Hi all,
I have a MBpro2 and it seem to have stopped reading / registering / reporting the air pressure. It does not show anywhere. I saw it stopped registering in august. I blamed my website, but when i looked, it seems not to show the airpressuresensor in the MBpro2. Updated to the latest version did not help.
Any ideas how to solve this?
Thx, Gerhard
MBpro2 not showing air pressure
fotogw
- Senior Boarder
- Schermafbeelding 2025-01-09 om 00.07.58.jpg (242.88 KiB) Viewed 2808 times
Re: MBpro2 not showing air pressure
You have no Indoor live data at all which includes Inside temp/Humidity & Pressure.
You have a very busy lot of multiple additional sensors but not sure why no Indoor?
fotogw
- Senior Boarder
Yes, I see the sensors direct read from RF (Davis VP2+ and additional Davis sensors. They all show up normally. But the built in sensors of the MBpro2 do not show. I don't use the indoor temp/hum sensor, so i hadn't noticed that was missing also. I do use the Airpressure sensor. These both do not show up.Mattk wrote: Thu Jan 09, 2025 3:09 am You have no Indoor live data at all which includes Inside temp/Humidity & Pressure.
Indoor sensors are connected via I2C. May by the I2C bus has been stalled somehow? Does a power-cycle fix it?
fotogw
- Senior Boarder
Thanks for your reply, I tried that, and I also got the latest updates then. It did not help unfortunately.
Can you please provide me a remote login as explained here: viewtopic.php?t=9885
Please send URL and temporary password to "info(at)meteobridge.com".
I assume you don't have anything connected to the 4 pin I2C port at the back panel of the Meteobridge? This could block the whole I2C bus.
fotogw
- Senior Boarder
No nothing connected to the IC2-bus.admin wrote: Fri Jan 10, 2025 10:38 am I assume you don't have anything connected to the 4 pin I2C port at the back panel of the Meteobridge? This could block the whole I2C bus.
I sent you the login.
Thanks for your help!
Gerhard
weeropdeveluwe.nl
Current finding is, that the I2C bus is somehow defective. I will give it a free repair.
