Meteobridge does not sense Meteostick. **solved**
josecmorales
Post by josecmorales »
Hello.
I use a TL-WR902ACV3 with Meteostick RF direct to the ISS, but it is unstable despite being close to the ISS, But the strange thing is that the MB does not sense the meteostick either.
MB con MS.jpg (87.79 KiB) Viewed 6813 times
@climaguayana
josecmorales
Re: Meteobridge does not sense Meteostick
May be the power is not enough to feed the meteostick?
@climaguayana
Which RF threshold did you define on "Station" tab?
josecmorales
Those are my setup, the MS works fine for a few hours, later stops sense the ISS and the meteostick.
data LIVE
data LIVE
MB DATA.jpg (105.67 KiB) Viewed 6782 times
Setup
Setup
@climaguayana
You are picking up an enormous level of RF noise (reception rate - shown beside the indoor data - is just 0.5%!!). Please set RF threshold to -80db and/or look for a better, less RF noise exposed location.
josecmorales
admin wrote: Wed Aug 06, 2025 4:22 pm You are picking up an enormous level of RF noise (reception rate - shown beside the indoor data - is just 0.5%!!). Please set RF threshold to -80db and/or look for a better, less RF noise exposed location.
Changed but still the same, worked for almost 4 hours.
ms setup.jpg (93.41 KiB) Viewed 6770 times
mb data 2.jpg (111.15 KiB) Viewed 6770 times
@climaguayana
josecmorales
I just add an extension of USB cable and done! works fine.
mb con ext.jpg (107.82 KiB) Viewed 6712 times
@climaguayana
