Problem with rain0total after clocks went back
frogfoot
Post by frogfoot »
Ever since the clocks went back on 31-march my rain0total-sumday value exported to my database has been incorrect, with the value on each hour showing the previous hours value, causing a sawtooth graph. Is anyone else having this problem?
(Meteobridge pro Version 5.6, Davis vantage vue)
Re: Problem with rain0total after clocks went back
Current version is 5.8, check the 5.6 release update March 25, 2023
frogfoot
Post by frogfoot »
Updated to 5.8 now, just have to wait for some more rain, shouldn't be too long.
tofe
Post by tofe »
frogfoot wrote: Wed Apr 03, 2024 10:44 am Ever since the clocks went back on 31-march my rain0total-sumday value exported to my database has been incorrect, with the value on each hour showing the previous hours value, causing a sawtooth graph. Is anyone else having this problem?
(Meteobridge pro Version 5.5, Davis vantage vue)
I have the same Problem on meteobridge nano sd white DAVIS Vantage Pro 2
Meteobridge 5.8 (Mar 17 2024, build 4795), FW 1.4
frogfoot
Post by frogfoot »
The problem is still present with Ver 5.8, see last nights rainfall
Screen Capture 007.jpg (40.56 KiB) Viewed 1359 times
Notice that 2.00am shows actual value from 1.00am (0mm), 3.00am shows value from 2.00am (0.2mm - happens to be correct), 4.00am shows value from 3.00am (0.2mm) the rest of the night looks ok because there is no more cumulative rainfall.
frogfoot
Post by frogfoot »
Reverting to V5.5 seems to have solved the problem
