Lespius
Post by Lespius »
Hello Brian,
All good, very useful instructions and information.
Many thanks
Alain
http://www.meteo-cugy.ch/MBSMARTv2.0/index.php
weatherist34 wrote: Wed Jan 01, 2020 11:27 pm Hi as of January 1st smart updates are available to be used with version 2.0 onwards this was planned for some months to release updates via that method after January 1st.
install version 2.0 and thereafter you can use the simple updater if and when they are available .the current version 2.0 download as all the updates pre installed as of January 1st !
in the future simply download the update zip i.e 31FEB2020.zip and place it in the main folder where the template is installed on your server. the updater will find it and it will appear in the dropdown just select and click update.
don't use the updater for version 1.07A or earlier because the updater will only have a small amount of files with fixes for version 2.0 only.
This was was used for a short period in 1.07a to test and iron out any issues prior to January 1st 2020.
as it January 1st 2020 now or later the 2019 chart data is not used unless you modify the charts for your own personal use or preference to display last year or year before etc depending on many years you have been using I have it back to 2017 and sometime this year I will try and introduce charts to support previous years on a separate page like the alternative version charts but thats something for the future.
settings1.php is the file you need to keep a copy on your PC for keeping settings and using if you don't want to go through the setup procedure .just simply keep a copy on your desktop and upload it when you have done new install . No changes were made to the main settings1.php or setup screen.
Only the alternative layout had a minor change to setup screen based on 12/24 clock .
Im really sorry but as of tomorrow(Jan 2nd) morning Im not available for some weeks so I can't be of much assistance to help you or try and explain in easier terms.Ive done my best to prepare everything for January 1st 2020 and addressed the minor metric/non metric setting issues today but Im out of time for a while and could be longer I have had an offer of a 2 year deal to work on a project thankfully not weather related still digesting it and whether I want to make that commitment on a monday-friday basis kind of got used to my own time and doing things without obstacles of commitments to work schedules .
Sorry your confused or missing something but time is not on my side for now. Perhaps others can help there are quite a few knowledgeable experienced users around that have been a constant help for a few years now.
still confused ? probably even more so now :-) weather stuff is never straight forward in fact Im beginning to loathe it , it is a tedious task maintaining a template with all the complexity of non metric versus metric versus languages doesn't matter how hard I try always something pops it head up and think to myself how did that occur ,how did I mess that up because its generally me that screws up :-) .
can only say always allow a bit of time to learn and become accustom too to something new unfortunately Im not the best educator I just tend to do it rather than explain it . Brian...
no problem if i can edit a file on my ipad ill upload an update to fix nanosd uptime if less than one day alignment .your perfect chance to test the updater ill name it 02JAN2020.zip but might take me an hour or so to do .
weatherist34 wrote: Thu Jan 02, 2020 8:01 pm chuck I don't see anything in recent firmware releases related to that string in the API has been there almost a year so im really guessing its a change of year thingy but why some have it and some don't is the mystery and I really have no idea .
I did a little more checking and it appears that the error that is produced depends on the units. Selecting F on the template gives the 0 value for December and selecting C shows the string variable.
ok chuck + others I added a workaround if [rain0total-max@M1] is present in the API output it shows nothing best I can do from this end.
managed to add that to smart update just now.
Taylor
Post by Taylor »
Brian, Thanks for quick update!
rzelle-K1TTC
Post by rzelle-K1TTC »
Brian, Sorry you have to deal with these last minute .. My 2019 chating is doing this and back arrow throws a 404.
..Ron
2019 not charting.PNG (122.19 KiB) Viewed 5046 times
rzelle-K1TTC
My Bad missed the additional charts when I updated ... but back arrow is still throwing a 404 from the 2019 charts.
This is the issue with the back arrow
https://weather.k1ttc.com/console/index.php should be this https://weather.k1ttc.com/console/consoledavis.php
.. Ron
weatherist34 wrote: Thu Jan 02, 2020 11:09 pm ok chuck + others I added a workaround if [rain0total-max@M1] is present in the API output it shows nothing best I can do from this end.
No problem. I am going to leave it until tomorrow and see if it changes.
Great idea displaying the 2019 data on the Console Charts.
Best wishes,
good morning firstly big thank you to Peter for sending me a workaround fully coded that doesn't happen often so very much appreciated .
so the workaround uses yesterdays total value even if nothing recorded(0.0mm or in) as opposed to nothing shown at all as the last month rainfall total rollover from 2019 is not working as it should . it is this string [rain0total-max@M1] suddenly appearing in the output causing the issue which was never present or I recall ever seeing throughout 2019 otherwise Im sure it would have been made aware of and resolved.
this is not a template issue as the template only reads what is present in the API output from meteobridge however a workaround is probably the safest way going forward . I guess it was nieve of me to think no issues would arise through change of year and should have known better.
Ron yes sorry fixed my bad :-)
smart update 03JAN2020.zip contains above workaround and full download also has the work around applied .
I will leave the GitHub repo open until Sunday for those who reap the benefit of pulling down updates via an app.After that please use the smart updates via the info page at weather34 .
weatherist34 wrote: Fri Jan 03, 2020 10:15 am good morning firstly big thank you to Peter for sending me a workaround fully coded that doesn't happen often so very much appreciated .
Many thanks to you and Peter!
rzelle-K1TTC
Brian, Seeing this on my site now for Rain Almanac.
73s
..Ron
Rain Almanac Issue.PNG (71.25 KiB) Viewed 5014 times
hi ron
Ive loaded your MBrealtimeupload into my demo on laptop I can't reproduce this so Im at a loss .. I see that string is present in your API output instead of a value. Perhaps Ill just remove the whole last rainfall/last month feature and replace it with yesterdays total rainfall as I have no I idea why suddenly this error or string is suddenly appearing in the API instead of last months data value .More confusing it doesnt appear in all users API output .Once again this string
[rain0total-max@M1]
is not generated by the template it is generated by meteobridge api output which I have no control over.I can't fix something that I have no access to so other than remove the feature altogether is the only solution I can think of going forward.
screenshot of your data loaded in my laptop demo
03/01/2020 09:54:05 5.5 59.0 -1.9 0.9 0.4 217.0 0.0 2.3 1009.9 221.0 1 m/s C hPa mm 0.7 1009.4 9.9 9.9 4.3 22.4 35.0 5.6 4.7 5.6 20200103094305 2.7 20200103055616 1.3 20200103000001 3.6 20200103000040 1009.9 20200103094603 1008.0 20200103001704 4.2 2740 1.8 VOCORE2 -- 0.0 6.6 69.0 227.0 0.5 0.5 20200101000120 -6.4 20200102131139 -2.7 20200102234540 0.5 20200101000120 -6.4 20200102131139 0.0 68.0 20200103055728 57.0 20200103000009 -1.8 20200103091903 -3.0 20200103001450 5.4 59.0 -2.0 22.7 35 1.0 0.9 -- -- -- -- -- -- 156.0 66426 7.2 20200102150921 -2.1 20200102070530 7.2 20200102150921 -2.1 20200102070530 7.2 20200102150921 -2.1 20200102070530 6.7 20200102142139 9.4 20200101134651 9.4 20200101134651 4.3 9.9 20200101000052 9.9 20200101023212 156.0 20200103090959 473.0 20200102130357 552.0 20200101125559 552.0 20200101125559 20200103000026 1.4 20200102120739 1.4 20200101114011 1.4 20200101114011 -6.4 20200102131139 0 5.2 20200103094831 35.4 20190721145749 -15.4 20191208064914 25.9 20190720134923 -24.6 20191116144504 16.1 20191017120919 1013.3 20200102092203 1008.3 20200102234210 1013.3 20200102092203 999.8 20200101001302 1013.3 20200102092203 999.8 20200101001302 1040.9 20191212185607 974.9 20191017053506 612.6 4.2 2 53.7 09:08 12:00 -- 0.6 92.0 20200101000048 39.0 20200102132727 92.0 20200101000048 39.0 20200102132727 78.0 20200102070354 39.0 20200102132727 0.0 0.0 [rain0total-max@M1] 602.7 -- 5.5 1009.9 0.0 1.1 58.2 -1.9 0.0 59.0 2.7 1.1 20190709174443 20190709170359 20190709172913 20190709170239 20200101000052 250.0 7.2 20200102150921 -4.6 20200101211442 _Increasing clouds with little temperature change.
weatherist34 wrote: Fri Jan 03, 2020 5:24 pm hi ron
[rain0total-max@M1]
Ron/Brian,
I'm seeing the misalignment as well on Ron's site. I cleared cache and checked on Chrome, Firefox, Safari - Mac and Ipad. On my site it looks fine, but I have not had any rain.
Ron's
rzelle-K1TTC
Brian & Chuck,
Every PC I've run it on including iPad with Safari shows the error my NANO-SD's FW is as of Boris's latest release. Don't know either :-(
73s All
..Ron
I got the same problem, also the Font size is too big?
I also installed the last NANO-SD's FW and latest MB-Smart Version.
