No sensors assigned on RMS300
This is intended for WMR100, WMR200, WMRS200 and RMS300 specific topics
stein42
Post by stein42 »
Dear all
I just start configuration of Meteohub installed on NSLU2 and I am using RMS300 as a weather station with 3 wireless sensors (humidity and temperature).
But there's a problem with sensors connection.
Pictures will be better than large description so here are screen shots of meteohub :
Do you have an idea ?
Re: No sensors assigned on RMS300
rms300 should detected as usb hid device. your second screen dump shows that this is not the case.
what does the dmesg log on log files screen say? the list of connected usb devices is the one i am looking for insight the log.
stein42
Post by stein42 »
Oh that's strange because at the beginning was detected as usb hid device.
Apparently it dissapeared after RMS300 reset I did in order to retrieve sensors (I read somewhere that it coould be useful).
Nevertheless here is the dmesg log :
DMESG:
<5>Linux version 2.6.21.7 (slug@otto) (gcc version 4.1.2) #1 PREEMPT Mon Dec 24 23:12:24 UTC 2007
<4>CPU: XScale-IXP42x Family [690541f1] revision 1 (ARMv5TE), cr=000039ff
<4>Machine: Linksys NSLU2
<4>Memory policy: ECC disabled, Data cache writeback
<7>On node 0 totalpages: 8192
<7>  DMA zone: 64 pages used for memmap
<7>  DMA zone: 0 pages reserved
<7>  DMA zone: 8128 pages, LIFO batch:0
<7>  Normal zone: 0 pages used for memmap
<4>CPU0: D VIVT undefined 5 cache
<4>CPU0: I cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
<4>CPU0: D cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
<4>Built 1 zonelists.  Total pages: 8128
<5>Kernel command line: rtc-x1205.probe=0,0x6f console=ttyS0,115200n8 root=/dev/mtdblock4 rootfstype=jffs2 rw init=/linuxrc noirqdebug
<6>IRQ lockup detection disabled
<4>PID hash table entries: 128 (order: 7, 512 bytes)
<4>Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
<4>Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
<6>Memory: 32MB = 32MB total
<5>Memory: 30292KB available (1912K code, 153K data, 84K init)
<7>Calibrating delay loop... 132.71 BogoMIPS (lpj=663552)
<4>Mount-cache hash table entries: 512
<6>CPU: Testing write buffer coherency: ok
<6>NET: Registered protocol family 16
<4>IXP4xx: Using 16MiB expansion bus window size
<4>PCI: IXP4xx is host
<4>PCI: IXP4xx Using direct access for memory space
<6>PCI: bus0: Fast back to back transfers disabled
<6>dmabounce: registered device 0000:00:01.0 on pci bus
<6>dmabounce: registered device 0000:00:01.1 on pci bus
<6>dmabounce: registered device 0000:00:01.2 on pci bus
<5>SCSI subsystem initialized
<6>usbcore: registered new interface driver usbfs
<6>usbcore: registered new interface driver hub
<6>usbcore: registered new device driver usb
<6>Time: OSTS clocksource has been installed.
<6>NET: Registered protocol family 2
<4>IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
<4>TCP established hash table entries: 1024 (order: 1, 8192 bytes)
<4>TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
<6>TCP: Hash tables configured (established 1024 bind 1024)
<6>TCP reno registered
<4>NetWinder Floating Point Emulator V0.97 (double precision)
<6>JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
<6>io scheduler noop registered
<6>io scheduler deadline registered (default)
<6>Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
<6>serial8250.0: ttyS0 at MMIO 0xc8000000 (irq = 15) is a XScale
<6>serial8250.0: ttyS1 at MMIO 0xc8001000 (irq = 13) is a XScale
<4>RAMDISK driver initialized: 4 RAM disks of 10240K size 1024 blocksize
<6>IXP4XX NPE driver Version 0.3.0 initialized
<6>NFTL driver: nftlcore.c $Revision: 1.98 $, nftlmount.c $Revision: 1.41 $
<6>IXP4XX-Flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
<7>IXP4XX-Flash.0: Found an alias at 0x800000 for the chip at 0x0
<4> Intel/Sharp Extended Query Table at 0x0031
<6>Using buffer write method
<5>cfi_cmdset_0001: Erase suspend on write enabled
<7>erase region 0: offset=0x0,size=0x20000,blocks=64
<5>Searching for RedBoot partition table in IXP4XX-Flash.0 at offset 0x7e0000
<5>6 RedBoot partitions found on MTD device IXP4XX-Flash.0
<5>Creating 6 MTD partitions on "IXP4XX-Flash.0":
<5>0x00000000-0x00040000 : "RedBoot"
<6>nslu2 mac: 00:14:bf:63:45:e8
<5>0x00040000-0x00060000 : "SysConf"
<5>0x00060000-0x00080000 : "Loader"
<5>0x00080000-0x00180000 : "Kernel"
<5>0x00180000-0x007e0000 : "Flashdisk"
<5>0x007e0000-0x00800000 : "FIS directory"
<4>npe: searching for firmware...
<6>npe: found at 0x1c010, IXP425/NPE-B func: 00, rev: 2.1, size: 11964, id: 01000201
<6>Image loaded to NPE-B Func:0, Rel: 2:1, Status: 82c00000
<6>Initializing USB Mass Storage driver...
<6>usbcore: registered new interface driver usb-storage
<6>USB Mass Storage support registered.
<6>input: ixp4xx beeper as /class/input/input0
<6>i2c /dev entries driver
<6>x1205 0-006f: chip found, driver version 1.0.7
<6>x1205 0-006f: rtc core: registered x1205 as rtc0
<3>x1205 0-006f: power failure detected, please set the clock
<6>Registered led device: ready
<6>Registered led device: status
<6>Registered led device: disk-1
<6>Registered led device: disk-2
<6>TCP cubic registered
<6>NET: Registered protocol family 17
<6>XScale DSP coprocessor detected.
<3>x1205 0-006f: hctosys: invalid date/time
<4>VFS: Mounted root (jffs2 filesystem).
<6>Freeing init memory: 84K
<4>PCI: enabling device 0000:00:01.2 (0140 -> 0142)
<6>ehci_hcd 0000:00:01.2: EHCI Host Controller
<6>ehci_hcd 0000:00:01.2: new USB bus registered, assigned bus number 1
<6>ehci_hcd 0000:00:01.2: irq 26, io mem 0x48002000
<6>ehci_hcd 0000:00:01.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
<6>usb usb1: configuration #1 chosen from 1 choice
<6>hub 1-0:1.0: USB hub found
<6>hub 1-0:1.0: 5 ports detected
<7>ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
<4>PCI: enabling device 0000:00:01.0 (0140 -> 0142)
<6>ohci_hcd 0000:00:01.0: OHCI Host Controller
<6>ohci_hcd 0000:00:01.0: new USB bus registered, assigned bus number 2
<6>ohci_hcd 0000:00:01.0: irq 28, io mem 0x48000000
<6>usb usb2: configuration #1 chosen from 1 choice
<6>hub 2-0:1.0: USB hub found
<6>hub 2-0:1.0: 3 ports detected
<6>usb 1-2: new high speed USB device using ehci_hcd and address 2
<4>PCI: enabling device 0000:00:01.1 (0140 -> 0142)
<6>ohci_hcd 0000:00:01.1: OHCI Host Controller
<6>ohci_hcd 0000:00:01.1: new USB bus registered, assigned bus number 3
<6>ohci_hcd 0000:00:01.1: irq 27, io mem 0x48001000
<6>usb usb3: configuration #1 chosen from 1 choice
<6>hub 3-0:1.0: USB hub found
<6>hub 3-0:1.0: 2 ports detected
<6>usb 1-2: configuration #1 chosen from 1 choice
<6>scsi0 : SCSI emulation for USB Mass Storage devices
<7>usb-storage: device found at 2
<7>usb-storage: waiting for device to settle before scanning
<5>scsi 0:0:0:0: Direct-Access              Patriot Memory   PMAP PQ: 0 ANSI: 0 CCS
<5>SCSI device sda: 8060928 512-byte hdwr sectors (4127 MB)
<5>sda: Write Protect is off
<7>sda: Mode Sense: 23 00 00 00
<3>sda: assuming drive cache: write through
<6> sda: sda1 sda2 sda3
<5>sd 0:0:0:0: Attached scsi removable disk sda
<7>usb-storage: device scan complete
<6>kjournald starting.  Commit interval 5 seconds
<4>EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
<6>EXT3 FS on sda1, internal journal
<6>EXT3-fs: mounted filesystem with ordered data mode.
<6>IXP4XX Q Manager 0.2.1 initialized.
<6>ixp4xx_mac driver 0.3.1: eth0 on NPE-B with PHY[1] initialized
<6>EXT3 FS on sda3, internal journal
<6>Adding 131064k swap on /dev/sda2.  Priority:-1 extents:1 across:131064k
<6>eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
<7>Link of eth0 is full-duplex
<4>IXP4xx Watchdog Timer: heartbeat 60 sec
<6>usbcore: registered new interface driver usbserial
<6>drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
<6>usbcore: registered new interface driver usbserial_generic
<6>drivers/usb/serial/usb-serial.c: USB Serial Driver core
<6>drivers/usb/serial/usb-serial.c: USB Serial support registered for pl2303
<6>usbcore: registered new interface driver pl2303
<6>drivers/usb/serial/pl2303.c: Prolific PL2303 USB to serial adaptor driver
<6>drivers/usb/serial/usb-serial.c: USB Serial support registered for cp2101
<6>usbcore: registered new interface driver cp2101
<6>drivers/usb/serial/cp2101.c: Silicon Labs CP2101/CP2102 RS232 serial adaptor driver v0.07
<6>drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI USB Serial Device
<6>usbcore: registered new interface driver ftdi_sio
<6>drivers/usb/serial/ftdi_sio.c: v1.4.3:USB FTDI Serial Converters Driver
USB:
Bus 1 Device 2: ID 13fe:1e00
Bus 1 Device 1: ID 0000:0000
Bus 2 Device 1: ID 0000:0000
Bus 3 Device 1: ID 0000:0000
PCI:
00:01.0 0c03: 1033:0035 (rev 43)
00:01.1 0c03: 1033:0035 (rev 43)
00:01.2 0c03: 1033:00e0 (rev 04)
iPartitions:
Filesystem           1k-blocks      Used Available Use% Mounted on
/dev/sda1               412524    219405    171821  56% /
/dev/mtdblock4            6528      5624       904  86% /initrd
/dev/sda1               412524    219405    171821  56% /dev/.static/dev
tmpfs                     2048        28      2020   1% /dev
/dev/sda3              3256488     66584   3024480   2% /data
tmpfs                    15188       960     14228   6% /var/volatile
tmpfs                    15188         0     15188   0% /dev/shm
Process:
  PID  Uid     VmSize Stat Command
    1 root        572 S   init [3]
    2 root            SWN [ksoftirqd/0]
    3 root            SW< [events/0]
    4 root            SW< [khelper]
    5 root            SW< [kthread]
   38 root            SW< [kblockd/0]
   41 root            SW< [khubd]
   56 root            SW  [pdflush]
   57 root            SW  [pdflush]
   58 root            SW< [kswapd0]
   59 root            SW< [aio/0]
   81 root            SW  [mtdblockd]
   82 root            SW  [nftld]
  167 root            SW< [scsi_eh_0]
  168 root            SW< [usb-storage]
  192 root            SW< [kjournald]
  238 root        616 S < udevd --daemon
  599 root            SW< [kjournald]
  892 root        252 S   udhcpc -n -p /var/run/udhcpc.eth0.pid -i eth0
  917 daemon      424 S   /sbin/portmap
  973 root        448 S   /home/meteohub/watchdog
  980 root        940 S   /home/meteohub/meteoschedule /dev/meteohub
 1040 root        908 S   /usr/sbin/sshd
 1055 root       2052 S N /usr/sbin/smbd
 1058 root       1140 S   /usr/sbin/nmbd
 1068 root       1020 S   /usr/sbin/thttpd -C /etc/thttpd.conf
 1074 root        808 S   /usr/sbin/thttpdbackup -C /etc/thttpd-backup.conf
 1081 root       1588 S N /usr/sbin/smbd
 1082 root        932 S   /home/meteohub/meteonet -r
 1088 root       1024 S   /usr/bin/ntpd -p /var/run/ntpd.pid -g
 1098 root        556 S   /usr/bin/rsync /var/run/rsyncd.pid --daemon
 1105 root        692 S   /usr/sbin/cron
 1132 root        544 S   /sbin/getty 115200 ttyS0
11338 root       1472 S < meteohub.cgi
11341 root        540 R   /usr/sbin/thttpd -C /etc/thttpd.conf
11366 root        796 R < ps w
stein42
Post by stein42 »
No idea where is the problem ?
stein42
Post by stein42 »
I am totally stopped by this problem...
Nobody can help ?
Thanks by advance
stein42
Post by stein42 »
I am sorry my USB wire was not well plugged on my weather station and now I have something in "Weather station".
But I still have an issue with sensors because in "Sensors" page I have following message :
Warning: Weather station does not have a sensor assigned on "Sensors" page
Warning: Data logging has been halted.
And in 'Log files" I have this :
DMESG:
<6>usb 2-1: new low speed USB device using ohci_hcd and address 2
<6>usb 2-1: configuration #1 chosen from 1 choice
<6>usbcore: registered new interface driver hiddev
<6>hiddev96: USB HID v1.10 Device [ ] on usb-0000:00:01.0-1
<6>usbcore: registered new interface driver usbhid
<6>drivers/usb/input/hid-core.c: v2.6:USB HID core driver
<6>usb 2-1: USB disconnect, address 2
<6>usb 2-1: new low speed USB device using ohci_hcd and address 3
USB:
Bus 2 Device 3: ID 0fde:ca01
PCI:
iPartitions:
/dev/sda1               412524    219152    172074  56% /
/dev/sda1               412524    219152    172074  56% /dev/.static/dev
tmpfs                     2048        32      2016   2% /dev
/dev/sda3              3256488     66568   3024496   2% /data
tmpfs                    15188       964     14224   6% /var/volatile
Process:
    2 root            RWN [ksoftirqd/0]
   41 root            SW< [khubd]
   59 root            SW< [aio/0]
   82 root            SW  [nftld]
  592 root            SW< [kjournald]
  818 root        616 S   /sbin/syslogd -n -O /var/log/messages -m 20
  820 root        612 S   /sbin/klogd -n
  891 root        252 S   udhcpc -n -p /var/run/udhcpc.eth0.pid -i eth0
  916 daemon      424 S   /sbin/portmap
  972 root        304 S   /home/meteohub/watchdog
  974 root        248 S   /bin/sh /etc/rc.boot/initsensors
  975 root        540 S   sleep 300
  979 root        824 S   /home/meteohub/meteoschedule /dev/meteohub
 1039 root        908 S   /usr/sbin/sshd
 1054 root       2052 S N /usr/sbin/smbd
 1057 root       1140 S   /usr/sbin/nmbd
 1067 root        992 S   /usr/sbin/thttpd -C /etc/thttpd.conf
 1073 root        772 S   /usr/sbin/thttpdbackup -C /etc/thttpd-backup.conf
 1080 root        932 S   /home/meteohub/meteonet -r
 1086 root       1588 S N /usr/sbin/smbd
 1087 root       1024 S   /usr/bin/ntpd -p /var/run/ntpd.pid -g
 1099 root        556 S   /usr/bin/rsync /var/run/rsyncd.pid --daemon
 1100 root        692 S   /usr/sbin/cron
 1131 root        544 S   /sbin/getty 115200 ttyS0
 1680 root       1472 S < meteohub.cgi
 1681 root            Z   [thttpd]
 1682 root        604 S   /usr/sbin/thttpd -C /etc/thttpd.conf
 1707 root        796 R < ps w
I really don't understand where the problem is...
Please do a reboot and follow steps describen here: http://wiki.meteohub.de/Setup_Guide
stein42
Post by stein42 »
OK I just tried but it's exactly the same story.
Weather station is detected but not sensors...
Please browse to "http://ip-of-your-meteohub/cgi-bin/help.cgi".
This will give me a ssh tunnel to login to your meteohub.
stein42
Post by stein42 »
That's done !!
nope, no result here. What does it print in your browser, when doing that?
stein42
Post by stein42 »
open ssh tunnel to meteohub support
done
stein42
Post by stein42 »
I had a bip on my NSLU2.
Apparently you are working on it !!
please update to 4.7f.
stein42
Post by stein42 »
OK I will try I keep you informed
