Problem with the rain rate chart! **solved**
zakos52
Post by zakos52 »
In the allinone.iso charts, in the rain rate section, the same image appears every day without it raining!
chart iso.png (140.04 KiB) Viewed 5473 times
This rain rate image is also transferred to all networks (underground etc.)
Unlike metacharts, the rain rate diagram is not displayed when there is no rain
Is there any setting that I need to make in meteobridge to solve this problem?
Platform: Raspberry Pi 4 Model B Rev 1.1 Rev 1.1
RAM: 3895 MB total, 3728 MB free (4% used)
Storage: ATP SLC, 1.5 GB total, 724 MB free (53% used, 254.2 yrs)
SW Version: Meteobridge 6.2 (Jul 20 2025, build 4092), FW 1.3
Re: Problem with the rain rate chart!
Do you also see the rainrate data in the database when you inspect? Which station are you using?
zakos52
Post by zakos52 »
The is not rainrate data in the database!
Davis Vantage Pro 2 with Solar and UV sensor
P.S
The rain rate chart is the same every day and starts around at sunrise until sunset!
Theres is a definition for "solXrate" that you might have mixed with "rainXrate" on the mappings tab? Can you please post "Station - Mappings" tab?
zakos52
Post by zakos52 »
You were right, I corrected the mapping and the problem was fixed.
Thanks for pointing it out!
