Meteobridge VM
Meteobridge VM
Finally Meteobridge VM is there!
Now you can have Meteobridge running without dedicated HW. Simply install the Meteobridge VM image on your virtualization platform of choice. Meteobridge VM is x86_64 based and is tested on VirtualBox, VMware Player, KVM and PROXMOX. You find details and installation instructions here.
vm bundle.png (173.81 KiB) Viewed 9605 times
scarecrow93
Re: Meteobridge VM
Post by scarecrow93 »
Just tried the Meteobridge VM in Proxmox to see if I could get data from my Davis Vantage Vue via an RTL-SDR Blog v3 USB stick but that doesn't seem to work. I tried passing through the device as instructed and also tried the whole port.
Any pointers?
Thanks!
Re: Meteobridge VM
Why should a "RTL-SDR Blog v3 USB stick" work? Meteobridge supports Meteostick for direct RF readout, nothing else.
scarecrow93
Re: Meteobridge VM
Because I can't buy them in the USA (checked your sole US reseller and they're not there). Unless I can cannibalize the one out of my current Meteobridge Pro I guess I'm SOL.
Thanks anyway.
Re: Meteobridge VM
I am in the process to setup a new US reseller, which will make US support easier in the future.
For the time being you can by here directly: https://www.smartbedded.com/wiki/index.php/Meteostick
I send to US but it will take 2 weeks (no express option).
cynicuk
Re: Meteobridge VM
Post by cynicuk »
Hi there,
I have setup a VM in Proxmox following the instructions but when I add my Weatherflow station it never receives any data from it. I am not running any firewall and the Proxmox build is bascially out of the box standard.
Any suggestions where to look or what the issue might be ? An Rpi on the same network receives data from the Weatherflow station without any issues.
Dave
