Pro2 Export Rain Fall Is Zero
Car54
Post by Car54 »
I used the standard-imp.exp template to export the weather data from yesterday. All the data looks good, except the rain sums are all zero.
Here's a section of the exported data showing zero rain:
And here's a screen shot showing there was rain:
Is there something I'm doing wrong?
VP2+ Nano SD & Pro2
Re: Pro2 Export Rain Fall Is Zero
You need to have "store per-minute data" enabled on "Database - Admin" tab. Otherwise only hourly data is permanently stored. When you switch to export of hourly data it should be in sync what you see in the database.
