2 stations with NSLU2?
plex
Post by plex »
Hi
Is't possible to use 2 stations with the NSLU2 - Hideki (USB) and RFXCOM (LAN) for additional sensors?
Re: 2 stations with NSLU2?
yep, no problem.
plex
Post by plex »
admin wrote:yep, no problem.
Thank you
plex
Post by plex »
Can I use a USB hub to connect both stations, or do I need to buy the more expensive lan version of the RFXCOM?
USB hub should work OK.
plex
Post by plex »
admin wrote:USB hub should work OK.
Cool 8)
I'll go for the RFXCOM right away.
Meteohub is very potentially, but I still wish better WDL compatibility - trend readings, and manual snow input. I hope this is future plans ;)
