number of raindays in a period. **solved**
I am looking for retrieving the number of raindays (respectively the reverse: the number of days without rain) in a period with Meteobridge:
all time, year, month, weewx, from - to - but I could find anything in the Template section of the WiKi which touches this point.
Also, searching in the forum didn't produce anything useable ...
I know that technically I would have to count the days when the daily rain sum was bigger than a defined threshold (>0.00, >0.1 --> dew, ...),
but how to formulate it ...?
two questions:
1. for determining the number of raindays in a given period (from - to):
Does anyone have ideas what the expression [sensor-selector ...] has to look like ? Maybe in combination with a conditional expression #if ...#fi
2. Is there a possibility to create a loop with a break condition (e.g. loop while condition is fulfilled or loop until condition fulfilled with the template language) ?
two questions:
Re: number of raindays in a period
is the solution to this question so trivial that noone of the experts minds to answer ?
I would at least expect from @admin a statement like
a) can be done e.g. this way or that way
or
b) not possible with MB means ...
or
c) a respective variable will be created to be used in the template language.
I hear that under Meteohub this is possible ...
or
or
yes, you are right. Meteohub had this function.
I don't understand why Meteobridge, as the successor, can do less than its predecessor.
I would also like to have these raindays.
Meteobridge has a completely different handling and storing of data compared to Meteohub. This is to get rid of delays in finding min/max values and ineffective data handling. To believe that a completely new designed follow-on product does clone every single feature of the former one is not realisitic. Nevertheless, I will think if/how to support wishes like "count all years/months/days/hours that meet a certain sensor condition".
Thank you very much for the feedback, which is absolutely understandable. I appreciate your willingness to consider implementing this through an update. Ultimately, the end customer is only interested in the result and does not understand the process behind it.
I implemented a light version of this, which hopefully lowers your pain a bit. Please read here: https://meteobridge.com/wiki/index.php/Forum
Thank you! Works wonderfully
The only thing missing is that "@" works.
Just did a rework of the solution. New syntax and function can be found here: https://meteobridge.com/wiki/index.php/Forum
I will check tomorrow how to make this available in exports as well.
I also added support of day counts in exports via "rain0total-count" template variable. Please have a look at the modified "NOAA" template below, which adds number of rain days as a last column:
Export for December 2023 is:
# Standard monthly NOAA template with data in metric units
$ MONTHLY CLIMATOLOGICAL SUMMARY FOR [YYYY]-[MM]
$Elevation: [mbsystem-altitude.0:]m
$Latitude: [mbsystem-latitude.3:]
$Longitude: [mbsystem-longitude.3:]
$Temperature in C, Rain in MM, Wind Speed in KM/H and Pressure in HPA
$ AVG AVG DOM RAIN
$DAY TEMP HIGH TIME LOW TIME RAIN WIND HIGH TIME DIR BAROM HUM DAYS
[DD] [th0temp-avg.000001: ] [th0temp-max.000001: ] [th0temp-maxts.ij: ]:[th0temp-maxts.kl: ] [th0temp-min.000001: ] [th0temp-mints.ij: ]:[th0temp-mints.kl: ] [rain0total-sum.000001: ] [wind0wind-avg=kmh.00001: ] [wind0wind-max=kmh.000001: ] [wind0wind-maxts.ij: ]:[wind0wind-maxts.kl: ] [wind0dir-avg.000: ] [thb0seapress-avg.0000001: ] [th0hum-avg.00: ] [rain0total-count.00: ]
$MONTH[th0temp-mavg.000001: ] [th0temp-mmax.000001: ] [th0temp-mmaxtime.gh: ] [th0temp-mmin.000001: ] [th0temp-mmintime.gh: ] [rain0total-monthsum.000001: ] [wind0wind-mavg=kmh.00001: ] [wind0wind-mmax=kmh.000001: ] [wind0wind-mmaxtime.gh: ] [wind0dir-mavg=endir.3: ] [thb0seapress-mavg.0000001: ] [th0hum-mavg.00: ] [rain0total-mcount.00: ]
MONTHLY CLIMATOLOGICAL SUMMARY FOR 2023-12
Elevation: m
Latitude: 53.686
Longitude: 9.980
AVG AVG DOM RAIN
01 -1.9 -0.2 15:37 -5.4 10:35 0.0 0.0 1.8 12:58 166 1004.5 96 00
02 -0.3 5.1 17:12 -2.1 17:12 0.0 0.0 0.0 17:13 166 1009.0 96 00
03 -1.7 -0.9 16:04 -2.8 11:32 0.0 0.0 0.0 16:04 184 1016.7 98 00
04 -0.4 0.1 13:15 -1.1 16:04 0.0 0.0 0.0 16:04 214 1010.3 95 00
05 -1.1 -0.9 14:37 -1.8 15:57 0.0 0.0 0.0 15:57 223 1004.4 97 00
06 0.1 0.1 14:54 -0.4 14:56 0.0 0.0 0.0 14:56 223 1008.7 99 00
07 1.3 2.1 17:06 0.7 17:06 0.0 0.0 1.8 16:29 220 1015.3 99 00
08 1.4 1.7 13:03 0.7 17:01 0.8 1.7 15.5 11:32 223 1008.3 96 01
09 4.8 5.3 12:47 4.3 16:31 7.0 1.5 11.9 17:58 223 1001.6 98 01
10 7.5 9.2 16:17 4.5 00:27 2.8 3.0 18.7 16:13 188 994.1 99 01
11 8.2 9.2 13:34 7.4 16:57 3.2 0.8 8.6 13:45 176 993.6 99 01
12 5.6 6.0 13:11 4.9 16:26 0.2 1.9 8.6 16:01 152 1002.1 99 01
13 4.7 4.8 12:04 4.1 16:10 0.0 8.5 23.8 10:28 223 999.0 97 00
14 2.6 3.9 11:53 1.0 23:58 0.6 0.8 13.7 12:25 223 1014.4 97 01
15 6.2 10.3 01:46 1.1 00:05 0.0 3.1 13.7 16:05 174 1026.3 99 00
16 7.4 7.9 15:30 6.9 11:08 0.4 9.2 29.2 10:34 172 1029.9 98 01
17 9.3 10.0 14:03 8.6 23:59 0.0 7.9 36.0 13:29 172 1026.7 92 00
18 8.2 8.6 00:18 7.6 15:35 0.6 8.1 27.4 14:03 175 1021.5 96 01
19 7.9 56.2 11:19 7.3 11:36 1.8 7.3 20.5 15:14 175 1010.8 98 01
20 5.6 6.8 14:21 4.8 10:42 13.4 6.5 39.2 11:49 170 1001.6 94 01
21 7.3 9.7 12:26 5.4 02:07 4.0 7.4 47.9 17:37 171 983.8 95 01
22 4.1 5.7 13:29 2.3 23:59 1.0 1.6 29.2 20:11 153 988.5 87 01
23 3.1 4.1 17:22 1.6 10:31 27.2 0.5 13.7 13:48 158 997.3 96 01
24 10.6 15.8 15:44 9.6 10:15 3.6 10.3 30.6 15:06 171 992.5 99 01
25 7.9 9.1 13:13 6.7 19:05 4.0 3.0 32.4 10:54 172 996.9 90 01
26 7.7 9.2 01:59 5.2 17:44 10.8 5.9 36.0 11:49 165 1002.8 96 01
27 3.5 18.1 18:51 1.5 09:45 0.2 0.0 6.8 18:41 221 1013.0 96 01
28 10.7 11.6 12:17 9.7 19:51 0.2 10.3 41.0 14:35 180 1002.0 86 01
29 8.6 9.9 14:51 7.4 23:59 0.0 7.3 42.8 14:41 173 998.3 83 00
30 6.0 7.4 00:10 4.4 18:44 1.6 2.8 27.4 00:17 183 1004.2 94 01
31 7.3 7.8 19:23 6.1 09:59 0.2 0.0 6.8 13:03 220 998.6 93 01
MONTH 4.9 56.2 19 -5.4 01 83.6 3.5 47.9 21 S 1005.7 95 20
great function, thank you very much
Torsten
Torsten
