I have been using meteobridge via Raspberry Pi to send data to Weather Underground for years. WU says it was updated x minutes ago, but there is no data
Suddenly the Weather Station /Primary Station option will no longer accepts Vantage as an option.
I found new (to me) "aurora" options - I tried setting them up but the display on my PC is like Weather Underground, no data.
Thanks in advance for any insights...
Vantage PRO no longer supported?? (no data transfer). **solved**
putteringalong
- Fresh Boarder
- Vantage device disabled.png (87.92 KiB) Viewed 7349 times
Re: Vantage PRO no longer supported?? (no data transfer)
The symbol you highlighted does not mean that. I have that symbol and my station works fine.
I'm uploading from WLL, Davis WL-Cloud is another option but not Vantage Pro
- WLL.png (71.76 KiB) Viewed 7311 times
Vantage "Pro" is not an option for station choice.
Chose "Vantage" if you want to receive direct from your ISS for example through a logger attached to a console that it reads from the loggers IP address.
putteringalong
- Fresh Boarder
Thanks for your responses ... still no luck. My system makes connections to Weather Underground but does not upload weather data
logger (05.08.2025 08:50:17): message above repeats 2 times.
logger (05.08.2025 08:50:27): station 0 (Vantage), execution of setup script failed (console is not responding).
logger (05.08.2025 08:50:27): station 0 (Vantage), internal logger activated.
logger (05.08.2025 08:50:27): station 0 (Vantage), syncing.
logger (05.08.2025 08:50:27): station 0 (Vantage), gettime request sent.
Is you ISS really station 0? default is 1, if I'm right
Main Station is "0"
See attached.
See attached.
logger (05.08.2025 12:48:14): station 0 (Vantage), no need to update console date/time.
logger (05.08.2025 12:48:14): station 0 (Vantage), setup script executed.
logger (05.08.2025 12:48:14): station 0 (Vantage), internal logger activated.
logger (05.08.2025 12:48:14): station 0 (Vantage), syncing.
logger (05.08.2025 12:48:24): station 0 (Vantage), gettime request sent.
logger (05.08.2025 12:48:24): station 0 (Vantage), no Vantage time offset.
logger (05.08.2025 12:48:24): station 0 (Vantage), eeprom request sent.
logger (05.08.2025 12:48:24): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (05.08.2025 12:48:24): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (05.08.2025 12:48:24): station 0 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (05.08.2025 12:48:24): station 0 (Vantage), firmware version request sent.
logger (05.08.2025 12:48:24): station 0 (Vantage), firmware version 3.88 (supports LOOP2)
logger (05.08.2025 12:48:24): station 0 (Vantage), no reading of Vantage's internal logger.
logger (05.08.2025 12:48:29): sensors are now providing data.
logger (05.08.2025 12:48:29): services started.- Attachments
- Sta0.jpg (86.96 KiB) Viewed 7271 times
It just tells that there is no Davis Console or Envoy connected via USB. You can still select it and connect to it via TCP/IP if you have a WLIP installed to the Console/Envoy.HAPE wrote: Mon Aug 04, 2025 6:33 pm I'm uploading from WLL, Davis WL-Cloud is another option but not Vantage Pro
putteringalong
- Fresh Boarder
Let me wipe the egg on my face off....
As I was straightening my office a few weeks ago I accidentally dropped my console on the floor
This morning I decide to do a complete reboot which requires removing a battery from the console...I discovered that the Ethernet adapter had been jarred lose from its port I was still getting a flashing green light the adapter and was getting "updates" to Weather Underground (just time stamps, no data)
Once I put everything back together it started working as it should...many thanks to those who replied to my query
Wayne
Wayne
