Meteobridge is not working since 02:00 AM (GMT+2)
Valdrin
Post by Valdrin »
Since 2 o'clock in the morning I see that my weather data has not been sent to other meteorological websites. After entering meteobridge, I saw a message!
What could it be? Is it a general problem or is there something wrong with me, even though it is not that I have touched anything on my part!
Re: Meteobridge is not working since 02:00 AM (GMT+2)
Any reason why the MB would reboot at 2am? Was there a power outage etc? Have you checked your internet (router), is it currently running ok now? Would that also have rebooted at the same time?
The MB appears hung for some reason, maybe waiting on internet? Have you tried to do a fresh repower/reboot of the MB?
Valdrin
Post by Valdrin »
Normally the internet is working, I turned them both off and on again but the same problem continues. At that time I was asleep, but immediately at 4 o'clock I received an email message from awekas after 2 hours that he has not sent information to this website and I checked it immediately.
I first looked to see if the console stopped (low battery) but it didn't, so I turned off both and turned them back on to see if the problem would be solved, but unfortunately it wasn't. The problem continues until now!
Was just a thought as what you see can happen if the router has not fully and totally booted up and connected before the MB tries to connect. For systems that power up together and as the MB will boot well before a router the MB has a Boot Delay setting on the Administration tab>Maintenance
Valdrin
Post by Valdrin »
The problem is that to access meteobridge for configuration, only this part that I sent as a screenshot is displayed.
What can I do now, please?
Valdrin
Post by Valdrin »
The problem fixed itself, only now the problem is with "windy": 2024-05-16 13:12:57 Error: 2024-05-16 13:04:43 OpenSSL: error:14077410:lib(20):func(119 ):reason(1040) Unable to establish SSL connection. (47 more tries, next in 143 secs)
I'm looking at what I can do to fix it. Thank you.
Which Meteobridge SW version are you using? Looks like outdated SW.
tomas21
Post by tomas21 »
What hardware do you have running your Meteobridge... i just had an reboot update from 5.8 to 5.9 on my trusted MR3040 and now caught in this loop as well... troubleshooting with Boris hope i didn't lose my device because I am so frustrated i didn't get a config backup before the reboot auto update.
tomas21 wrote: Fri May 24, 2024 3:05 am What hardware do you have running your Meteobridge... i just had an reboot update from 5.8 to 5.9 on my trusted MR3040 and now caught in this loop as well... troubleshooting with Boris hope i didn't lose my device because I am so frustrated i didn't get a config backup before the reboot auto update.
The MR3040 problem with version 5.9 is separate. I was able to reproduce the error and I am working on it.
For the moment I limited access for TL-MR3040 to version 5.8 which works fine on my test equipment.
MR3040 issue is solved with just released version.
Valdrin
Post by Valdrin »
admin wrote: Tue May 21, 2024 9:46 am Which Meteobridge SW version are you using? Looks like outdated SW.
Is this what you are looking for? Still Windy isn't working.
Screenshot 2024-05-30 at 20-07-50 Meteobridge.png (70.48 KiB) Viewed 4788 times
Another router platform EOL for many years... Can you please use newest Meteobridge SW to rule out that you are struggling with issues already solved.
What does "Monitoring - Upload Status" tell in regard to Windy?
tomas21
Post by tomas21 »
admin wrote: Fri May 24, 2024 10:26 am MR3040 issue is solved with just released version.
Thank you Boris!
Valdrin
Post by Valdrin »
admin wrote: Thu May 30, 2024 8:26 pm Another router platform EOL for many years... Can you please use newest Meteobridge SW to rule out that you are struggling with issues already solved.
These are appearing
Screenshot 2024-06-01 at 14-26-31 Meteobridge.png (64.82 KiB) Viewed 4753 times
I don't have this HW platform for testing here. When you give me remote login, I can try to solve this.
Please send to "info(at)meteobridge.com"
