Pro2, Davis and adding Ecowitt
meexiles
Post by meexiles »
Hi there,
I have a Pro2 setup and sending Davis weather sensor data successfully to a number of weather sites. I recently added an Ecowitt hub and that is sending data to the Pro2 successfully. My question is, is there a tutorial/howto/specific instructions regarding how one might add additional sensor data to the weather site uploads? I see a lot of Meteobridge documentation but I am having difficulty putting it all together in a coherent process for enable the functionality I am looking for.
Thanks very much for your help!
davidmc36
Re: Pro2, Davis and adding Ecowitt
Post by davidmc36 »
Ecowitt Hub sending data to Pro2?
What do you mean by that?
grwkak
Post by grwkak »
The Ecowitt gateways can send data to the meteobridge (additional weather station tab). I suspect that is what is being referenced here.
Guy
grwkak
Post by grwkak »
meexiles wrote: Wed Mar 18, 2026 7:38 pm Hi there,
What data do you want to send and where?
Guy
meexiles
Post by meexiles »
I am interested in sending the soil moisture and temperature, along with the lightning strike data assuming any site that accepts it.
I would propose to do it the other way round. Is there a specific network that is able to evaluate some kind of data that your station is providing but does not get uploaded? Having this specific situation, we might be able to help.
In general data mapped to "soil0hum", "soil0temp", "lgt0total", etc is used for sending to weather networks. You can do mapping of available physical sensors to these logical sensor names on "Station - Mapping" tab.
azchrisf
Post by azchrisf »
Most networks only accept a certain subset of data. Generally, when you want to send additional things like Lightning counts, Soil moisture, etc. you need to setup your own webpage to show the extra data you're collecting. I seem to remember AWEKAS used to accept Soil moisture - you might want to look into that.
