I understand that the interactive graphics can be accessed via the "remote URL" if "allow login from internet" is enabled.
Because my meteobridge is connected to the internet via a LTE connection I can not use this approach.
How can the graphs can be generated and uploaded periodically ?
I tried using two "Events", the first should create the graphics via the "allinone-wind1st-iso" template.
The second event should then transfer the chart:lastchart.html to the web server.
But I only see an empty graph.
What is missing there ?
how to FTP push interactive graphics to web server. **solved**
Re: how to FTP push interactive graphics to web server
The problem was that the timeslot was wrong. With "today (Min)" or "heute (Min)" the graphic show the complete data.
(special thanks to Boris for his tipps
- graph.jpg (340.42 KiB) Viewed 6019 times
- event.jpg (121.5 KiB) Viewed 6019 times
Re: how to FTP push interactive graphics to web server. **solved**
Thanks for sharing the issue and the solution.
