Meteobridge VM
Meteobridge VM
Finally Meteobridge VM is there!
Now you can have Meteobridge running without dedicated HW. Simply install the Meteobridge VM image on your virtualization platform of choice. Meteobridge VM is x86_64 based and is tested on VirtualBox, VMware Player, KVM and PROXMOX. You find details and installation instructions here.
vm bundle.png (173.81 KiB) Viewed 11669 times
Ed_Heaton
Re: Meteobridge VM
Post by Ed_Heaton »
So version 6 only works with VM and not my current hardware?
Re: Meteobridge VM
Ed_Heaton wrote: Sun May 26, 2024 7:48 pm So version 6 only works with VM and not my current hardware?
No, all hardware is supported by any new version, as it always was.
Since Version 6 Meteobridge VM is added to the family.
Re: Meteobridge VM
Please make sure that you select "USB 3.0" as USB mode when using VirtualBox. Otherwise VirtualBox freezes when you feed USB data into your Meteobridge VM.
ivan
Re: Meteobridge VM
Post by ivan »
Hello, I just arrived at Meteobridge, I'm new to everything, I just installed my weather station and decided to try Meteobridge VM, I did it on a Qnap NAS through Virtualization Station, everything seems to be working well, but I had to do a "move" before, I installed Meteobridge on VirtualBox because I didn't have a guide for Qnap and then I exported the Virtual Machine from VirtualBox to Virtualization Station, as I said before, it seems to be working without any problems. I'm leaving my experience in case someone wants to try it.
:!: Now; being a newbie, I have no experience with the software, I would like to make some edits to the "weather34" language (I use it in Spanish) it shows some incorrect words in the translation, I would like to change them but I don't know how to do it. I don't have access to the files to edit the template, I also see that there is a newer version but I can't update either. I'm working as I said on the Virtual Machine installed on my NAS, I don't work on a specific domain (http://myIP/PWS2/weather34-tv.php). I would appreciate your help, at least with the translation issue so I can correct words in the "weather34" template :)
ivan
Re: Meteobridge VM
Post by ivan »
I'll expand a bit on my situation, I've already tried to enter through SMB but without success, I tried it from Windows and from Mac, but I think there could be some problem due to the fact that I have an unofficial VM (On Qnap) perhaps that's why it's complicated to enter through SMB. So I have no way to correct the translations of the Template. :cry:
Re: Meteobridge VM
SMB can be a little quirky depending on your windows operating system hence assuming the WM options are the same as say a MBPro/2 then under System>Administration>Maintenance Media Access allows Download or Delete Files and Upload Files.
You should also be able to Download/Upload using http://x.x.x.x/cgi-bin/download.cgi and http://x.x.x.x/upload.html
ivan
Re: Meteobridge VM
Post by ivan »
Thank you, i only see these attached files. Can I edit the language of the template I used there?
Captura de pantalla 2024-07-04 a la(s) 9.32.24 p.m..png (249.53 KiB) Viewed 11156 times
Re: Meteobridge VM
I've never changed the actually language but they are only text files so don't see why not?
I would download the standard/default template/file you want to change (click on the actual file as highlighted and copy/paste/save as)) to an new appropriate name of your choice, do your editing, then upload back. If you were to simply edit an existing default filename then next firmware update would overwrite it back to default. The file you rename/edit/upload and save won't be overwritten next update.
Gyvate
Re: Meteobridge VM
Post by Gyvate »
you should be able to find your Weather34 langauge file here:
/tmp/mnt/PWS/MB/languages (unless the file system has changed in MB VM)
and the file name is lang.sp.php
you will have to connect via SSH or any other tool which allows you to access the file system
Kanok
Re: Meteobridge VM
Post by Kanok »
I see the VM is running on OpenWRT 21.02.3. Does it need to be updated to a more current version of OpenWRT?
Regrards,
Ambient Weather WS-1900
WUnderground, PWS - IPATHUMT2
CWOP - EW4214
http://kanok.net/pws
Re: Meteobridge VM
Kanok wrote: Sat Sep 05, 2026 6:54 am I see the VM is running on OpenWRT 21.02.3. Does it need to be updated to a more current version of OpenWRT?
Regrards,
No, that will break the installation.
