Hi
Is't possible to use 2 stations with the NSLU2 - Hideki (USB) and RFXCOM (LAN) for additional sensors?
2 stations with NSLU2?
Re: 2 stations with NSLU2?
yep, no problem.
Thank youadmin wrote:yep, no problem.
Can I use a USB hub to connect both stations, or do I need to buy the more expensive lan version of the RFXCOM?
USB hub should work OK.
Cooladmin wrote:USB hub should work OK.
I'll go for the RFXCOM right away.
Meteohub is very potentially, but I still wish better WDL compatibility - trend readings, and manual snow input. I hope this is future plans
