Moving to a Raspberry Pi Setup. **solved**
Robbie936
Post by Robbie936 »
My meteobridge pro has become unreliable, freezing pi for some reason so i want to build a raspberry pi equivalent.
I've purchased the pi and downloaded the meteo image.
The writing to the SD card looks straight forward, how do i transfer all of my data records to the new setup?
Any tips/tricks would be appreciared.
Thank you
Robbie936
Re: Moving to a Raspberry Pi Setup
Post by Robbie936 »
I've made up a set of instructions using chatgpt, they will suffice.
You mainly have to backup/restore settings on "System - Admin" tab. Then doing a backup/restore of the database on "Database - Admin" tab. Last step is to move templates, grafph definitions etc from the PRO SMB folder to the RPI folders.
Robbie936
Post by Robbie936 »
Thanks admin, i missed the part about templates
