I2C sht31 install
alexvanuxem
I2C sht31 install
Post by alexvanuxem »
Hi
i connected a external I2c sht31 to a MBpro2.
I see it information tab as sht31ext.
how to get readings from it?
thx
alex
Re: I2C sht31 install
What does "Monitoring - Live Data" tab tell?
alexvanuxem
Nothing extra. My usual stations, and the data from the MB pro 2 itself, under station 9 (internal storage, uptime, internal temp and humidity, pressure,...), but an extra temp or humidity.....
thanks
PRO2 takes it as a replacement for the internal sensor that does not show true indoor data because being in a heated up environment. So temp and humidity of thb0 are now the values from this external sensor.
Did you plan to use it as a more accurate indoor sensor replacement, or something else?
alexvanuxem
the system temperature stays the same when plugging the sht31 external one, even after rebooting.
one good thing: at first the MBpro2 was connected through lan, > no RF firmware update available
i changed it to wifi and then I could flash the RF firmware (but stays at FW 3.5?).
just letting you know
i want to use the I2C bus for calibrating temp hum and pressure with all my installed sensors right next to it (WLL, vantage with uwb logger, ecowitt)
thx
a
alexvanuxem wrote: Thu Jun 05, 2025 7:47 pm i changed it to wifi and then I could flash the RF firmware (but stays at FW 3.5?).
There is no RF firmware 3.5. You see RF firmware version in "System - Logging" when using the RF function.
alexvanuxem
sorry my mistake,
can you explain why the internal temperature stays at +/- 33°c after attaching the sht31 module?
It should display a ambient temp of +/- 22°c or something, right?
you need to do a reboot after installing the module. Can you please send output of
http://ip-of-your-meteobridge/cgi-bin/system.cgi?cat%20/var/run/i2cdata
On a regular PRO2 it looks like this
DATE 1749203446
SHT31INT 38.4 22
BMP390 1000.9 37.6
INA220 5.09 312 1.59
DEVICES 50
alexvanuxem
command: cat /var/run/i2cdata
DATE 1749225665
SHT31INT 34.5 25
SHT31EXT 27.0 42
BMP390 1009.5 33.7
INA220 5.22 270 1.41
DEVICES 54
Schermafbeelding 2025-06-06 180043.png (93.79 KiB) Viewed 9738 times
I need to see 27.0°C and 42% humidity under system#9 correct?
Grtz
A
alexvanuxem wrote: Fri Jun 06, 2025 6:03 pm I need to see 27.0°C and 42% humidity under system#9 correct?
Yes, that is what I would expect to see. But your example does show different. I will check.
just released SW version should add a "th9" to system station to represent the external SHT31 data. please give it a try.
alexvanuxem
HI
Thanks! it works! I guess it will work with any type I2C temp/huymidity sensor?
I will use this IC2C sensors to try to calibrate my weather stations.
If a pressure sensor would be attached, any type, you will need to add again an additional sensor ?
thx
alex
currently just this external sensor is supported. As the PRO2 has a high quality BMP390 sensor inside, you should be fine on exact pressure data.
alexvanuxem
too bad,
it should be nice to just attach whatever i2c sensor to fully exploit this feature,
thank you for the support !!!!!!!
