Possible Newbie
G4MHJ
Possible Newbie
Post by G4MHJ »
By way of introduction I have been running a weather station using a Davis Vantage Pro2+ for about 10 years with earlier weather stations before that. I have always used Weather Display software with a PC running 24/7. I am now on my 4th PC and the low power of a meteobridge appeals to me. Currently my ISS communicates wirelessly to a Console in my lounge and wirelessly to an Envoy with a logger (initially a serial but now a usb).My router is in the same room as the envoy. There seems to be three versions of meteobridge (nano, black and red). I am tempted to go for the red version if only to bypass the envoy and as an insurance policy should that ever fail. I have just introduced a trial Meteotemplates on my website so I would want this to continue without too much interruption. Am I on the right lines - has anybody else have gone through this change of hardware?
liamwilliams
Re: Possible Newbie
Post by liamwilliams »
Your plan sounds reasonable, but I’d verify two things before buying: whether the red Meteobridge model you’re considering includes the Davis RF receiver needed to read the ISS directly, and whether its upload method fits your Meteotemplate setup. If both check out, running it alongside Weather Display for a few days is a low-risk way to confirm data and website updates before making it the main path. The Envoy then becomes optional rather than essential.
Re: Possible Newbie
G4MHJ wrote: Fri Aug 24, 2018 10:29 pm ... Currently my ISS communicates wirelessly to a Console in my lounge and wirelessly to an Envoy with a logger (initially a serial but now a usb).My router is in the same room as the envoy. There seems to be three versions of meteobridge (nano, black and red). I am tempted to go for the red version if only to bypass the envoy and as an insurance policy should that ever fail. ....
Just to clarify the original MBPro were Black & Red, Red being the RF version, Black a non RF version, both are basically superseded (but still supported) by the MBPro2 which is Black but does everything the old Black & red did, just a lot better.
The Nano/NanoSD fits into a Davis console or Envoy and does much the same things as the MBPro2 except the Nano is solely WiFi not Ethernet/WiFi like the MBPro2. If you ISS is some distance from your stations then the Nano gets the same RF reception as your current Console.Envoy does, the MBPro2 RF reception distance is typically less than a Davis console but can receive a re-transmit from a Davis console
gwhit_s11
Re: Possible Newbie
Post by gwhit_s11 »
Mattk wrote:Just to clarify the original MBPro were Black & Red, Red being the RF version, Black a non RF version, both are basically superseded (but still supported) by the MBPro2 which is Black but does everything the old Black & red did, just a lot better.
Mattk, cheers for that... I reckon Nano's the safer bet if the ISS is far from the house.
