did you try to use the ID without the leading zeros ?
And "Serial" instead of "USB Serial".
At the RF level the transmission protocol of the WS-5000-ARRAY should be the same as the WS80 as far as weather data are concerned.
An Ecowitt console can receive a WS-5000-ARRAY - then the SDR interface of Meteobridge should also be able to do this.
my station panel looks different ...
A Pro2 reads the RF signal directly without extra Meteostick hardware - as far as I understand it, it uses a Meteostick software emulation.
- MB-Pro2-direct-RF.jpg (42.4 KiB) Viewed 1434 times
Your picture looks like a Pro or RPi or NANO device with an added Meteostick
Maybe your subject is incorrect and you don't have/use a Pro2 ...
