Aurora 2026 Rev-4.4X Release
Re: Aurora 2026 Rev-4.4L Release
Simple-Update-Aurora-2026-August2026-4.4L
https://www.mediafire.com/file/hnabcg8o ... L.zip/file
Master-Aurora-2026-4.4L-August2026
https://www.mediafire.com/file/75fxrijh ... 6.zip/file
1.Fix for meteor shower dates
2.Adds metar SVG icon to module
3.Fix missing rain data when none/zero forecasted will show probability
.TESTING ..merrysky.net API https://merrysky.net/forecast/40.9948522,28.5403387 to eventually replace WU FORECAST module and popup screen
Screenshot 2026-08-24 at 09.45.59.png (1.23 MiB) Viewed 1045 times
woolfg
Post by woolfg »
Hi
I dont seem to be getting any lightning data showing either for today or in the charts - I have recorded 18 strikes this month on my Tempest
You can see my site here http://ringwoodweather.ddns.net:8000/Weather34/
I am using a WeatherFlow Tempest for measuring lightning which according to the settings should work although my main site above is a Davis Vantage Pro 2 using a Meteobridge Pro
I have attached a screenshot so any ideas would be much appreciated
Warm Wishes
Graham Woolf
Hello Graham
Has in previous years your site is not visible here in Istanbul (been like that for years) so not much i can do apart from asking is the data visible in meteobridge itself if so then I could adjust the template but without it being visible i dont have much chance
woolfg
Post by woolfg »
Hi Brian
I have attached a screenshot of my settings in Meteobridge
Now it maybe that they are not right and thats the problem but Im not sure either way
Warm Wishes
Graham
Good morning Graham
I’ll take a look but unfortunately lightning can be a tedious patient process due to the fact lightning in your region is sparse and realtime data is the key to getting it to function has expected. Does weatherflow tempest still use third party data in its lightning output which can be a bit misleading has the data is not directly detected by the hardware.
woolfg
Post by woolfg »
Hi Brian
As far as I am aware it measures lightning strikes directly
Warm wishes
Graham
ok Graham I'm going to guess because I can't see anything from your site (ps in this day and age HTTPS:// is standard !!!
I just did numerous false trigger of lightning which simulates weather flow output via meteobridge
is mb-lightning.php running ? http://ringwoodweather.ddns.net:8000/We ... htning.php
result
Screenshot 2026-08-31 at 12.02.40.png (100.13 KiB) Viewed 928 times
woolfg
Post by woolfg »
Hi Brian
Thanks I will try and get https up and running - for some reason my certificates cause me problems but I will have another go
I am running this on my meteobridge as a service
http://192.168.0.134:8000/Weather34/mbr ... ing.php?d=[lgt0energy-act:--] [lgt0dist-act:--] [lgt0total-nonzerotime:--] [lgt0total-daysum.0:--] [lgt0total-monthsum.0:--] [lgt0total-yearsum.0:--] [lgt0total-sum10.0:--]
Warm wishes
Graham
woolfg
Post by woolfg »
Hi Brian
In the event
Should I be mapping the physical lightning sensor or the logical - at the moment its using the logical sensor
Warm Wishes
Graham
Hello Graham
It is going to be difficult for me to do anything without some form of seeing the outcome , if you resolve your website visibility I could probably nail it in a couple of minutes. I apologise and no problem in helping if it was visible but bit like blind leading the blind scenario and outcome
woolfg
Post by woolfg »
Hi Brian
OK I will give it a go and get back to you
Warm Wishes
Graham
Re: Aurora 2026 Rev-4.4MRelease
Simple-Update-Aurora-2026-September-4.4M
https://www.mediafire.com/file/761d93r6 ... M.zip/file
Aurora-2026-September-4.4M-Master
https://www.mediafire.com/file/apzrrpub ... r.zip/file
1.Verified PHP 8.6 BETA 2
2.Fixed Moon Phase text positioning (full moon/new moon)
3.Added 2027 Lunar events
4.Fixed Meteor Next Event
Screenshot 2026-09-10 at 07.55.09.png (165.69 KiB) Viewed 741 times
Screenshot 2026-09-10 at 07.55.34.png (101.69 KiB) Viewed 741 times
Screenshot 2026-09-10 at 08.05.23.png (1.28 MiB) Viewed 734 times
Screenshot 2026-09-10 at 08.08.05.png (1.26 MiB) Viewed 733 times
lorenz1982
Re: Aurora 2026 Rev-4.4M Release
Post by lorenz1982 »
Hi, I wanted to report that the Meteobridge API module isn't updating correctly; it often stalls.
Screenshot 2026-09-11 084008.png (16.62 KiB) Viewed 713 times
https://meteoborgo.altervista.org/Auror ... 4-2026.php
MeteoBorgo: www.meteoborgo.it
fotogw
Re: Aurora Cloud: Not updating correctly
Post by fotogw »
Since last wednesday the MB Aurora cloud is not updating correctly, Today even only once. So i miss a lot of weather...
I'm running a Meteobridge Pro2, restarted and updated multiple times, no improvement.
Don't know if it is connected, but the time shown in the MB Aurora cloud screen seems to be in GMT, not GMT+2 as it should be here.
Scherm­afbeelding 2026-09-11 om 13.54.37.png (223.82 KiB) Viewed 706 times
Re: Aurora 2026 Rev-4.4Q Release
lorenz1982 wrote: Fri Sep 11, 2026 8:40 am Hi, I wanted to report that the Meteobridge API module isn't updating correctly; it often stalls.
Good morning
I have adjust the last two small modules (position 19/20) to update every 10 seconds that might reflect better for that particular module , I don't want to update all bottom modules to ten seconds has that might cause problems(heavy load) for those running of low resource hosting or free hosting services.
Simple-Update-Aurora-2026-September-4.4Q
https://www.mediafire.com/file/c33x0jbl ... Q.zip/file
Aurora-2026-September-4.4Q-Master
https://www.mediafire.com/file/kllwvgbv ... Q.zip/file
1. Adds lunar phases and events up to year 2030
2. Adjusted 10 seconds update intervals for last two small modules
Screenshot 2026-09-15 at 07.32.38.png (1.19 MiB) Viewed 650 times
@fotogw sorry I cannot help with Cloud internal version , simply there is no public direct file access or means of diagnosing from remote. please open another thread so Boris may be able to help ,also if you have requests for additional items for the cloud version again please open another thread . pre warning the Cloud version will produce many errors if the internal cloud version of PHP is updated to current release of PHP . There is no urgent purpose to update the current PHP version in the cloud unless security becomes an issue.
Brian...
