Nano SD locking up. **solved**
Re: Nano SD locking up
Mitch56338 wrote: Tue May 09, 2023 4:56 am I have a 1amp 5volt dc power supply and batteries tested at 1.58VDC. The VP2 came with the 1amp USB power supply. I did buy a 3amp 5VDC. Would that be enough?
1A is enough but the Davis power supply might not hold the 5V as precisely when giving a bit more amps as that is irrelevant for the console. A proper 5v 1A+ power supply might do better when challenged a bit.
Mitch56338
Post by Mitch56338 »
Update, Still running with the 3 amp power supply.
Platform: Meteobridge NANO SD
RAM: 125 MB total, 62 MB free (50% used)
Storage: swissbit SLC, 1.8 GB total, 1.7 GB free (9% used, 2.8 yrs)
SW Version: Meteobridge 5.6 (Apr 30 2023, build 4529), FW 1.4
Uptime: 9 days, 22 hours, 16 minutes Buffer: 1 items (0%)
Looks like I will be retiring the PC at the end of this month.
BigAlT
Post by BigAlT »
The easiest way to upgrade the power supply without having to do any wiring is to purchase the Davis 6627 USB to Davis Plug Power Cord and a 3 to 4 Amp USB Power Supply. It’s just plug & play.
tomas21
Re: Nano SD locking up. **solved**
Post by tomas21 »
@BigAIT do you have any recommendations on the USB power supply... will something like this work?
2.4A USB Setup
