Would it be possible to add MQTT support to Meteobridge pro2? If not, then perhaps a JSON output similar to WifiLogger.
I've attached the JSON file that WifiLogger makes available at IP_ADDRESS/wflexpj.json
MQTT or JSON
doubleohwhatever
- Fresh Boarder
MQTT or JSON
- wflexpj.zip
- (1015 Bytes) Downloaded 142 times
Re: MQTT or JSON
You can define a template file that results into a json style output.
doubleohwhatever
- Fresh Boarder
Re: MQTT or JSON
Thanks. I've went with another option that provides what I need and costs less.
Re: MQTT or JSON
Which route did you go?doubleohwhatever wrote: Thu Jul 10, 2025 5:33 pm Thanks. I've went with another option that provides what I need and costs less.
doubleohwhatever
- Fresh Boarder
Re: MQTT or JSON
WeatherLink Live. It provides JSON that I can pull into HomeAssistant. I'll use WeeWx on a Pi to send data elsewhere if I decide to.
