Webcam credential error. **solved**
captgadget
Post by captgadget »
In my Meteobridge under webcam it shows Error: Camera URL not providing data: https://xxx.xxx.x.xx/cgi-bin/api.cgi?cm ... &password=. However,Image when I go to my Meteobridge Aurora the correct picture is showing in there so what in the world is happening to me?
captgadget
Re: Webcam credential error
Whoa! I'm totally wrong here. I went to Aurora, clicked the red button in the lower left corner of the photo and that is the wrong photo. The right temperature is showing over an old photo so I still have a problem that I don't how to fix.
gwhit_s11
Post by gwhit_s11 »
captgadget wrote:The right temperature is showing over an old photo so I still have a problem that I don't how to fix.
captgadget, I had something similar with mine ages ago... turned out Meteobridge was just caching the old frame and bolting the live temp overlay on top, exactly what you described. What fixed it for me was clearing the cache via the "Live Image" settings and forcing a manual snapshot refresh, rather than mucking about with the camera URL itself since that bit was fine all along. Also worth checking if your camera's own snapshot interval is longer than what Meteobridge expects, mine was set to update every 10 mins and Meteobridge kept grabbing the same stale jpeg. Bit of a faff to track down to be fair, but once i sorted the refresh interval it never happened again.
captgadget
Thanks for the information. I will try that see if that works for me. Thank you
captgadget
gwhit_s11 I finally got that bugger. I had notice the other day that the password I was using was a duplicate and change one. So I did and that's when my problems started. I had the Reolink setup as a single camera and then the internet ai said I could run it in the home hub which I did and that did not work. So then I had remove from the hub and set it up as a stand alone came. Of course my password would not work so back out side, climb the step ladder and reset. Well by golly I finally got the new password and finally got it connected back up to ambient weather and then back on metobridge so now it send to awekas. What a nightmare but now it's all working.
gwhit_s11
Re: Webcam credential error. **solved**
Post by gwhit_s11 »
captgadget wrote:gwhit_s11 I finally got that bugger.
Glad you got there in the end mate, sounds proper hellish with the ladder and all. Reolink cameras are a right pain when you shift them between standalone and hub mode, had the exact same thing happen on my Defender's dash cam setup funnily enough, different gear but same daft password reset dance. Good job sorting it though, nothing worse than a nagging niggle like that hanging over you for days.
