Aurora Downloads and Updates
Just to clear up any confusion or if you are not aware all downloads of Aurora Meteobridge (Formerly Weather34) and updates to the template are done via the admin panel of meteobridge itself shown below
i will post here what is new or fixed in the updates once they are available via meteobridge ..
development and new ideas will be ongoing nothing has changed in that respect
in time the weather34 phrase will be removed and simply use Aurora Meteobridge ..
hope that clarifies it..brian
Re: Aurora Downloads and Updates
May Update has been upload and accessible via meteobridge admin screen.
to update simple follow below once uploaded to your server where template resides.
May update contains new lightning module for theme 8/9 and adds functional chart display for lightning .
* to use the lightning module for ecowitt devices an additional service event script can be used and shown below .
like this.(this is also visible in the template setup screen.
https://yourdomain.com/mbridge/mb-lightning.php?d=[lgt0energy-act:--] [lgt0dist-act:--] [lgt0dist-age:--] [lgt0total-daysum.0:--] [lgt0total-monthsum.0:--] [lgt0total-yearsum.0:--] [lgt0total-sum10.0:--]
any problems or confused feel free to get in touch ..brian
pwilman
Post by pwilman »
Thanks for implementing this new partnership with Boris and continuing to deliver updates.
Quick question which I suspect is not possible without a lot of effort. I maintain a local Davis owners website for him that is based on my website, so built around your template. He has a VP2 with a nano SD. He was interested in measuring lightening, so bought the ecowit lightening detector unit, with the router unit so that he can upload to lightening strikes to the ecowit app.
Would it be possible to integrate his ecowit lightening strikes into his W34 template? I suspect it would need a lot more coding to get both instances into your template so not worth it, but thought I would ask!
Paul
pwilman wrote: Mon May 27, 2024 12:33 pm Brian,
Paul
Hello Paul
its feasible but im no expert by far on ecowitt stuff and its workings , i already went through a small learning curve last few weeks and I just find it confusing which is mostly to my lack of knowledge and owning one , my days of learning stuff are dwindling in many aspects. I should imagine simplest method is too setup the ecowitt router(gw1000 or something) as a second weather station and map the lightning sensor strings to lgt0.... perhaps Boris would know better if it is possible so i would contact him for confirmation and if possible I can help and if it is possible then template is good to go without additional code.
hope it helps..brian
pwilman
Post by pwilman »
Thanks for your help with the ecowitt lightening module. I have added the GW1000 unit as a second weather station. I have also mapped in the 3 lightening sensors. It appears to be pulling in some lightening energy data, so I can only assume the ecowitt is connected to the Nano SD.
I have setup the event setting in MB exactly as you have set out, updating the URL to where his template is stored on his host. I have it setup to run every minute.
I am not sure exactly how it works, but there is no mb-lightening.php file created, and the module on the website does not update.
Is there something I am doing wrong?
Paul
hello paul i have temporary set the lightning module in theme 9 on your site to test .if you can leave it for a day or so so i can confirm all ok.
if you can email meteobridge login admin details so i can check whats going on..
.brian
pwilman
Post by pwilman »
Thanks so much for helping out so quickly. It is actually for a local weather station owner and not me
https://www.cotswoldobservatory.co.uk/W ... yout-3.php
I have just emailed over all the details that I think you need.
I am off to the Netherlands this evening for a week so maybe limitted in what I can do remotely.
Thanks you
Paul
pwilman wrote: Wed May 29, 2024 10:07 am Brian,
Paul
hello paul should be fine now ...https://www.cotswoldobservatory.co.uk/W ... yout-3.php
let it run for a few days ..
see below
Screenshot at May 29 19-38-53.png (244.09 KiB) Viewed 10155 times
cheffy
Post by cheffy »
I have just updated to the latest version and I have a couple of questions on the lightning module. I already had the following as a lightning event and on update everything continued on fine.
https://micklehamweather.com/mbridge/mb ... ing.php?d=[lgt0energy-act:--] [lgt0dist-act:--] [lgt0total-nonzerotime:--] [lgt0total-daysum.0:--] [lgt0total-monthsum.0:--] [lgt0total-yearsum.0:--] [lgt0total-sum10.0:--]
However, I later noticed the monthly and yearly lightning charts did not contain any data even though I can see data in the 2024strikes file, which continues to update. I then noticed the lightning event you had in this thread was subtly different to what I had already. I changed over to the new version, however the charts still had no data and the time since last strike in my current view (layout 2) did not work - it showed 19883 days ago. So I reverted back to my original code above.
Do you have any idea what I am doing wrong?
Neil
cheffy wrote: Sun Jun 09, 2024 5:45 am Hi Brian,
Neil
good evening , i apologise but not much i CAN OFFER in process of elimination solutions at present and until I get back to Istanbul which unfortunately is 2nd week of August.
all i can suggest is check this particular file (weather34-chart-end-of-day.php) has this new code in it ,last position should be , .$weather["lightningmax"]."" // lightning chart position = 18
[b]//create the current month file example folder/file path = weather34charts/2021/July.csv[/b]
$weatherchartfilemonth ="weather34charts/".$year."/".date('F').".csv";
// meteobridge and chart position number
$weather34chartdata = date('j M',strtotime("yesterday"))."," //date chart position = 0
.$meteobridgeapi[82]."," //Max Temp chart position = 1
.$meteobridgeapi[84]."," // Min Temp chart position = 2
.$meteobridgeapi[52]."," // Max Dewpoint chart position = 3
.$meteobridgeapi[120]."," // Min Dewpoint chart position = 4
.$meteobridgeapi[100]."," // Rain Total chart position = 5
.$meteobridgeapi[94]."," // Wind Speed Max chart position = 6
.$meteobridgeapi[123]."," // Wind Speed Avg chart position = 7
.$notused."," // Not Used chart position = 8
.$meteobridgeapi[135].","  // Pressure Max chart position = 9
.$meteobridgeapi[137]."," // Pressure Min chart position = 10
.$meteobridgeapi[114]."," // UV Max chart position = 11
.$meteobridgeapi[107]."," // Solar Max chart position = 12
.$aqiweather["aqi24h"]."," // Purple Air 24 hour Avg chart position = 13
.$meteobridgeapi[184]."," // Davis Airlink chart position = 14
.$meteobridgeapi[171]."," // Wind Direction Avg chart position = 15
.$meteobridgeapi[167]."," // Max Humidity chart position = 16
.$meteobridgeapi[169]."," // Min Humidity chart position = 17
."\r\n"; //end
[b]//create the year file example folder/file path = weather34charts/2021.csv[/b]
$weatherchartfileyear = "weather34charts/".date('Y').".csv";
$weather34chartdata1  = date('j M',strtotime("yesterday"))."," // date chart position = 0
."\r\n"; //end
thats all i can think of at the moment.
brian
cheffy
Post by cheffy »
Thanks Brian.
I have spent a bit of time looking at it but I can't figure it out. It's not a big issue so it can wait. I did notice the file 2024strike.csv was still being updated, so for now I have repointed the charts to use that instead. I have an event to run weather34-strikes-end-of-day.php at 23.45pm which must be updating this file.
I could be way of the mark here but I noticed the weather34-lightning.txt file captures the lightning data. My weather34-chart-end-of-day.php event runs at 2am. If it looks at this file to grab the lightning data for the previous day at this time, then I would miss the previous days data because it would have already rolled over. If that make sense. It was just a thought.
Like I said no big deal at the moment because I have a work around.
Neil
MeteoHeerde
Post by MeteoHeerde »
How can i reset de password in the backsite.
Greetings,
Robert
reindeer
Post by reindeer »
The first post says:
"i will post here what is new or fixed in the updates once they are available via meteobridge .."
Could you please post about new update files?
So I accidently found the dezember-update-file on my meteobridge.
I tried updating as described, but the files are only unzipped in a folder called: "December-2024-Simple-Update"
Do I have to manually move the files and folders to their correct location?
Many thanks for your work.
There seems to be an issue with the December update. Until fixed I linked back to the October update, which was proven to work fine.
good morning Tom /Boris have emailed i have an inkling what caused the issue..brian
