Weather34 Template - Daily charts. **solved**
Re: Weather34 Template - Daily charts
Edzo1 wrote: Sun Jun 16, 2024 5:51 am Greetings,
I think I have a similar issue as Matteo. I recently uploaded the new Aurora Master File and everything looks great except I'm having issues with the Charts ...., my 2024 Charts are missing March and April, and the June Chart skips June 12 and displays June 14 twice. I have deleted the Master file from my hosting service and reinstalled thinking it might fix the problem but that didn't help. I'm probably missing something simple but I don't know what. Thanks for any assistance anyone can provide!
Ed
https://scituatewx.com
take out the retries, so 0 retries
maybe you also have server availability problems, so that the calls of chartstoday.php and weather34-chart-end-of-day.php are not always executed? in your daily chart you have a rough rasterization, normally every 10th minute should be a value in the chart.
Edzo1
Post by Edzo1 »
Thank you Torsten. I set to "no retries" but no change. And I see what you mean now about the frequency of the uploads for the daily Charts. Instead of every full 10 minutes, my charts are updating every 60-70 minutes. Do you have any other advice on what to do next? I think I'll begin by reaching out to my Web Host, Hostgator, and ask them if everything is OK on their end. Thanks again for your help!
Ed
Edzo1
Post by Edzo1 »
I contacted my web host and they said there were no issues to report.
Does anyone have any ideas why my daily charts are updating every 60-70 minutes, and not every full 10 minutes per the Meteobridge Event Definition?
Events SS2.jpg (89.89 KiB) Viewed 4923 times
I still think that your web host is responsible for this.
There may also be some setting in your web space, but I don't know much about that.
Try a different provider.
Edzo1
Post by Edzo1 »
:roll: frustrating! ...., thanks for the reply Torsten.
Cavaliere
Post by Cavaliere »
HI,
a few days ago I updated the template, and I put the number 9, but I can't see the graphs at the bottom of each parameter, why?
Cavaliere
Post by Cavaliere »
Could someone please give me some support?
Cavaliere wrote: Mon Jul 29, 2024 9:51 pm Could someone please give me some support?
good afternoon , firstly sincere apologies but I have been down here in south west Turkiye since 1st week of June and Im not due back in Istanbul where I live a majority of the year till 15th August .
Until then I can not offer any reliable support , but let me just say to give me any chance of resolving any issues that arise a URL to website is the basic requirement , often i can either replicate or pin point the issue simply by looking at the URL browser response tab of Safari in developer mode.
as above sorry for any inconvenience . brian
Cavaliere
Post by Cavaliere »
Hi Brian, sorry you're right, I didn't put the direct link to the template, where I have the problem of the graphs not appearing.
Here you go, thanks a lot in advance
https://www.ombarcellonapg.com/wdisplay ... /index.php
Cavaliere wrote: Sun Aug 04, 2024 11:04 am Hi Brian, sorry you're right, I didn't put the direct link to the template, where I have the problem of the graphs not appearing.
hi good evening a quick look shows you're not running the charts cron via meteobridge see your display now . i simply kick the charts for today twice hence 2 bars are display.
1. you need to setup the services for current day using yourdomain/chartstoday.php
2. you need to setup the services for end of day using yourdomain/weather34-chart-end-of-day.php
https://www.mediafire.com/file/fpcf73z9 ... e.zip/file setup guide
screenshot of the pdf setup for charts but this in the download link above .
Screenshot at Aug 04 20-57-23.png (166.77 KiB) Viewed 4571 times
have a good read of the setup guide
you can also find the setup guides in the master down
brian ..
Cavaliere
Post by Cavaliere »
I corrected the address of the individual graph files, which were wrong, and also the stationcron address, perhaps it takes more time and more data than several days. But in layout 9 you can't see the graphs below, is this normal?
Cavaliere wrote: Tue Aug 06, 2024 9:54 am Hi Brian,
hi good afternoon it looks like you have it running ok i can see the chart data in theme 9 ..
screenshots of your url...brian
Cavaliere
Post by Cavaliere »
Ok yes everything seems to be going well, thank you very much!
