number of raindays in a period. **solved**
Gyvate
Post by Gyvate »
I am looking for retrieving the number of raindays (respectively the reverse: the number of days without rain) in a period with Meteobridge:
all time, year, month, weewx, from - to - but I could find anything in the Template section of the WiKi which touches this point.
Also, searching in the forum didn't produce anything useable ...
I know that technically I would have to count the days when the daily rain sum was bigger than a defined threshold (>0.00, >0.1 --> dew, ...),
but how to formulate it ...?
two questions:
1. for determining the number of raindays in a given period (from - to):
Does anyone have ideas what the expression [sensor-selector ...] has to look like ? Maybe in combination with a conditional expression #if ...#fi
2. Is there a possibility to create a loop with a break condition (e.g. loop while condition is fulfilled or loop until condition fulfilled with the template language) ?
Gyvate
Re: number of raindays in a period
Post by Gyvate »
is the solution to this question so trivial that noone of the experts minds to answer ?
I would at least expect from @admin a statement like
a) can be done e.g. this way or that way
or
b) not possible with MB means ...
or
c) a respective variable will be created to be used in the template language.
I hear that under Meteohub this is possible ...
Empire24
Post by Empire24 »
yes, you are right. Meteohub had this function.
I don't understand why Meteobridge, as the successor, can do less than its predecessor.
I would also like to have these raindays.
Meteobridge has a completely different handling and storing of data compared to Meteohub. This is to get rid of delays in finding min/max values and ineffective data handling. To believe that a completely new designed follow-on product does clone every single feature of the former one is not realisitic. Nevertheless, I will think if/how to support wishes like "count all years/months/days/hours that meet a certain sensor condition".
Empire24
Post by Empire24 »
Thank you very much for the feedback, which is absolutely understandable. I appreciate your willingness to consider implementing this through an update. Ultimately, the end customer is only interested in the result and does not understand the process behind it.
I implemented a light version of this, which hopefully lowers your pain a bit. Please read here: https://meteobridge.com/wiki/index.php/Forum
Empire24
Post by Empire24 »
Thank you! Works wonderfully :-)
The only thing missing is that "@" works.
Just did a rework of the solution. New syntax and function can be found here: https://meteobridge.com/wiki/index.php/Forum
I will check tomorrow how to make this available in exports as well.
I also added support of day counts in exports via "rain0total-count" template variable. Please have a look at the modified "NOAA" template below, which adds number of rain days as a last column:
# Standard monthly NOAA template with data in metric units
$                  MONTHLY CLIMATOLOGICAL SUMMARY FOR [YYYY]-[MM]
$Elevation: [mbsystem-altitude.0:]m
$Latitude:  [mbsystem-latitude.3:]
$Longitude: [mbsystem-longitude.3:]
$Temperature in C, Rain in MM, Wind Speed in KM/H and Pressure in HPA
$      AVG                                      AVG                 DOM            RAIN
$DAY   TEMP   HIGH   TIME   LOW   TIME   RAIN   WIND   HIGH   TIME  DIR  BAROM HUM DAYS
 [DD]  [th0temp-avg.000001:     ]  [th0temp-max.000001:     ]  [th0temp-maxts.ij:  ]:[th0temp-maxts.kl:  ] [th0temp-min.000001:     ]  [th0temp-mints.ij:  ]:[th0temp-mints.kl:  ]  [rain0total-sum.000001:     ]   [wind0wind-avg=kmh.00001:    ]  [wind0wind-max=kmh.000001:     ]  [wind0wind-maxts.ij:  ]:[wind0wind-maxts.kl:  ]  [wind0dir-avg.000:   ] [thb0seapress-avg.0000001:      ]  [th0hum-avg.00:  ] [rain0total-count.00:  ]
$MONTH[th0temp-mavg.000001:     ]  [th0temp-mmax.000001:     ]  [th0temp-mmaxtime.gh:  ]    [th0temp-mmin.000001:     ]  [th0temp-mmintime.gh:  ]     [rain0total-monthsum.000001:     ]   [wind0wind-mavg=kmh.00001:    ]  [wind0wind-mmax=kmh.000001:     ]  [wind0wind-mmaxtime.gh:  ]     [wind0dir-mavg=endir.3:   ] [thb0seapress-mavg.0000001:      ]  [th0hum-mavg.00:  ] [rain0total-mcount.00:  ]
Export for December 2023 is:
                  MONTHLY CLIMATOLOGICAL SUMMARY FOR 2023-12
Elevation: m
Latitude:  53.686
Longitude: 9.980
      AVG                                      AVG                 DOM            RAIN
 01   -1.9   -0.2  15:37  -5.4  10:35    0.0    0.0    1.8  12:58  166 1004.5  96 00
 02   -0.3    5.1  17:12  -2.1  17:12    0.0    0.0    0.0  17:13  166 1009.0  96 00
 03   -1.7   -0.9  16:04  -2.8  11:32    0.0    0.0    0.0  16:04  184 1016.7  98 00
 04   -0.4    0.1  13:15  -1.1  16:04    0.0    0.0    0.0  16:04  214 1010.3  95 00
 05   -1.1   -0.9  14:37  -1.8  15:57    0.0    0.0    0.0  15:57  223 1004.4  97 00
 06    0.1    0.1  14:54  -0.4  14:56    0.0    0.0    0.0  14:56  223 1008.7  99 00
 07    1.3    2.1  17:06   0.7  17:06    0.0    0.0    1.8  16:29  220 1015.3  99 00
 08    1.4    1.7  13:03   0.7  17:01    0.8    1.7   15.5  11:32  223 1008.3  96 01
 09    4.8    5.3  12:47   4.3  16:31    7.0    1.5   11.9  17:58  223 1001.6  98 01
 10    7.5    9.2  16:17   4.5  00:27    2.8    3.0   18.7  16:13  188  994.1  99 01
 11    8.2    9.2  13:34   7.4  16:57    3.2    0.8    8.6  13:45  176  993.6  99 01
 12    5.6    6.0  13:11   4.9  16:26    0.2    1.9    8.6  16:01  152 1002.1  99 01
 13    4.7    4.8  12:04   4.1  16:10    0.0    8.5   23.8  10:28  223  999.0  97 00
 14    2.6    3.9  11:53   1.0  23:58    0.6    0.8   13.7  12:25  223 1014.4  97 01
 15    6.2   10.3  01:46   1.1  00:05    0.0    3.1   13.7  16:05  174 1026.3  99 00
 16    7.4    7.9  15:30   6.9  11:08    0.4    9.2   29.2  10:34  172 1029.9  98 01
 17    9.3   10.0  14:03   8.6  23:59    0.0    7.9   36.0  13:29  172 1026.7  92 00
 18    8.2    8.6  00:18   7.6  15:35    0.6    8.1   27.4  14:03  175 1021.5  96 01
 19    7.9   56.2  11:19   7.3  11:36    1.8    7.3   20.5  15:14  175 1010.8  98 01
 20    5.6    6.8  14:21   4.8  10:42   13.4    6.5   39.2  11:49  170 1001.6  94 01
 21    7.3    9.7  12:26   5.4  02:07    4.0    7.4   47.9  17:37  171  983.8  95 01
 22    4.1    5.7  13:29   2.3  23:59    1.0    1.6   29.2  20:11  153  988.5  87 01
 23    3.1    4.1  17:22   1.6  10:31   27.2    0.5   13.7  13:48  158  997.3  96 01
 24   10.6   15.8  15:44   9.6  10:15    3.6   10.3   30.6  15:06  171  992.5  99 01
 25    7.9    9.1  13:13   6.7  19:05    4.0    3.0   32.4  10:54  172  996.9  90 01
 26    7.7    9.2  01:59   5.2  17:44   10.8    5.9   36.0  11:49  165 1002.8  96 01
 27    3.5   18.1  18:51   1.5  09:45    0.2    0.0    6.8  18:41  221 1013.0  96 01
 28   10.7   11.6  12:17   9.7  19:51    0.2   10.3   41.0  14:35  180 1002.0  86 01
 29    8.6    9.9  14:51   7.4  23:59    0.0    7.3   42.8  14:41  173  998.3  83 00
 30    6.0    7.4  00:10   4.4  18:44    1.6    2.8   27.4  00:17  183 1004.2  94 01
 31    7.3    7.8  19:23   6.1  09:59    0.2    0.0    6.8  13:03  220  998.6  93 01
MONTH  4.9   56.2  19     -5.4  01      83.6    3.5   47.9  21       S 1005.7  95 20
paul_1055
Post by paul_1055 »
great function, thank you very much :D
Torsten
