woolfg
Post by woolfg »
Hi Brian
Thank you so much for looking
Yes it looks like it might be dead
A good project for between Xmas and New Year to fit a new one
Have a great Xmas and 2024
Warm wishes
Graham
no problem Graham..
SIMPLE UPDATE https://www.mediafire.com/file/zw8sohga ... 2.zip/file
Weather34-simple-update-2024-R2.zip contains all the updates for year change over in charts ,updated forecast module,updated purple air module plus minor fixes
if you discover any problems, issues, anomalies ,dislikes drop em here in this thread please don't email its not monitored regularly..I'll be back sometime in 2024 preoccupied with this over energised cat we adopted from the streets a few months ago :D
.. happy Christmas and new year to all. Brian
alexeysailman
Post by alexeysailman »
Hi, Brian! I found such a thing: in the mobile and browser versions, there is a narrow strip on the left in Microsoft EDGE. I know you have a MAC. Please take a look.
2023-12-24 06-17-25.JPG (235.83 KiB) Viewed 397839 times
alexeysailman
:D
@Brian: Thanks or your great ongoing support and Happy Xmas to You and Your family!
I wish all Weather34 and Meteobridge users and developers a Merry CHRISTMAS AND A HAPPY HOLIDAY.
Thank you for your support over the last years.
meteolive57290
Post by meteolive57290 »
hello all
http://valdefench57sgz.franceserv.com/p ... hboard.php
with an MB Pro device
PurpleAir sensor in service
i have the API key okay
but after configuring my /console-setup.php with the ID_sensor and API references
the block is not up to date like the corresponding almanac :(-
ps/ do I have to configure my MB with the PAII as an additional station by chance like I did with my AirLink ?
thnx and Regards
Capture d'écran 2023-12-27 124342.png (73.6 KiB) Viewed 397756 times
meteolive57290 wrote: Wed Dec 27, 2023 1:54 pm hello all
thnx and Regards
GOOD MORNING ..
Purple Air data comes from the Purple Air API from their site/hosting.. double check the API key for no hidden blank spaces on the end(often occurs when cut and paste long data because their blank whitespaces their not visible ..), double check the sensor ID number .. look for the file purpleair.txt (check permission on file is writable) in the jsondata folder that is where the data stored on your server.
http://valdefench57sgz.franceserv.com/p ... pleair.txt is blank currently
brian
part two mid to end of January ..adds day charts to modules..
meteolive57290
weatherist34 wrote: Thu Dec 28, 2023 8:51 am Purple Air data comes from the Purple Air API from their site/hosting.. double check the API key for no hidden blank spaces on the end(often occurs when cut and paste long data because their blank whitespaces their not visible ..), double check the sensor ID number .. look for the file purpleair.txt (check permission on file is writable) in the jsondata folder that is where the data stored on your server.
hello Brian thank you for your feedback
the ID of the sensor is correct the key supplied at the beginning of 2023 registered (correctly ?) in the original format type
"43Bxxxxx-9Bxx-11xx-B6xx-4201xxxxxx07"
so spaced !
for the file I also didn't modify anything but i just noticed that the Json is indeed "empty" :?:
Have a good day
Capture d'écran 2023-12-28 092343.png (11.61 KiB) Viewed 397703 times
Capture d'écran 2023-12-28 092302.png (16.37 KiB) Viewed 397703 times
Didi
Post by Didi »
Hello everyone. Excuse my English but I use Google Translate from French.
I have a very basic question but unfortunately I don't know the answer.
I have been using Weather34 for several years but I no longer remember how to display the graphs. For today's chart I put a cron job in meteobridge using the chartstoday.php file. But I can't figure out how to do the other graphs (month and year). If you have any idea on this thank you.
Didi
Post by Didi »
I have the same kind of problem. Don't you think it's because the Purpleair API is now paid? => https://community.purpleair.com/t/api-pricing/4523
meteolive57290
Didi wrote: Thu Dec 28, 2023 12:15 pm Hello everyone. Excuse my English but I use Google Translate from French.
:D salut je te répond en français :D
si tu ne l'as pas déjà fait dans ton MB >Services Settings tu dois aussi configurer une tâche HTTP at 02:00 avec l'URL correspondante :
....pws/weather34-chart-end-of-day.php
bonne continuation
i have used the ID 47165 and run the stationcron.php . can only say delete the purpleair.txt file and run the stationcron.php manually through your browser your-domain/pws/mbdbfiles/stationcron.php.
double check that API key also ..
i do not have a paid subscription i use the original API key from years ago..
it returned valid data as shown below timestamp converted GMT: Thursday, 28 December 2023 11:10:06
  "api_version" : "V1.0.11-0.0.49",
  "time_stamp" : 1703761806,
  "data_time_stamp" : 1703761769,
  "sensor" : {
    "sensor_index" : 47165,
    "last_modified" : 1612601115,
    "date_created" : 1580166309,
    "last_seen" : 1703761717,
    "private" : 0,
    "is_owner" : 0,
    "name" : "Valdefensch57@Meteolive OUTSIDE",
    "icon" : 0,
    "location_type" : 0,
    "model" : "PA-II",
    "hardware" : "2.0+BME280+PMSX003-B+PMSX003-A",
    "led_brightness" : 35,
    "firmware_version" : "7.02",
    "rssi" : -59,
    "uptime" : 12198,
    "pa_latency" : 365,
    "memory" : 16080,
    "position_rating" : 5,
    "latitude" : 49.31634,
    "longitude" : 6.092432,
    "altitude" : 674,
    "channel_state" : 3,
    "channel_flags" : 0,
    "channel_flags_manual" : 0,
    "channel_flags_auto" : 0,
    "confidence" : 100,
    "confidence_auto" : 100,
    "confidence_manual" : 100,
    "humidity" : 55,
    "humidity_a" : 55,
    "temperature" : 58,
    "temperature_a" : 58,
    "pressure" : 995.15,
    "pressure_a" : 995.15,
    "analog_input" : 0.02,
    "pm1.0" : 1.1,
    "pm1.0_a" : 1.1,
    "pm1.0_b" : 1.1,
    "pm2.5" : 1.7,
    "pm2.5_a" : 1.7,
    "pm2.5_b" : 1.7,
    "pm2.5_alt" : 1.4,
    "pm2.5_alt_a" : 1.3,
    "pm2.5_alt_b" : 1.4,
    "pm10.0" : 2.5,
    "pm10.0_a" : 2.7,
    "pm10.0_b" : 2.3,
    "scattering_coefficient" : 5.5,
    "scattering_coefficient_a" : 5.8,
    "scattering_coefficient_b" : 5.2,
    "deciviews" : 5.1,
    "deciviews_a" : 5.3,
    "deciviews_b" : 4.9,
    "visual_range" : 235.1,
    "visual_range_a" : 230.4,
    "visual_range_b" : 239.8,
    "0.3_um_count" : 366,
    "0.3_um_count_a" : 385,
    "0.3_um_count_b" : 348,
    "0.5_um_count" : 105,
    "0.5_um_count_a" : 106,
    "0.5_um_count_b" : 104,
    "1.0_um_count" : 10,
    "1.0_um_count_a" : 8,
    "1.0_um_count_b" : 12,
    "2.5_um_count" : 0,
    "2.5_um_count_a" : 0,
    "2.5_um_count_b" : 1,
    "5.0_um_count" : 0,
    "5.0_um_count_a" : 0,
    "5.0_um_count_b" : 0,
    "10.0_um_count" : 0,
    "10.0_um_count_a" : 0,
    "10.0_um_count_b" : 0,
    "pm1.0_cf_1" : 1.1,
    "pm1.0_cf_1_a" : 1.12,
    "pm1.0_cf_1_b" : 1.09,
    "pm1.0_atm" : 1.1,
    "pm1.0_atm_a" : 1.12,
    "pm1.0_atm_b" : 1.09,
    "pm2.5_atm" : 1.7,
    "pm2.5_atm_a" : 1.71,
    "pm2.5_atm_b" : 1.67,
    "pm2.5_cf_1" : 1.7,
    "pm2.5_cf_1_a" : 1.71,
    "pm2.5_cf_1_b" : 1.67,
    "pm10.0_atm" : 2.5,
    "pm10.0_atm_a" : 2.71,
    "pm10.0_atm_b" : 2.34,
    "pm10.0_cf_1" : 2.5,
    "pm10.0_cf_1_a" : 2.71,
    "pm10.0_cf_1_b" : 2.34,
    "primary_id_a" : 973278,
    "primary_key_a" : "B31BSEQC8PBFY8Z7",
    "primary_id_b" : 973280,
    "primary_key_b" : "GY6R0EJ0EF5AV0HK",
    "secondary_id_a" : 973279,
    "secondary_key_a" : "QZQGO1L8M0ONFGJ7",
    "secondary_id_b" : 973281,
    "secondary_key_b" : "P20PGRDZ9NWJ3M8X",
    "stats" : {"pm2.5" : 1.7, "pm2.5_10minute" : 2.4, "pm2.5_30minute" : 3.6, "pm2.5_60minute" : 4.2, "pm2.5_6hour" : 7.2, "pm2.5_24hour" : 6.0, "pm2.5_1week" : 10.6, "time_stamp" : 1703761717},
    "stats_a" : {"pm2.5" : 1.7, "pm2.5_10minute" : 2.6, "pm2.5_30minute" : 3.8, "pm2.5_60minute" : 4.4, "pm2.5_6hour" : 7.6, "pm2.5_24hour" : 6.2, "pm2.5_1week" : 10.9, "time_stamp" : 1703761717},
    "stats_b" : {"pm2.5" : 1.7, "pm2.5_10minute" : 2.3, "pm2.5_30minute" : 3.4, "pm2.5_60minute" : 4.0, "pm2.5_6hour" : 6.9, "pm2.5_24hour" : 5.7, "pm2.5_1week" : 10.2, "time_stamp" : 1703761717}
Didi wrote: Thu Dec 28, 2023 12:32 pm I have the same kind of problem. Don't you think it's because the Purpleair API is now paid? => https://community.purpleair.com/t/api-pricing/4523
No , i do not use or have a paid API key..
