PHP Enter the name of the winds according to the tag [wind0dir-act=endir:--]
Re: PHP Enter the name of the winds according to the tag [wind0dir-act=endir:--]
Cavaliere wrote: Sun Dec 18, 2022 1:39 pm I just tried your changes by renaming the Dashboard1.php file to Dashboard1.txt
only now on the page http://www.ombarcellonapg.com/saratoga/dashboard2.php , the dashboard.php file remains empty after I reload the template, is this normal? Do I need to make any changes?
can't see anything anymore why? Have I reloaded the model?
I also enclose the changes to the meteobridge below.
There are dozens of php errors in the script as all PHP code is now executed.
=> HTTP ERROR 500, meaning the script fails, the first one is at
if(( $valore[th0temp-delta10] > 0.0 ) ){ $src = "trendUp.png"; }
<b>Fatal error</b>: Uncaught Error: Undefined constant &quot;th0temp&quot; in . . . .php:159
Stack trace:
#1 {main}
thrown in <b>/. . . .php</b> on line <b>159</b><br />
I cleaned the .txt file, it generates no php errors.Just try it and if it works, you can see the differences with your version.
1234567.txt.zip
(2.49 KiB) Downloaded 134 times
Cavaliere
Post by Cavaliere »
Thanks a lot for the help wim,
I've seen all the fixes you've made to the file, and now I'm trying it out and it seems to work for almost everything.
The temperature trend images do not appear, maybe because they are too big 250x250px?
<?php
$valore = "th0temp-delta10";
if(( $valore > 0.0 ) ){ $src = "trendUp.png"; }
if(( $valore = 0.0 ) ){ $src = "trendNeutral.png"; }
if(( $valore < 0.0 ) ){ $src = "trendDown.png"; }
<img src="<?php echo $src; ?>" alt="" />
I tried to correct the temperature trend tag like this, but it still doesn't work, the images are not visible (the images are in the same folder as the dashboard file):
<div style="width:100px; height:30px; padding:5x; font-size:15px; margin:auto; padding-left: 20px; color: #FFFFFF;">[th0temp-delta10:--]&deg;C </div>
</td>
<?php
$valore = "[th0temp-delta10:--]";
To avoid repeating php errors or in any case reading what the errors are, can I put a php string that you gave me a few days ago? but I can't find it anymore....and where to insert it? And sorry for the dumb question, how did you change the color inside the php script?
Cavaliere wrote: Sun Dec 18, 2022 2:54 pm . . .
Use the attached code always at the beginning of a PHP script.
It allows two things:
  • display the php-source even when started in a browser
  • switch error reporting on by adding ?test at the url
You will see that similar code is in a lot of scripts, f.i. Saratoga-template sripts, all Leuven-template scripts, all PWS_Dashboard scripts.
This makes helping with debugging a lot easier.
Succes,
<?php
if (isset($_REQUEST['sce']) && strtolower($_REQUEST['sce']) == 'view' ) {
   header('Pragma: public');
   header('Cache-Control: private');
   header('Cache-Control: no-cache, must-revalidate');
   header('Content-type: text/plain; charset=UTF-8');
   header('Accept-Ranges: bytes');
   header('Content-Length: '.filesize(__FILE__));
   header('Connection: close');
   readfile(__FILE__);
   exit;}
elseif (!isset ($_REQUEST['test']))
     {  ini_set('display_errors', 0);      error_reporting(0);}
else {  ini_set('display_errors', 'On');   error_reporting(E_ALL); }
before_all.txt.zip
(1.03 KiB) Downloaded 171 times
Cavaliere
Post by Cavaliere »
Perfect, I inserted it before the table began, after the css part, but it could also be inserted before, to avoid some css code errors, since I'm inexperienced.
Now it doesn't report any errors, but I can't see any image in the temperature block why do you think?
1. Move the text for sce=view to the beginning of the file.
2. Typing error from me, remove all text after the ?>
Should look like this
<?php
   readfile(__FILE__);
   exit;}
3. The image is not displayed because the value is 0.0
First line compares for greater
Last line compares for less
But the second line assigns a zero to $valore
Compare for equal uses ==
if(  $valore == 0.0 )  { $src = "trendNeutral.png"; }
Also remove the xtra ( and ), they do nothing
if ( $valore > 0.0 )  { $src = "trendUp.png"; }
if ( $valore == 0.0 ) { $src = "trendNeutral.png"; }
if ( $valore < 0.0 )  { $src = "trendDown.png"; }
4. You have to add the width and height as the images are to big
Cavaliere
Post by Cavaliere »
I made the modifications you indicated and I made these modifications, but the images are still not visible, why?
<?php
if( $valore > 0.0 )  { $src = "trendUp.png" ; }
if( $valore < 0.0 )  { $src = "trendDown.png"; }
<img src="<?php echo $src; ?>" width="30" height="30" />
HTML problem: The img is not inside the <td> . . . </td>
The browser does not know what you want. It just skipped the <img. part.
Although web-browsers are very forgiving, they can not solve every language error.
When you validate your HTML the validator stops also at the <img>
https://validator.w3.org/nu/?doc=https: ... board2.php
Solutions:
1. Go step by step and and test between each step
2. Use a validator to check your html => https://validator.w3.org/
3. HTML is a language and as every new language you have to learn the basics
== Buy a book such as "HTML and CSS for Dummies" if it is available in Italian or
== HTML CSS: La guida completa al web design per progettare e sviluppare siti web in 7 giorni Copertina flessibile – 15 giugno
== Use the website https://html.com/
4. always test with different browsers, at least Chrome and FF.
If you want to build your own websites, you have to understand and use two new languages, HTML and PHP.
That takes time but it is a very interesting and rewarding hobby.
If you just want a small html/php page , find a IT-student who will be happy to do it for you for a small fee.
Succes, Wim
Cavaliere
Post by Cavaliere »
wvdkuil wrote: Mon Dec 19, 2022 10:20 am HTML problem: The img is not inside the <td> . . . </td>
Solutions:
Succes, Wim
Ok thanks
