The upload to pro.idokep.hu does not work!
Please check the upload procedure.
http get = http://pro.idokep.hu/sendws.php?user=us ... obridge&p=[thb0seapress-act.1:--]&hom=[th0temp-act.1:--]&rh=[th0hum-act.0:--]&szelero=[wind0avgwind-act.1:--]&szellokes=[wind0wind-max5.1:--]&szelirany=[wind0dir-act.0:--]&csap1h=[rain0rate-act.1:--]&csap=[rain0total-sumday.1:--]
The php has more data, but i known at now.
MeteoBridge to idokep.hu **solved**
SpiderKnight
- Fresh Boarder
Re: MeteoBridge to idokep.hu
I don't have accounts to test with. Would you allow me to test on your Meteobridge?
If so, you can open remote access like expalined below and send link to "info(at)smartbedded.com":
viewtopic.php?f=57&t=9885
SpiderKnight
- Fresh Boarder
I send a mail to you
Kiskrampusz
- Fresh Boarder
HI!
I have a WH4000 weather station and MR3020 modul. I bought the Meteobridge license. I need upload to the Idokep site. Unfortunately, uploading does not work. I set up my user ID and password. I have professional account on pro.idokep.hu.
WU, CWOP and AWEKAS uploads are working.
Please Help Me.
Please Help Me.
Kiskrampusz
- Fresh Boarder
Solved
HTTP Request:
h ttp://pro.idokep.hu/sendws.php?user=*****&pass=*****&tipus=meteobridge&inrh=[thb0hum-act.0:--]&inhom=[thb0temp-act.1:--]&hom=[th0temp-act.1:--]&rh=[th0hum-act.0:--]&szelero=[wind0avgwind-act.1:--]&p=[thb0seapress-act.1:--]&szelirany=[wind0dir-act.0:--]&csap1h=[rain0rate-act.1:--]&csap=[rain0total-sumday.1:--]&szellokes=[wind0wind-max5.1:--]&uv=[uv0index-act:--]
HTTP Request:
Are you sure the idokep option given on Meteobridges "weaterh network" tab does not work?
It did once, I am sure I have tested it.
I just released a new version that also provides indoor temp and hum data. Please give it a test drive. I can't see why the implemented support should not do the job as it mainly does what you specified manually.
Kiskrampusz
- Fresh Boarder
I set up username and password on weather networks tab. Unfortunately the upload does not work without the HTTP request command.
It works perfect with http request.
SW Version: Meteobridge 3.4 (Dec 3 2017, build 11655), FW 1.5
- Névtelen 4.jpg (38.99 KiB) Viewed 4588 times
- Névtelen 3.jpg (47.03 KiB) Viewed 4590 times
I found out that sending was never triggered by Meteobridge. I just fixed that bug and released a new version. Can you please reboot and try again?
I would love to have this issue fixed.
Kiskrampusz
- Fresh Boarder
OK. Thank You! Everything is perfect. Updated every 5 minutes.
- Névtelen 6.jpg (116.14 KiB) Viewed 4581 times
