MQTT or JSON
doubleohwhatever
MQTT or JSON
Post by doubleohwhatever »
Would it be possible to add MQTT support to Meteobridge pro2? If not, then perhaps a JSON output similar to WifiLogger.
I've attached the JSON file that WifiLogger makes available at IP_ADDRESS/wflexpj.json
wflexpj.zip
(1015 Bytes) Downloaded 186 times
Re: MQTT or JSON
You can define a template file that results into a json style output.
doubleohwhatever
Re: MQTT or JSON
Thanks. I've went with another option that provides what I need and costs less.
Re: MQTT or JSON
doubleohwhatever wrote: Thu Jul 10, 2025 5:33 pm Thanks. I've went with another option that provides what I need and costs less.
Which route did you go?
doubleohwhatever
Re: MQTT or JSON
WeatherLink Live. It provides JSON that I can pull into HomeAssistant. I'll use WeeWx on a Pi to send data elsewhere if I decide to.
