:0:0:0: Attached scsi generic sg0 type 0
[274728.500000] sd 917:0:0:0: [sda] Attached SCSI removable disk
[275093.460000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[275093.460000] scsi918 : usb-storage 1-1.4:1.0
[275094.470000] scsi 918:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[275094.480000] sd 918:0:0:0: Attached scsi generic sg0 type 0
[275094.490000] sd 918:0:0:0: [sda] Attached SCSI removable disk
[275331.510000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[275331.510000] scsi919 : usb-storage 1-1.4:1.0
[275332.520000] scsi 919:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[275332.530000] sd 919:0:0:0: Attached scsi generic sg0 type 0
[275332.540000] sd 919:0:0:0: [sda] Attached SCSI removable disk
[275702.490000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[275702.490000] scsi920 : usb-storage 1-1.4:1.0
[275703.500000] scsi 920:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[275703.510000] sd 920:0:0:0: Attached scsi generic sg0 type 0
[275703.520000] sd 920:0:0:0: [sda] Attached SCSI removable disk
[275995.640000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[275995.640000] scsi921 : usb-storage 1-1.4:1.0
[275996.670000] scsi 921:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[275996.680000] sd 921:0:0:0: Attached scsi generic sg0 type 0
[275996.690000] sd 921:0:0:0: [sda] Attached SCSI removable disk
[276277.680000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[276277.680000] scsi922 : usb-storage 1-1.4:1.0
[276278.690000] scsi 922:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[276278.700000] sd 922:0:0:0: Attached scsi generic sg0 type 0
[276278.710000] sd 922:0:0:0: [sda] Attached SCSI removable disk
[276522.530000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[276522.530000] scsi923 : usb-storage 1-1.4:1.0
[276523.540000] scsi 923:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[276523.550000] sd 923:0:0:0: Attached scsi generic sg0 type 0
[276523.560000] sd 923:0:0:0: [sda] Attached SCSI removable disk
[276892.550000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[276892.550000] scsi924 : usb-storage 1-1.4:1.0
[276893.560000] scsi 924:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[276893.600000] sd 924:0:0:0: Attached scsi generic sg0 type 0
[276893.600000] sd 924:0:0:0: [sda] Attached SCSI removable disk
[277186.850000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[277186.880000] scsi925 : usb-storage 1-1.4:1.0
[277187.880000] scsi 925:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[277187.890000] sd 925:0:0:0: Attached scsi generic sg0 type 0
[277187.900000] sd 925:0:0:0: [sda] Attached SCSI removable disk
[277457.640000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[277457.640000] scsi926 : usb-storage 1-1.4:1.0
[277458.650000] scsi 926:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[277458.660000] sd 926:0:0:0: Attached scsi generic sg0 type 0
[277458.670000] sd 926:0:0:0: [sda] Attached SCSI removable disk
[277770.740000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[277770.740000] scsi927 : usb-storage 1-1.4:1.0
[277771.750000] scsi 927:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[277771.760000] sd 927:0:0:0: Attached scsi generic sg0 type 0
[277771.770000] sd 927:0:0:0: [sda] Attached SCSI removable disk
[278081.950000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[278081.960000] scsi928 : usb-storage 1-1.4:1.0
[278082.960000] scsi 928:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[278082.970000] sd 928:0:0:0: Attached scsi generic sg0 type 0
[278082.980000] sd 928:0:0:0: [sda] Attached SCSI removable disk
[278334.670000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[278334.670000] scsi929 : usb-storage 1-1.4:1.0
[278335.680000] scsi 929:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[278335.690000] sd 929:0:0:0: Attached scsi generic sg0 type 0
[278335.710000] sd 929:0:0:0: [sda] Attached SCSI removable disk
[278706.740000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[278706.740000] scsi930 : usb-storage 1-1.4:1.0
[278707.750000] scsi 930:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[278707.760000] sd 930:0:0:0: Attached scsi generic sg0 type 0
[278707.780000] sd 930:0:0:0: [sda] Attached SCSI removable disk
[278979.940000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[278979.940000] scsi931 : usb-storage 1-1.4:1.0
[278980.950000] scsi 931:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[278980.960000] sd 931:0:0:0: Attached scsi generic sg0 type 0
[278980.970000] sd 931:0:0:0: [sda] Attached SCSI removable disk
[279270.730000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[279270.730000] scsi932 : usb-storage 1-1.4:1.0
[279271.740000] scsi 932:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[279271.750000] sd 932:0:0:0: Attached scsi generic sg0 type 0
[279271.760000] sd 932:0:0:0: [sda] Attached SCSI removable disk
[279603.770000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[279603.770000] scsi933 : usb-storage 1-1.4:1.0
[279604.780000] scsi 933:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[279604.790000] sd 933:0:0:0: Attached scsi generic sg0 type 0
[279604.810000] sd 933:0:0:0: [sda] Attached SCSI removable disk
[279861.880000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[279861.910000] scsi934 : usb-storage 1-1.4:1.0
[279862.910000] scsi 934:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[279862.920000] sd 934:0:0:0: Attached scsi generic sg0 type 0
[279862.930000] sd 934:0:0:0: [sda] Attached SCSI removable disk
[280188.820000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[280188.820000] scsi935 : usb-storage 1-1.4:1.0
[280189.830000] scsi 935:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[280189.840000] sd 935:0:0:0: Attached scsi generic sg0 type 0
[280189.850000] sd 935:0:0:0: [sda] Attached SCSI removable disk
[280454.850000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[280454.850000] scsi936 : usb-storage 1-1.4:1.0
[280455.860000] scsi 936:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[280455.870000] sd 936:0:0:0: Attached scsi generic sg0 type 0
[280455.880000] sd 936:0:0:0: [sda] Attached SCSI removable disk
[280774.890000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[280774.890000] scsi937 : usb-storage 1-1.4:1.0
[280775.900000] scsi 937:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[280775.910000] sd 937:0:0:0: Attached scsi generic sg0 type 0
[280775.920000] sd 937:0:0:0: [sda] Attached SCSI removable disk
[281094.000000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[281094.000000] scsi938 : usb-storage 1-1.4:1.0
[281095.010000] scsi 938:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[281095.020000] sd 938:0:0:0: Attached scsi generic sg0 type 0
[281095.030000] sd 938:0:0:0: [sda] Attached SCSI removable disk
[281404.870000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[281404.870000] scsi939 : usb-storage 1-1.4:1.0
[281405.880000] scsi 939:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[281405.890000] sd 939:0:0:0: Attached scsi generic sg0 type 0
[281405.900000] sd 939:0:0:0: [sda] Attached SCSI removable disk
[281658.860000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[281658.860000] scsi940 : usb-storage 1-1.4:1.0
[281659.870000] scsi 940:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[281659.880000] sd 940:0:0:0: Attached scsi generic sg0 type 0
[281659.890000] sd 940:0:0:0: [sda] Attached SCSI removable disk
[281953.910000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[281953.910000] scsi941 : usb-storage 1-1.4:1.0
[281954.920000] scsi 941:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[281954.930000] sd 941:0:0:0: Attached scsi generic sg0 type 0
[281954.940000] sd 941:0:0:0: [sda] Attached SCSI removable disk
[282229.890000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[282229.890000] scsi942 : usb-storage 1-1.4:1.0
[282230.900000] scsi 942:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[282230.910000] sd 942:0:0:0: Attached scsi generic sg0 type 0
[282230.920000] sd 942:0:0:0: [sda] Attached SCSI removable disk
[282540.950000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[282540.950000] scsi943 : usb-storage 1-1.4:1.0
[282541.960000] scsi 943:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[282541.970000] sd 943:0:0:0: Attached scsi generic sg0 type 0
[282541.980000] sd 943:0:0:0: [sda] Attached SCSI removable disk
[282861.920000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[282861.920000] scsi944 : usb-storage 1-1.4:1.0
[282862.930000] scsi 944:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[282862.940000] sd 944:0:0:0: Attached scsi generic sg0 type 0
[282862.960000] sd 944:0:0:0: [sda] Attached SCSI removable disk
[283143.950000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[283143.950000] scsi945 : usb-storage 1-1.4:1.0
[283144.960000] scsi 945:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[283144.970000] sd 945:0:0:0: Attached scsi generic sg0 type 0
[283144.980000] sd 945:0:0:0: [sda] Attached SCSI removable disk
[283428.100000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[283428.100000] scsi946 : usb-storage 1-1.4:1.0
[283429.110000] scsi 946:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[283429.120000] sd 946:0:0:0: Attached scsi generic sg0 type 0
[283429.130000] sd 946:0:0:0: [sda] Attached SCSI removable disk
[283803.990000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[283804.010000] scsi947 : usb-storage 1-1.4:1.0
[283805.010000] scsi 947:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[283805.020000] sd 947:0:0:0: Attached scsi generic sg0 type 0
[283805.030000] sd 947:0:0:0: [sda] Attached SCSI removable disk
[284073.000000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[284073.000000] scsi948 : usb-storage 1-1.4:1.0
[284074.010000] scsi 948:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[284074.020000] sd 948:0:0:0: Attached scsi generic sg0 type 0
[284074.030000] sd 948:0:0:0: [sda] Attached SCSI removable disk
[284405.020000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[284405.020000] scsi949 : usb-storage 1-1.4:1.0
[284406.030000] scsi 949:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[284406.050000] sd 949:0:0:0: Attached scsi generic sg0 type 0
[284406.050000] sd 949:0:0:0: [sda] Attached SCSI removable disk
[284680.120000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[284680.120000] scsi950 : usb-storage 1-1.4:1.0
[284681.130000] scsi 950:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[284681.170000] sd 950:0:0:0: Attached scsi generic sg0 type 0
[284681.190000] sd 950:0:0:0: [sda] Attached SCSI removable disk
[284965.070000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[284965.070000] scsi951 : usb-storage 1-1.4:1.0
[284966.080000] scsi 951:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[284966.090000] sd 951:0:0:0: Attached scsi generic sg0 type 0
[284966.110000] sd 951:0:0:0: [sda] Attached SCSI removable disk
[285236.080000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[285236.080000] scsi952 : usb-storage 1-1.4:1.0
[285237.090000] scsi 952:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[285237.100000] sd 952:0:0:0: Attached scsi generic sg0 type 0
[285237.110000] sd 952:0:0:0: [sda] Attached SCSI removable disk
[285515.180000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[285515.180000] scsi953 : usb-storage 1-1.4:1.0
[285516.190000] scsi 953:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[285516.200000] sd 953:0:0:0: Attached scsi generic sg0 type 0
[285516.230000] sd 953:0:0:0: [sda] Attached SCSI removable disk
[285842.150000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[285842.150000] scsi954 : usb-storage 1-1.4:1.0
[285843.160000] scsi 954:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[285843.170000] sd 954:0:0:0: Attached scsi generic sg0 type 0
[285843.180000] sd 954:0:0:0: [sda] Attached SCSI removable disk
[286195.130000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[286195.130000] scsi955 : usb-storage 1-1.4:1.0
[286196.140000] scsi 955:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[286196.150000] sd 955:0:0:0: Attached scsi generic sg0 type 0
[286196.160000] sd 955:0:0:0: [sda] Attached SCSI removable disk
[286466.150000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[286466.150000] scsi956 : usb-storage 1-1.4:1.0
[286467.170000] scsi 956:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[286467.180000] sd 956:0:0:0: Attached scsi generic sg0 type 0
[286467.190000] sd 956:0:0:0: [sda] Attached SCSI removable disk
[286790.150000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[286790.150000] scsi957 : usb-storage 1-1.4:1.0
[286791.160000] scsi 957:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[286791.170000] sd 957:0:0:0: Attached scsi generic sg0 type 0
[286791.180000] sd 957:0:0:0: [sda] Attached SCSI removable disk
[287063.250000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[287063.250000] scsi958 : usb-storage 1-1.4:1.0
[287064.260000] scsi 958:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[287064.270000] sd 958:0:0:0: Attached scsi generic sg0 type 0
[287064.300000] sd 958:0:0:0: [sda] Attached SCSI removable disk
[287336.160000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[287336.180000] scsi959 : usb-storage 1-1.4:1.0
[287337.180000] scsi 959:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[287337.190000] sd 959:0:0:0: Attached scsi generic sg0 type 0
[287337.200000] sd 959:0:0:0: [sda] Attached SCSI removable disk
[287621.210000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[287621.210000] scsi960 : usb-storage 1-1.4:1.0
[287622.220000] scsi 960:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[287622.230000] sd 960:0:0:0: Attached scsi generic sg0 type 0
[287622.240000] sd 960:0:0:0: [sda] Attached SCSI removable disk
[287923.210000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[287923.210000] scsi961 : usb-storage 1-1.4:1.0
[287924.220000] scsi 961:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[287924.230000] sd 961:0:0:0: Attached scsi generic sg0 type 0
[287924.240000] sd 961:0:0:0: [sda] Attached SCSI removable disk
[288289.210000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[288289.210000] scsi962 : usb-storage 1-1.4:1.0
[288290.220000] scsi 962:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[288290.230000] sd 962:0:0:0: Attached scsi generic sg0 type 0
[288290.240000] sd 962:0:0:0: [sda] Attached SCSI removable disk
[288528.350000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[288528.350000] scsi963 : usb-storage 1-1.4:1.0
[288529.360000] scsi 963:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[288529.370000] sd 963:0:0:0: Attached scsi generic sg0 type 0
[288529.400000] sd 963:0:0:0: [sda] Attached SCSI removable disk
[288893.310000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[288893.310000] scsi964 : usb-storage 1-1.4:1.0
[288894.320000] scsi 964:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[288894.330000] sd 964:0:0:0: Attached scsi generic sg0 type 0
[288894.340000] sd 964:0:0:0: [sda] Attached SCSI removable disk
[289170.260000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[289170.260000] scsi965 : usb-storage 1-1.4:1.0
[289171.270000] scsi 965:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[289171.280000] sd 965:0:0:0: Attached scsi generic sg0 type 0
[289171.310000] sd 965:0:0:0: [sda] Attached SCSI removable disk
[289458.420000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[289458.420000] scsi966 : usb-storage 1-1.4:1.0
[289459.450000] scsi 966:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[289459.460000] sd 966:0:0:0: Attached scsi generic sg0 type 0
[289459.470000] sd 966:0:0:0: [sda] Attached SCSI removable disk
[289771.270000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[289771.270000] scsi967 : usb-storage 1-1.4:1.0
[289772.280000] scsi 967:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[289772.290000] sd 967:0:0:0: Attached scsi generic sg0 type 0
[289772.300000] sd 967:0:0:0: [sda] Attached SCSI removable disk
[290032.310000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[290032.310000] scsi968 : usb-storage 1-1.4:1.0
[290033.320000] scsi 968:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[290033.330000] sd 968:0:0:0: Attached scsi generic sg0 type 0
[290033.340000] sd 968:0:0:0: [sda] Attached SCSI removable disk
[290355.380000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[290355.380000] scsi969 : usb-storage 1-1.4:1.0
[290356.390000] scsi 969:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[290356.400000] sd 969:0:0:0: Attached scsi generic sg0 type 0
[290356.420000] sd 969:0:0:0: [sda] Attached SCSI removable disk
[290693.260000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[290693.260000] scsi970 : usb-storage 1-1.4:1.0
[290694.270000] scsi 970:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[290694.280000] sd 970:0:0:0: Attached scsi generic sg0 type 0
[290694.290000] sd 970:0:0:0: [sda] Attached SCSI removable disk
[290939.280000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[290939.280000] scsi971 : usb-storage 1-1.4:1.0
[290940.290000] scsi 971:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[290940.300000] sd 971:0:0:0: Attached scsi generic sg0 type 0
[290940.310000] sd 971:0:0:0: [sda] Attached SCSI removable disk
[291231.380000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[291231.380000] scsi972 : usb-storage 1-1.4:1.0
[291232.390000] scsi 972:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[291232.400000] sd 972:0:0:0: Attached scsi generic sg0 type 0
[291232.410000] sd 972:0:0:0: [sda] Attached SCSI removable disk
[291593.350000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[291593.350000] scsi973 : usb-storage 1-1.4:1.0
[291594.360000] scsi 973:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[291594.370000] sd 973:0:0:0: Attached scsi generic sg0 type 0
[291594.380000] sd 973:0:0:0: [sda] Attached SCSI removable disk
[291897.390000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[291897.390000] scsi974 : usb-storage 1-1.4:1.0
[291898.400000] scsi 974:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[291898.410000] sd 974:0:0:0: Attached scsi generic sg0 type 0
[291898.420000] sd 974:0:0:0: [sda] Attached SCSI removable disk
[292134.400000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[292134.400000] scsi975 : usb-storage 1-1.4:1.0
[292135.410000] scsi 975:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[292135.430000] sd 975:0:0:0: Attached scsi generic sg0 type 0
[292135.430000] sd 975:0:0:0: [sda] Attached SCSI removable disk
[292490.350000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[292490.350000] scsi976 : usb-storage 1-1.4:1.0
[292491.360000] scsi 976:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[292491.370000] sd 976:0:0:0: Attached scsi generic sg0 type 0
[292491.380000] sd 976:0:0:0: [sda] Attached SCSI removable disk
[292772.420000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[292772.420000] scsi977 : usb-storage 1-1.4:1.0
[292773.430000] scsi 977:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[292773.440000] sd 977:0:0:0: Attached scsi generic sg0 type 0
[292773.450000] sd 977:0:0:0: [sda] Attached SCSI removable disk
[293054.380000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[293054.380000] scsi978 : usb-storage 1-1.4:1.0
[293055.390000] scsi 978:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[293055.400000] sd 978:0:0:0: Attached scsi generic sg0 type 0
[293055.410000] sd 978:0:0:0: [sda] Attached SCSI removable disk
[293371.350000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[293371.350000] scsi979 : usb-storage 1-1.4:1.0
[293372.360000] scsi 979:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[293372.370000] sd 979:0:0:0: Attached scsi generic sg0 type 0
[293372.380000] sd 979:0:0:0: [sda] Attached SCSI removable disk
[293615.500000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[293615.500000] scsi980 : usb-storage 1-1.4:1.0
[293616.510000] scsi 980:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[293616.520000] sd 980:0:0:0: Attached scsi generic sg0 type 0
[293616.550000] sd 980:0:0:0: [sda] Attached SCSI removable disk
[293932.450000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[293932.450000] scsi981 : usb-storage 1-1.4:1.0
[293933.460000] scsi 981:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[293933.470000] sd 981:0:0:0: Attached scsi generic sg0 type 0
[293933.480000] sd 981:0:0:0: [sda] Attached SCSI removable disk
[294301.450000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[294301.450000] scsi982 : usb-storage 1-1.4:1.0
[294302.460000] scsi 982:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[294302.470000] sd 982:0:0:0: Attached scsi generic sg0 type 0
[294302.480000] sd 982:0:0:0: [sda] Attached SCSI removable disk
[294572.400000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[294572.400000] scsi983 : usb-storage 1-1.4:1.0
[294573.410000] scsi 983:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[294573.420000] sd 983:0:0:0: Attached scsi generic sg0 type 0
[294573.430000] sd 983:0:0:0: [sda] Attached SCSI removable disk
[294845.430000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[294845.430000] scsi984 : usb-storage 1-1.4:1.0
[294846.440000] scsi 984:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[294846.450000] sd 984:0:0:0: Attached scsi generic sg0 type 0
[294846.460000] sd 984:0:0:0: [sda] Attached SCSI removable disk
[295112.610000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[295112.610000] scsi985 : usb-storage 1-1.4:1.0
[295113.620000] scsi 985:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[295113.630000] sd 985:0:0:0: Attached scsi generic sg0 type 0
[295113.660000] sd 985:0:0:0: [sda] Attached SCSI removable disk
[295487.480000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[295487.480000] scsi986 : usb-storage 1-1.4:1.0
[295488.490000] scsi 986:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[295488.500000] sd 986:0:0:0: Attached scsi generic sg0 type 0
[295488.510000] sd 986:0:0:0: [sda] Attached SCSI removable disk
[295735.520000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[295735.520000] scsi987 : usb-storage 1-1.4:1.0
[295736.530000] scsi 987:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[295736.540000] sd 987:0:0:0: Attached scsi generic sg0 type 0
[295736.560000] sd 987:0:0:0: [sda] Attached SCSI removable disk
[296030.490000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[296030.490000] scsi988 : usb-storage 1-1.4:1.0
[296031.500000] scsi 988:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[296031.510000] sd 988:0:0:0: Attached scsi generic sg0 type 0
[296031.520000] sd 988:0:0:0: [sda] Attached SCSI removable disk
[296328.520000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[296328.530000] scsi989 : usb-storage 1-1.4:1.0
[296329.540000] scsi 989:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[296329.550000] sd 989:0:0:0: Attached scsi generic sg0 type 0
[296329.560000] sd 989:0:0:0: [sda] Attached SCSI removable disk
[296643.600000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[296643.600000] scsi990 : usb-storage 1-1.4:1.0
[296644.610000] scsi 990:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[296644.620000] sd 990:0:0:0: Attached scsi generic sg0 type 0
[296644.630000] sd 990:0:0:0: [sda] Attached SCSI removable disk
[296980.480000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[296980.480000] scsi991 : usb-storage 1-1.4:1.0
[296981.490000] scsi 991:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[296981.500000] sd 991:0:0:0: Attached scsi generic sg0 type 0
[296981.510000] sd 991:0:0:0: [sda] Attached SCSI removable disk
[297240.650000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[297240.690000] scsi992 : usb-storage 1-1.4:1.0
[297241.690000] scsi 992:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[297241.700000] sd 992:0:0:0: Attached scsi generic sg0 type 0
[297241.710000] sd 992:0:0:0: [sda] Attached SCSI removable disk
[297570.540000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[297570.550000] scsi993 : usb-storage 1-1.4:1.0
[297571.550000] scsi 993:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[297571.560000] sd 993:0:0:0: Attached scsi generic sg0 type 0
[297571.570000] sd 993:0:0:0: [sda] Attached SCSI removable disk
[297842.560000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[297842.560000] scsi994 : usb-storage 1-1.4:1.0
[297843.570000] scsi 994:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[297843.580000] sd 994:0:0:0: Attached scsi generic sg0 type 0
[297843.610000] sd 994:0:0:0: [sda] Attached SCSI removable disk
[298129.500000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[298129.520000] scsi995 : usb-storage 1-1.4:1.0
[298130.520000] scsi 995:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[298130.530000] sd 995:0:0:0: Attached scsi generic sg0 type 0
[298130.540000] sd 995:0:0:0: [sda] Attached SCSI removable disk
[298419.590000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[298419.590000] scsi996 : usb-storage 1-1.4:1.0
[298420.600000] scsi 996:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[298420.610000] sd 996:0:0:0: Attached scsi generic sg0 type 0
[298420.620000] sd 996:0:0:0: [sda] Attached SCSI removable disk
[298717.640000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[298717.640000] scsi997 : usb-storage 1-1.4:1.0
[298718.650000] scsi 997:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[298718.660000] sd 997:0:0:0: Attached scsi generic sg0 type 0
[298718.670000] sd 997:0:0:0: [sda] Attached SCSI removable disk
[299057.550000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[299057.550000] scsi998 : usb-storage 1-1.4:1.0
[299058.560000] scsi 998:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[299058.570000] sd 998:0:0:0: Attached scsi generic sg0 type 0
[299058.580000] sd 998:0:0:0: [sda] Attached SCSI removable disk
[299315.570000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[299315.570000] scsi999 : usb-storage 1-1.4:1.0
[299316.580000] scsi 999:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[299316.590000] sd 999:0:0:0: Attached scsi generic sg0 type 0
[299316.600000] sd 999:0:0:0: [sda] Attached SCSI removable disk
[299706.580000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[299706.580000] scsi1000 : usb-storage 1-1.4:1.0
[299707.590000] scsi 1000:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[299707.600000] sd 1000:0:0:0: Attached scsi generic sg0 type 0
[299707.610000] sd 1000:0:0:0: [sda] Attached SCSI removable disk
[299935.700000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[299935.710000] scsi1001 : usb-storage 1-1.4:1.0
[299936.710000] scsi 1001:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[299936.720000] sd 1001:0:0:0: Attached scsi generic sg0 type 0
[299936.730000] sd 1001:0:0:0: [sda] Attached SCSI removable disk
[300266.700000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[300266.700000] scsi1002 : usb-storage 1-1.4:1.0
[300267.710000] scsi 1002:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[300267.720000] sd 1002:0:0:0: Attached scsi generic sg0 type 0
[300267.730000] sd 1002:0:0:0: [sda] Attached SCSI removable disk
[300593.710000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[300593.710000] scsi1003 : usb-storage 1-1.4:1.0
[300594.720000] scsi 1003:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[300594.730000] sd 1003:0:0:0: Attached scsi generic sg0 type 0
[300594.740000] sd 1003:0:0:0: [sda] Attached SCSI removable disk
[300896.740000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[300896.740000] scsi1004 : usb-storage 1-1.4:1.0
[300897.750000] scsi 1004:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[300897.760000] sd 1004:0:0:0: Attached scsi generic sg0 type 0
[300897.780000] sd 1004:0:0:0: [sda] Attached SCSI removable disk
[301118.730000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[301118.730000] scsi1005 : usb-storage 1-1.4:1.0
[301119.740000] scsi 1005:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[301119.750000] sd 1005:0:0:0: Attached scsi generic sg0 type 0
[301119.760000] sd 1005:0:0:0: [sda] Attached SCSI removable disk
[301493.710000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[301493.710000] scsi1006 : usb-storage 1-1.4:1.0
[301494.720000] scsi 1006:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[301494.730000] sd 1006:0:0:0: Attached scsi generic sg0 type 0
[301494.740000] sd 1006:0:0:0: [sda] Attached SCSI removable disk
[301733.770000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[301733.770000] scsi1007 : usb-storage 1-1.4:1.0
[301734.780000] scsi 1007:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[301734.790000] sd 1007:0:0:0: Attached scsi generic sg0 type 0
[301734.800000] sd 1007:0:0:0: [sda] Attached SCSI removable disk
[302050.780000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[302050.780000] scsi1008 : usb-storage 1-1.4:1.0
[302051.790000] scsi 1008:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[302051.810000] sd 1008:0:0:0: Attached scsi generic sg0 type 0
[302051.830000] sd 1008:0:0:0: [sda] Attached SCSI removable disk
[302366.790000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[302366.790000] scsi1009 : usb-storage 1-1.4:1.0
[302367.810000] scsi 1009:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[302367.820000] sd 1009:0:0:0: Attached scsi generic sg0 type 0
[302367.830000] sd 1009:0:0:0: [sda] Attached SCSI removable disk
[302680.800000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[302680.800000] scsi1010 : usb-storage 1-1.4:1.0
[302681.810000] scsi 1010:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[302681.820000] sd 1010:0:0:0: Attached scsi generic sg0 type 0
[302681.830000] sd 1010:0:0:0: [sda] Attached SCSI removable disk
[302930.870000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[302930.870000] scsi1011 : usb-storage 1-1.4:1.0
[302931.880000] scsi 1011:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[302931.890000] sd 1011:0:0:0: Attached scsi generic sg0 type 0
[302931.900000] sd 1011:0:0:0: [sda] Attached SCSI removable disk
[303210.980000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[303210.980000] scsi1012 : usb-storage 1-1.4:1.0
[303212.000000] scsi 1012:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[303212.020000] sd 1012:0:0:0: Attached scsi generic sg0 type 0
[303212.040000] sd 1012:0:0:0: [sda] Attached SCSI removable disk
WETRHE
Post by WETRHE »
[303520.880000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[303520.880000] scsi1013 : usb-storage 1-1.4:1.0
[303521.890000] scsi 1013:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[303521.900000] sd 1013:0:0:0: Attached scsi generic sg0 type 0
[303521.910000] sd 1013:0:0:0: [sda] Attached SCSI removable disk
[303879.950000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[303879.950000] scsi1014 : usb-storage 1-1.4:1.0
[303880.960000] scsi 1014:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[303880.970000] sd 1014:0:0:0: Attached scsi generic sg0 type 0
[303880.980000] sd 1014:0:0:0: [sda] Attached SCSI removable disk
[304179.930000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[304179.930000] scsi1015 : usb-storage 1-1.4:1.0
[304180.940000] scsi 1015:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[304180.950000] sd 1015:0:0:0: Attached scsi generic sg0 type 0
[304180.960000] sd 1015:0:0:0: [sda] Attached SCSI removable disk
[304466.970000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[304466.970000] scsi1016 : usb-storage 1-1.4:1.0
[304468.010000] scsi 1016:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[304468.020000] sd 1016:0:0:0: Attached scsi generic sg0 type 0
[304468.030000] sd 1016:0:0:0: [sda] Attached SCSI removable disk
[304748.990000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[304748.990000] scsi1017 : usb-storage 1-1.4:1.0
[304750.000000] scsi 1017:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[304750.010000] sd 1017:0:0:0: Attached scsi generic sg0 type 0
[304750.020000] sd 1017:0:0:0: [sda] Attached SCSI removable disk
[305108.010000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[305108.010000] scsi1018 : usb-storage 1-1.4:1.0
[305109.020000] scsi 1018:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[305109.030000] sd 1018:0:0:0: Attached scsi generic sg0 type 0
[305109.040000] sd 1018:0:0:0: [sda] Attached SCSI removable disk
[305386.040000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[305386.040000] scsi1019 : usb-storage 1-1.4:1.0
[305387.050000] scsi 1019:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[305387.060000] sd 1019:0:0:0: Attached scsi generic sg0 type 0
[305387.080000] sd 1019:0:0:0: [sda] Attached SCSI removable disk
[305650.080000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[305650.080000] scsi1020 : usb-storage 1-1.4:1.0
[305651.090000] scsi 1020:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[305651.100000] sd 1020:0:0:0: Attached scsi generic sg0 type 0
[305651.110000] sd 1020:0:0:0: [sda] Attached SCSI removable disk
[305980.030000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[305980.030000] scsi1021 : usb-storage 1-1.4:1.0
[305981.040000] scsi 1021:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[305981.050000] sd 1021:0:0:0: Attached scsi generic sg0 type 0
[305981.060000] sd 1021:0:0:0: [sda] Attached SCSI removable disk
[306257.010000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[306257.010000] scsi1022 : usb-storage 1-1.4:1.0
[306258.020000] scsi 1022:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[306258.030000] sd 1022:0:0:0: Attached scsi generic sg0 type 0
[306258.040000] sd 1022:0:0:0: [sda] Attached SCSI removable disk
[306569.050000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[306569.050000] scsi1023 : usb-storage 1-1.4:1.0
[306570.060000] scsi 1023:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[306570.070000] sd 1023:0:0:0: Attached scsi generic sg0 type 0
[306570.090000] sd 1023:0:0:0: [sda] Attached SCSI removable disk
[306836.080000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[306836.080000] scsi1024 : usb-storage 1-1.4:1.0
[306837.090000] scsi 1024:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[306837.100000] sd 1024:0:0:0: Attached scsi generic sg0 type 0
[306837.110000] sd 1024:0:0:0: [sda] Attached SCSI removable disk
[307190.090000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[307190.090000] scsi1025 : usb-storage 1-1.4:1.0
[307191.100000] scsi 1025:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[307191.110000] sd 1025:0:0:0: Attached scsi generic sg0 type 0
[307191.120000] sd 1025:0:0:0: [sda] Attached SCSI removable disk
[307464.160000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[307464.160000] scsi1026 : usb-storage 1-1.4:1.0
[307465.170000] scsi 1026:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[307465.180000] sd 1026:0:0:0: Attached scsi generic sg0 type 0
[307465.190000] sd 1026:0:0:0: [sda] Attached SCSI removable disk
[307789.150000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[307789.150000] scsi1027 : usb-storage 1-1.4:1.0
[307790.160000] scsi 1027:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[307790.170000] sd 1027:0:0:0: Attached scsi generic sg0 type 0
[307790.180000] sd 1027:0:0:0: [sda] Attached SCSI removable disk
[308032.200000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[308032.200000] scsi1028 : usb-storage 1-1.4:1.0
[308033.210000] scsi 1028:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[308033.220000] sd 1028:0:0:0: Attached scsi generic sg0 type 0
[308033.230000] sd 1028:0:0:0: [sda] Attached SCSI removable disk
[308379.180000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[308379.180000] scsi1029 : usb-storage 1-1.4:1.0
[308380.190000] scsi 1029:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[308380.200000] sd 1029:0:0:0: Attached scsi generic sg0 type 0
[308380.210000] sd 1029:0:0:0: [sda] Attached SCSI removable disk
[308639.180000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[308639.180000] scsi1030 : usb-storage 1-1.4:1.0
[308640.210000] scsi 1030:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[308640.220000] sd 1030:0:0:0: Attached scsi generic sg0 type 0
[308640.250000] sd 1030:0:0:0: [sda] Attached SCSI removable disk
[308964.230000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[308964.230000] scsi1031 : usb-storage 1-1.4:1.0
[308965.240000] scsi 1031:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[308965.250000] sd 1031:0:0:0: Attached scsi generic sg0 type 0
[308965.260000] sd 1031:0:0:0: [sda] Attached SCSI removable disk
[309304.260000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[309304.260000] scsi1032 : usb-storage 1-1.4:1.0
[309305.270000] scsi 1032:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[309305.280000] sd 1032:0:0:0: Attached scsi generic sg0 type 0
[309305.290000] sd 1032:0:0:0: [sda] Attached SCSI removable disk
[309556.300000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[309556.300000] scsi1033 : usb-storage 1-1.4:1.0
[309557.310000] scsi 1033:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[309557.320000] sd 1033:0:0:0: Attached scsi generic sg0 type 0
[309557.330000] sd 1033:0:0:0: [sda] Attached SCSI removable disk
[309855.290000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[309855.290000] scsi1034 : usb-storage 1-1.4:1.0
[309856.300000] scsi 1034:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[309856.310000] sd 1034:0:0:0: Attached scsi generic sg0 type 0
[309856.320000] sd 1034:0:0:0: [sda] Attached SCSI removable disk
[310130.320000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[310130.320000] scsi1035 : usb-storage 1-1.4:1.0
[310131.330000] scsi 1035:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[310131.340000] sd 1035:0:0:0: Attached scsi generic sg0 type 0
[310131.350000] sd 1035:0:0:0: [sda] Attached SCSI removable disk
[310492.300000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[310492.300000] scsi1036 : usb-storage 1-1.4:1.0
[310493.310000] scsi 1036:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[310493.320000] sd 1036:0:0:0: Attached scsi generic sg0 type 0
[310493.330000] sd 1036:0:0:0: [sda] Attached SCSI removable disk
[310756.250000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[310756.250000] scsi1037 : usb-storage 1-1.4:1.0
[310757.260000] scsi 1037:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[310757.270000] sd 1037:0:0:0: Attached scsi generic sg0 type 0
[310757.280000] sd 1037:0:0:0: [sda] Attached SCSI removable disk
[311102.530000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[311102.530000] scsi1038 : usb-storage 1-1.4:1.0
[311103.540000] scsi 1038:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[311103.550000] sd 1038:0:0:0: Attached scsi generic sg0 type 0
[311103.570000] sd 1038:0:0:0: [sda] Attached SCSI removable disk
[311402.470000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[311402.470000] scsi1039 : usb-storage 1-1.4:1.0
[311403.480000] scsi 1039:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[311403.490000] sd 1039:0:0:0: Attached scsi generic sg0 type 0
[311403.500000] sd 1039:0:0:0: [sda] Attached SCSI removable disk
[311643.560000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[311643.560000] scsi1040 : usb-storage 1-1.4:1.0
[311644.570000] scsi 1040:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[311644.580000] sd 1040:0:0:0: Attached scsi generic sg0 type 0
[311644.590000] sd 1040:0:0:0: [sda] Attached SCSI removable disk
[311959.500000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[311959.500000] scsi1041 : usb-storage 1-1.4:1.0
[311960.510000] scsi 1041:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[311960.520000] sd 1041:0:0:0: Attached scsi generic sg0 type 0
[311960.530000] sd 1041:0:0:0: [sda] Attached SCSI removable disk
[312218.490000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[312218.490000] scsi1042 : usb-storage 1-1.4:1.0
[312219.510000] scsi 1042:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[312219.520000] sd 1042:0:0:0: Attached scsi generic sg0 type 0
[312219.530000] sd 1042:0:0:0: [sda] Attached SCSI removable disk
[312510.720000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[312510.720000] scsi1043 : usb-storage 1-1.4:1.0
[312511.750000] scsi 1043:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[312511.760000] sd 1043:0:0:0: Attached scsi generic sg0 type 0
[312511.770000] sd 1043:0:0:0: [sda] Attached SCSI removable disk
[312882.390000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[312882.390000] scsi1044 : usb-storage 1-1.4:1.0
[312883.400000] scsi 1044:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[312883.410000] sd 1044:0:0:0: Attached scsi generic sg0 type 0
[312883.420000] sd 1044:0:0:0: [sda] Attached SCSI removable disk
[313139.480000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[313139.480000] scsi1045 : usb-storage 1-1.4:1.0
[313140.490000] scsi 1045:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[313140.500000] sd 1045:0:0:0: Attached scsi generic sg0 type 0
[313140.510000] sd 1045:0:0:0: [sda] Attached SCSI removable disk
[313442.480000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[313442.480000] scsi1046 : usb-storage 1-1.4:1.0
[313443.490000] scsi 1046:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[313443.500000] sd 1046:0:0:0: Attached scsi generic sg0 type 0
[313443.510000] sd 1046:0:0:0: [sda] Attached SCSI removable disk
[313710.680000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[313710.680000] scsi1047 : usb-storage 1-1.4:1.0
[313711.690000] scsi 1047:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[313711.700000] sd 1047:0:0:0: Attached scsi generic sg0 type 0
[313711.710000] sd 1047:0:0:0: [sda] Attached SCSI removable disk
[314041.530000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[314041.530000] scsi1048 : usb-storage 1-1.4:1.0
[314042.540000] scsi 1048:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[314042.550000] sd 1048:0:0:0: Attached scsi generic sg0 type 0
[314042.560000] sd 1048:0:0:0: [sda] Attached SCSI removable disk
[314313.620000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[314313.620000] scsi1049 : usb-storage 1-1.4:1.0
[314314.630000] scsi 1049:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[314314.640000] sd 1049:0:0:0: Attached scsi generic sg0 type 0
[314314.650000] sd 1049:0:0:0: [sda] Attached SCSI removable disk
[314660.640000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[314660.640000] scsi1050 : usb-storage 1-1.4:1.0
[314661.650000] scsi 1050:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[314661.660000] sd 1050:0:0:0: Attached scsi generic sg0 type 0
[314661.680000] sd 1050:0:0:0: [sda] Attached SCSI removable disk
[314978.550000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[314978.560000] scsi1051 : usb-storage 1-1.4:1.0
[314979.560000] scsi 1051:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[314979.570000] sd 1051:0:0:0: Attached scsi generic sg0 type 0
[314979.580000] sd 1051:0:0:0: [sda] Attached SCSI removable disk
[315290.590000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[315290.590000] scsi1052 : usb-storage 1-1.4:1.0
[315291.600000] scsi 1052:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[315291.610000] sd 1052:0:0:0: Attached scsi generic sg0 type 0
[315291.620000] sd 1052:0:0:0: [sda] Attached SCSI removable disk
[315583.640000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[315583.640000] scsi1053 : usb-storage 1-1.4:1.0
[315584.650000] scsi 1053:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[315584.660000] sd 1053:0:0:0: Attached scsi generic sg0 type 0
[315584.670000] sd 1053:0:0:0: [sda] Attached SCSI removable disk
[315830.570000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[315830.580000] scsi1054 : usb-storage 1-1.4:1.0
[315831.580000] scsi 1054:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[315831.590000] sd 1054:0:0:0: Attached scsi generic sg0 type 0
[315831.600000] sd 1054:0:0:0: [sda] Attached SCSI removable disk
[316198.640000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[316198.640000] scsi1055 : usb-storage 1-1.4:1.0
[316199.650000] scsi 1055:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[316199.660000] sd 1055:0:0:0: Attached scsi generic sg0 type 0
[316199.670000] sd 1055:0:0:0: [sda] Attached SCSI removable disk
[316409.680000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[316409.680000] scsi1056 : usb-storage 1-1.4:1.0
[316410.690000] scsi 1056:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[316410.700000] sd 1056:0:0:0: Attached scsi generic sg0 type 0
[316410.730000] sd 1056:0:0:0: [sda] Attached SCSI removable disk
[316741.700000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[316741.700000] scsi1057 : usb-storage 1-1.4:1.0
[316742.710000] scsi 1057:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[316742.720000] sd 1057:0:0:0: Attached scsi generic sg0 type 0
[316742.730000] sd 1057:0:0:0: [sda] Attached SCSI removable disk
[317098.670000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[317098.670000] scsi1058 : usb-storage 1-1.4:1.0
[317099.680000] scsi 1058:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[317099.690000] sd 1058:0:0:0: Attached scsi generic sg0 type 0
[317099.700000] sd 1058:0:0:0: [sda] Attached SCSI removable disk
[317369.720000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[317369.720000] scsi1059 : usb-storage 1-1.4:1.0
[317370.730000] scsi 1059:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[317370.740000] sd 1059:0:0:0: Attached scsi generic sg0 type 0
[317370.750000] sd 1059:0:0:0: [sda] Attached SCSI removable disk
[317644.750000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[317644.750000] scsi1060 : usb-storage 1-1.4:1.0
[317645.770000] scsi 1060:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[317645.780000] sd 1060:0:0:0: Attached scsi generic sg0 type 0
[317645.790000] sd 1060:0:0:0: [sda] Attached SCSI removable disk
[317948.640000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[317948.640000] scsi1061 : usb-storage 1-1.4:1.0
[317949.650000] scsi 1061:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[317949.660000] sd 1061:0:0:0: Attached scsi generic sg0 type 0
[317949.680000] sd 1061:0:0:0: [sda] Attached SCSI removable disk
[318212.900000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[318212.910000] scsi1062 : usb-storage 1-1.4:1.0
[318213.910000] scsi 1062:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[318213.920000] sd 1062:0:0:0: Attached scsi generic sg0 type 0
[318213.930000] sd 1062:0:0:0: [sda] Attached SCSI removable disk
[318589.780000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[318589.780000] scsi1063 : usb-storage 1-1.4:1.0
[318590.790000] scsi 1063:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[318590.800000] sd 1063:0:0:0: Attached scsi generic sg0 type 0
[318590.810000] sd 1063:0:0:0: [sda] Attached SCSI removable disk
[318905.700000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[318905.700000] scsi1064 : usb-storage 1-1.4:1.0
[318906.710000] scsi 1064:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[318906.720000] sd 1064:0:0:0: Attached scsi generic sg0 type 0
[318906.740000] sd 1064:0:0:0: [sda] Attached SCSI removable disk
[319122.830000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[319122.830000] scsi1065 : usb-storage 1-1.4:1.0
[319123.840000] scsi 1065:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[319123.850000] sd 1065:0:0:0: Attached scsi generic sg0 type 0
[319123.860000] sd 1065:0:0:0: [sda] Attached SCSI removable disk
[319425.770000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[319425.770000] scsi1066 : usb-storage 1-1.4:1.0
[319426.780000] scsi 1066:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[319426.790000] sd 1066:0:0:0: Attached scsi generic sg0 type 0
[319426.810000] sd 1066:0:0:0: [sda] Attached SCSI removable disk
[319768.850000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[319768.860000] scsi1067 : usb-storage 1-1.4:1.0
[319769.860000] scsi 1067:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[319769.870000] sd 1067:0:0:0: Attached scsi generic sg0 type 0
[319769.880000] sd 1067:0:0:0: [sda] Attached SCSI removable disk
[320049.860000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[320049.860000] scsi1068 : usb-storage 1-1.4:1.0
[320050.870000] scsi 1068:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[320050.880000] sd 1068:0:0:0: Attached scsi generic sg0 type 0
[320050.890000] sd 1068:0:0:0: [sda] Attached SCSI removable disk
[320353.830000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[320353.830000] scsi1069 : usb-storage 1-1.4:1.0
[320354.840000] scsi 1069:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[320354.850000] sd 1069:0:0:0: Attached scsi generic sg0 type 0
[320354.870000] sd 1069:0:0:0: [sda] Attached SCSI removable disk
[320613.010000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[320613.010000] scsi1070 : usb-storage 1-1.4:1.0
[320614.060000] scsi 1070:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[320614.090000] sd 1070:0:0:0: Attached scsi generic sg0 type 0
[320614.100000] sd 1070:0:0:0: [sda] Attached SCSI removable disk
[320938.910000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[320938.910000] scsi1071 : usb-storage 1-1.4:1.0
[320939.930000] scsi 1071:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[320939.940000] sd 1071:0:0:0: Attached scsi generic sg0 type 0
[320939.960000] sd 1071:0:0:0: [sda] Attached SCSI removable disk
[321253.910000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[321253.910000] scsi1072 : usb-storage 1-1.4:1.0
[321254.920000] scsi 1072:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[321254.930000] sd 1072:0:0:0: Attached scsi generic sg0 type 0
[321254.940000] sd 1072:0:0:0: [sda] Attached SCSI removable disk
[321569.830000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[321569.830000] scsi1073 : usb-storage 1-1.4:1.0
[321570.840000] scsi 1073:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[321570.850000] sd 1073:0:0:0: Attached scsi generic sg0 type 0
[321570.860000] sd 1073:0:0:0: [sda] Attached SCSI removable disk
[321872.850000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[321872.850000] scsi1074 : usb-storage 1-1.4:1.0
[321873.860000] scsi 1074:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[321873.870000] sd 1074:0:0:0: Attached scsi generic sg0 type 0
[321873.890000] sd 1074:0:0:0: [sda] Attached SCSI removable disk
[322201.860000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[322201.860000] scsi1075 : usb-storage 1-1.4:1.0
[322202.870000] scsi 1075:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[322202.880000] sd 1075:0:0:0: Attached scsi generic sg0 type 0
[322202.890000] sd 1075:0:0:0: [sda] Attached SCSI removable disk
[322458.860000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[322458.860000] scsi1076 : usb-storage 1-1.4:1.0
[322459.870000] scsi 1076:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[322459.880000] sd 1076:0:0:0: Attached scsi generic sg0 type 0
[322459.890000] sd 1076:0:0:0: [sda] Attached SCSI removable disk
[322800.910000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[322800.910000] scsi1077 : usb-storage 1-1.4:1.0
[322801.920000] scsi 1077:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[322801.930000] sd 1077:0:0:0: Attached scsi generic sg0 type 0
[322801.940000] sd 1077:0:0:0: [sda] Attached SCSI removable disk
[323088.890000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[323088.890000] scsi1078 : usb-storage 1-1.4:1.0
[323089.900000] scsi 1078:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[323089.910000] sd 1078:0:0:0: Attached scsi generic sg0 type 0
[323089.920000] sd 1078:0:0:0: [sda] Attached SCSI removable disk
[323397.900000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[323397.900000] scsi1079 : usb-storage 1-1.4:1.0
[323398.910000] scsi 1079:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[323398.920000] sd 1079:0:0:0: Attached scsi generic sg0 type 0
[323398.930000] sd 1079:0:0:0: [sda] Attached SCSI removable disk
[323676.990000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[323676.990000] scsi1080 : usb-storage 1-1.4:1.0
[323678.000000] scsi 1080:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[323678.010000] sd 1080:0:0:0: Attached scsi generic sg0 type 0
[323678.020000] sd 1080:0:0:0: [sda] Attached SCSI removable disk
[323973.950000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[323973.950000] scsi1081 : usb-storage 1-1.4:1.0
[323974.960000] scsi 1081:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[323974.970000] sd 1081:0:0:0: Attached scsi generic sg0 type 0
[323974.980000] sd 1081:0:0:0: [sda] Attached SCSI removable disk
[324217.960000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[324217.960000] scsi1082 : usb-storage 1-1.4:1.0
[324218.970000] scsi 1082:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[324218.980000] sd 1082:0:0:0: Attached scsi generic sg0 type 0
[324218.990000] sd 1082:0:0:0: [sda] Attached SCSI removable disk
[324571.990000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[324571.990000] scsi1083 : usb-storage 1-1.4:1.0
[324573.000000] scsi 1083:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[324573.010000] sd 1083:0:0:0: Attached scsi generic sg0 type 0
[324573.030000] sd 1083:0:0:0: [sda] Attached SCSI removable disk
[324813.960000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[324813.960000] scsi1084 : usb-storage 1-1.4:1.0
[324814.970000] scsi 1084:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[324814.980000] sd 1084:0:0:0: Attached scsi generic sg0 type 0
[324814.990000] sd 1084:0:0:0: [sda] Attached SCSI removable disk
[325170.970000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[325170.970000] scsi1085 : usb-storage 1-1.4:1.0
[325171.980000] scsi 1085:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[325171.990000] sd 1085:0:0:0: Attached scsi generic sg0 type 0
[325172.000000] sd 1085:0:0:0: [sda] Attached SCSI removable disk
[325503.990000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[325503.990000] scsi1086 : usb-storage 1-1.4:1.0
[325505.000000] scsi 1086:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[325505.010000] sd 1086:0:0:0: Attached scsi generic sg0 type 0
[325505.020000] sd 1086:0:0:0: [sda] Attached SCSI removable disk
[325717.000000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[325717.000000] scsi1087 : usb-storage 1-1.4:1.0
[325718.010000] scsi 1087:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[325718.020000] sd 1087:0:0:0: Attached scsi generic sg0 type 0
[325718.030000] sd 1087:0:0:0: [sda] Attached SCSI removable disk
[326024.100000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[326024.100000] scsi1088 : usb-storage 1-1.4:1.0
[326025.120000] scsi 1088:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[326025.130000] sd 1088:0:0:0: Attached scsi generic sg0 type 0
[326025.150000] sd 1088:0:0:0: [sda] Attached SCSI removable disk
[326342.010000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[326342.010000] scsi1089 : usb-storage 1-1.4:1.0
[326343.020000] scsi 1089:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[326343.030000] sd 1089:0:0:0: Attached scsi generic sg0 type 0
[326343.040000] sd 1089:0:0:0: [sda] Attached SCSI removable disk
[326616.020000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[326616.020000] scsi1090 : usb-storage 1-1.4:1.0
[326617.030000] scsi 1090:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[326617.040000] sd 1090:0:0:0: Attached scsi generic sg0 type 0
[326617.050000] sd 1090:0:0:0: [sda] Attached SCSI removable disk
[326957.990000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[326957.990000] scsi1091 : usb-storage 1-1.4:1.0
[326959.000000] scsi 1091:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[326959.010000] sd 1091:0:0:0: Attached scsi generic sg0 type 0
[326959.020000] sd 1091:0:0:0: [sda] Attached SCSI removable disk
[327251.030000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[327251.030000] scsi1092 : usb-storage 1-1.4:1.0
[327252.040000] scsi 1092:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[327252.050000] sd 1092:0:0:0: Attached scsi generic sg0 type 0
[327252.060000] sd 1092:0:0:0: [sda] Attached SCSI removable disk
[327510.000000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[327510.000000] scsi1093 : usb-storage 1-1.4:1.0
[327511.010000] scsi 1093:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[327511.020000] sd 1093:0:0:0: Attached scsi generic sg0 type 0
[327511.030000] sd 1093:0:0:0: [sda] Attached SCSI removable disk
[327902.030000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[327902.030000] scsi1094 : usb-storage 1-1.4:1.0
[327903.040000] scsi 1094:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[327903.050000] sd 1094:0:0:0: Attached scsi generic sg0 type 0
[327903.060000] sd 1094:0:0:0: [sda] Attached SCSI removable disk
[328131.050000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[328131.050000] scsi1095 : usb-storage 1-1.4:1.0
[328132.060000] scsi 1095:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[328132.070000] sd 1095:0:0:0: Attached scsi generic sg0 type 0
[328132.080000] sd 1095:0:0:0: [sda] Attached SCSI removable disk
[328477.110000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[328477.110000] scsi1096 : usb-storage 1-1.4:1.0
[328478.120000] scsi 1096:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[328478.130000] sd 1096:0:0:0: Attached scsi generic sg0 type 0
[328478.140000] sd 1096:0:0:0: [sda] Attached SCSI removable disk
[328749.050000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[328749.050000] scsi1097 : usb-storage 1-1.4:1.0
[328750.060000] scsi 1097:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[328750.070000] sd 1097:0:0:0: Attached scsi generic sg0 type 0
[328750.080000] sd 1097:0:0:0: [sda] Attached SCSI removable disk
[329054.130000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[329054.130000] scsi1098 : usb-storage 1-1.4:1.0
[329055.140000] scsi 1098:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[329055.150000] sd 1098:0:0:0: Attached scsi generic sg0 type 0
[329055.160000] sd 1098:0:0:0: [sda] Attached SCSI removable disk
[329327.070000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[329327.070000] scsi1099 : usb-storage 1-1.4:1.0
[329328.080000] scsi 1099:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[329328.090000] sd 1099:0:0:0: Attached scsi generic sg0 type 0
[329328.100000] sd 1099:0:0:0: [sda] Attached SCSI removable disk
[329687.080000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[329687.080000] scsi1100 : usb-storage 1-1.4:1.0
[329688.090000] scsi 1100:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[329688.100000] sd 1100:0:0:0: Attached scsi generic sg0 type 0
[329688.110000] sd 1100:0:0:0: [sda] Attached SCSI removable disk
[329962.120000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[329962.120000] scsi1101 : usb-storage 1-1.4:1.0
[329963.130000] scsi 1101:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[329963.140000] sd 1101:0:0:0: Attached scsi generic sg0 type 0
[329963.150000] sd 1101:0:0:0: [sda] Attached SCSI removable disk
[330293.090000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[330293.090000] scsi1102 : usb-storage 1-1.4:1.0
[330294.100000] scsi 1102:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[330294.110000] sd 1102:0:0:0: Attached scsi generic sg0 type 0
[330294.120000] sd 1102:0:0:0: [sda] Attached SCSI removable disk
[330587.120000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[330587.120000] scsi1103 : usb-storage 1-1.4:1.0
[330588.130000] scsi 1103:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[330588.140000] sd 1103:0:0:0: Attached scsi generic sg0 type 0
[330588.150000] sd 1103:0:0:0: [sda] Attached SCSI removable disk
[330842.120000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[330842.120000] scsi1104 : usb-storage 1-1.4:1.0
[330843.130000] scsi 1104:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[330843.140000] sd 1104:0:0:0: Attached scsi generic sg0 type 0
[330843.150000] sd 1104:0:0:0: [sda] Attached SCSI removable disk
[331197.200000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[331197.200000] scsi1105 : usb-storage 1-1.4:1.0
[331198.210000] scsi 1105:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[331198.220000] sd 1105:0:0:0: Attached scsi generic sg0 type 0
[331198.240000] sd 1105:0:0:0: [sda] Attached SCSI removable disk
[331497.330000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[331497.330000] scsi1106 : usb-storage 1-1.4:1.0
[331498.350000] scsi 1106:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[331498.360000] sd 1106:0:0:0: Attached scsi generic sg0 type 0
[331498.370000] sd 1106:0:0:0: [sda] Attached SCSI removable disk
[331745.140000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[331745.140000] scsi1107 : usb-storage 1-1.4:1.0
[331746.150000] scsi 1107:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[331746.160000] sd 1107:0:0:0: Attached scsi generic sg0 type 0
[331746.170000] sd 1107:0:0:0: [sda] Attached SCSI removable disk
[332056.130000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[332056.130000] scsi1108 : usb-storage 1-1.4:1.0
[332057.140000] scsi 1108:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[332057.150000] sd 1108:0:0:0: Attached scsi generic sg0 type 0
[332057.160000] sd 1108:0:0:0: [sda] Attached SCSI removable disk
[332333.150000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[332333.150000] scsi1109 : usb-storage 1-1.4:1.0
[332334.160000] scsi 1109:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[332334.170000] sd 1109:0:0:0: Attached scsi generic sg0 type 0
[332334.180000] sd 1109:0:0:0: [sda] Attached SCSI removable disk
[332692.170000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[332692.170000] scsi1110 : usb-storage 1-1.4:1.0
[332693.180000] scsi 1110:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[332693.190000] sd 1110:0:0:0: Attached scsi generic sg0 type 0
[332693.200000] sd 1110:0:0:0: [sda] Attached SCSI removable disk
[332959.190000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[332959.190000] scsi1111 : usb-storage 1-1.4:1.0
[332960.200000] scsi 1111:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[332960.210000] sd 1111:0:0:0: Attached scsi generic sg0 type 0
[332960.220000] sd 1111:0:0:0: [sda] Attached SCSI removable disk
[333300.170000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[333300.170000] scsi1112 : usb-storage 1-1.4:1.0
[333301.180000] scsi 1112:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[333301.190000] sd 1112:0:0:0: Attached scsi generic sg0 type 0
[333301.200000] sd 1112:0:0:0: [sda] Attached SCSI removable disk
[333591.190000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[333591.190000] scsi1113 : usb-storage 1-1.4:1.0
[333592.200000] scsi 1113:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[333592.210000] sd 1113:0:0:0: Attached scsi generic sg0 type 0
[333592.220000] sd 1113:0:0:0: [sda] Attached SCSI removable disk
[333844.220000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[333844.220000] scsi1114 : usb-storage 1-1.4:1.0
[333845.230000] scsi 1114:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[333845.240000] sd 1114:0:0:0: Attached scsi generic sg0 type 0
[333845.250000] sd 1114:0:0:0: [sda] Attached SCSI removable disk
[334166.420000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[334166.420000] scsi1115 : usb-storage 1-1.4:1.0
[334167.430000] scsi 1115:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[334167.440000] sd 1115:0:0:0: Attached scsi generic sg0 type 0
[334167.460000] sd 1115:0:0:0: [sda] Attached SCSI removable disk
[334481.360000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[334481.370000] scsi1116 : usb-storage 1-1.4:1.0
[334482.370000] scsi 1116:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[334482.400000] sd 1116:0:0:0: Attached scsi generic sg0 type 0
[334482.400000] sd 1116:0:0:0: [sda] Attached SCSI removable disk
[334795.350000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[334795.350000] scsi1117 : usb-storage 1-1.4:1.0
[334796.380000] scsi 1117:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[334796.410000] sd 1117:0:0:0: [sda] Attached SCSI removable disk
[334796.430000] sd 1117:0:0:0: Attached scsi generic sg0 type 0
[335036.440000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[335036.440000] scsi1118 : usb-storage 1-1.4:1.0
[335037.460000] scsi 1118:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[335037.470000] sd 1118:0:0:0: Attached scsi generic sg0 type 0
[335037.500000] sd 1118:0:0:0: [sda] Attached SCSI removable disk
[335327.420000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[335327.440000] scsi1119 : usb-storage 1-1.4:1.0
[335328.440000] scsi 1119:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[335328.450000] sd 1119:0:0:0: Attached scsi generic sg0 type 0
[335328.460000] sd 1119:0:0:0: [sda] Attached SCSI removable disk
[335679.450000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[335679.450000] scsi1120 : usb-storage 1-1.4:1.0
[335680.460000] scsi 1120:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[335680.480000] sd 1120:0:0:0: Attached scsi generic sg0 type 0
[335680.490000] sd 1120:0:0:0: [sda] Attached SCSI removable disk
[335995.420000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[335995.420000] scsi1121 : usb-storage 1-1.4:1.0
[335996.430000] scsi 1121:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[335996.440000] sd 1121:0:0:0: Attached scsi generic sg0 type 0
[335996.460000] sd 1121:0:0:0: [sda] Attached SCSI removable disk
[336250.680000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[336250.680000] scsi1122 : usb-storage 1-1.4:1.0
[336251.690000] scsi 1122:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[336251.700000] sd 1122:0:0:0: Attached scsi generic sg0 type 0
[336251.710000] sd 1122:0:0:0: [sda] Attached SCSI removable disk
[336573.720000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[336573.720000] scsi1123 : usb-storage 1-1.4:1.0
[336574.730000] scsi 1123:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[336574.740000] sd 1123:0:0:0: Attached scsi generic sg0 type 0
[336574.750000] sd 1123:0:0:0: [sda] Attached SCSI removable disk
[336825.450000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[336825.450000] scsi1124 : usb-storage 1-1.4:1.0
[336826.460000] scsi 1124:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[336826.470000] sd 1124:0:0:0: Attached scsi generic sg0 type 0
[336826.480000] sd 1124:0:0:0: [sda] Attached SCSI removable disk
[337132.490000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[337132.490000] scsi1125 : usb-storage 1-1.4:1.0
[337133.510000] scsi 1125:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[337133.550000] sd 1125:0:0:0: Attached scsi generic sg0 type 0
[337133.550000] sd 1125:0:0:0: [sda] Attached SCSI removable disk
[337444.520000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[337444.520000] scsi1126 : usb-storage 1-1.4:1.0
[337445.530000] scsi 1126:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[337445.540000] sd 1126:0:0:0: Attached scsi generic sg0 type 0
[337445.560000] sd 1126:0:0:0: [sda] Attached SCSI removable disk
[337714.710000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[337714.710000] scsi1127 : usb-storage 1-1.4:1.0
[337715.720000] scsi 1127:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[337715.760000] sd 1127:0:0:0: [sda] Attached SCSI removable disk
[337715.770000] sd 1127:0:0:0: Attached scsi generic sg0 type 0
[338041.750000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[338041.750000] scsi1128 : usb-storage 1-1.4:1.0
[338042.760000] scsi 1128:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[338042.800000] sd 1128:0:0:0: Attached scsi generic sg0 type 0
[338042.800000] sd 1128:0:0:0: [sda] Attached SCSI removable disk
[338317.660000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[338317.660000] scsi1129 : usb-storage 1-1.4:1.0
[338318.670000] scsi 1129:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[338318.680000] sd 1129:0:0:0: Attached scsi generic sg0 type 0
[338318.690000] sd 1129:0:0:0: [sda] Attached SCSI removable disk
[338663.010000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[338663.010000] scsi1130 : usb-storage 1-1.4:1.0
[338664.020000] scsi 1130:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[338664.030000] sd 1130:0:0:0: Attached scsi generic sg0 type 0
[338664.060000] sd 1130:0:0:0: [sda] Attached SCSI removable disk
[338989.710000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[338989.720000] scsi1131 : usb-storage 1-1.4:1.0
[338990.720000] scsi 1131:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[338990.730000] sd 1131:0:0:0: Attached scsi generic sg0 type 0
[338990.740000] sd 1131:0:0:0: [sda] Attached SCSI removable disk
[339221.640000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[339221.640000] scsi1132 : usb-storage 1-1.4:1.0
[339222.650000] scsi 1132:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[339222.660000] sd 1132:0:0:0: Attached scsi generic sg0 type 0
[339222.670000] sd 1132:0:0:0: [sda] Attached SCSI removable disk
[339528.750000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[339528.750000] scsi1133 : usb-storage 1-1.4:1.0
[339529.760000] scsi 1133:0:0:0: Direct-Access ChipsBnk Flash Disk 5.00 PQ: 0 ANSI: 2
[339529.780000] sd 1133:0:0:0: Attached scsi generic sg0 type 0
[339529.780000] sd 1133:0:0:0: [sda] Attached SCSI removable disk
Re: Meteobridge Pro - Missing folders after reboot
Your storage ist defective. Are you operating with the internal USB stick of the MB PRO?
What does "lsusb -v" report?
WETRHE
Post by WETRHE »
Yes, it is an internal USB Stick abd it has already been exchanged as the other one was defective.
But same issue with the other USB stick before.
root@MeteoBridge:~# lsusb -v
lsusb: cannot open "/usr/share/usb.ids", No such file or directory
Bus 001 Device 002: ID 1a40:0101
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9
bDeviceSubClass 0
bDeviceProtocol 1
bMaxPacketSize0 64
idVendor 0x1a40
idProduct 0x0101
bcdDevice 1.11
iManufacturer 0
iProduct 1 USB 2.0 Hub
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 4
wHubCharacteristic 0x0000
Ganged power switching
Ganged overcurrent protection
TT think time 8 FS bits
bPwrOn2PwrGood 50 * 2 milli seconds
bHubContrCurrent 100 milli Ampere
DeviceRemovable 0x00
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0103 power enable connect
Port 2: 0000.0100 power
Port 3: 0000.0103 power enable connect
Port 4: 0000.0503 highspeed power enable connect
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 9
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
Device Status: 0x0001
Self Powered
Bus 001 Device 001: ID 1d6b:0002
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9
bDeviceSubClass 0
bDeviceProtocol 1
bMaxPacketSize0 64
idVendor 0x1d6b
idProduct 0x0002
bcdDevice 3.10
iManufacturer 3 Linux 3.10.49 ehci_hcd
iProduct 2 EHCI Host Controller
iSerial 1 ehci-platform
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
wHubCharacteristic 0x0009
Per-port power switching
Per-port overcurrent protection
bPwrOn2PwrGood 10 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
Hub Port Status:
Port 1: 0000.0503 highspeed power enable connect
Self Powered
Bus 001 Device 003: ID 10c4:ea60
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x10c4
idProduct 0xea60
bcdDevice 1.00
iManufacturer 1 Silicon Labs
iProduct 2 CP2102 USB to UART Bridge Controller
iSerial 3 0001
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255
iInterface 2 CP2102 USB to UART Bridge Controller
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Status: 0x0000
(Bus Powered)
Bus 001 Device 004: ID 0403:6001
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x0403
idProduct 0x6001
bcdDevice 6.00
iManufacturer 1 FTDI
iProduct 2 FT232R USB UART
iSerial 3 AL05ZEO2
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 90mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255
bInterfaceSubClass 255
bInterfaceProtocol 255
iInterface 2 FT232R USB UART
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
(Bus Powered)
Bus 001 Device 005: ID 1e3d:198a
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x1e3d
idProduct 0x198a
bcdDevice 1.00
iManufacturer 0
iProduct 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8
bInterfaceSubClass 6
bInterfaceProtocol 80
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
(Bus Powered)
root@MeteoBridge:~#
I see the internal RF module, a Davis USB logger and a consumer USB stick (1e3d:198a) connected via USB.
Consumer sticks will not work reliable. SLC USB sticks as the one from ATP which was in the PRO when being delivered are to be used.
WETRHE
Post by WETRHE »
The original SLC USB stick (as the one from ATP) has been crashing twice so I decided to try and use this USB stick.
So you mean, if I again put in a SLC USB stick that automatically all folders are being written again? I slightly doubt this but I would give it a try.
Can you pls tell me where to get a SLC USB stick as the one from ATP?
Thx & best regards
Please send me your address, I have the ATP ones in stock.
WETRHE
Re: Meteobridge Pro - Missing folders after reboot. **solved**
Post by WETRHE »
admin wrote: Sat Dec 16, 2023 2:16 pm Please send me your address, I have the ATP ones in stock.
That sounds good. How can I send you a pn for address details?
WETRHE wrote: Thu Feb 01, 2024 10:36 am
info(at)meteobridge.com
