dashboard rain rate ** solved **
binbags
Post by binbags »
Is it possible to add one more column to the dashboard:unsure: giving actual rain total, rather than just the rain rate per hour.
I am a little confused as to the rain total display. Take yesterday here in the uk, we had by 16:00 15mm of rain but the dashboard and the graph showed 30mm. I know that the 15mm is the more acurate figure, I say this because I have two rain gauges and both of them are telling me that 15mm was the total by 16:00, I presume that both are not wrong, a total of 22m had fallen by 00:00.
Is there something that I have not set up correctly in meteohub, I have looked at the \"weather station\" section in meteohub and used the divide by 2 option, but am still not sure if the reading is correct:unsure:
regards
alan
Re:dashboard rain rate
i think tweaking by the calibration factor is not a solution here. There have been some changes with the rain sensor logging (espacially with more than one rain gauge in operation). May be this is already fixed by that changes.
I suggest that you have an eye on this. If it occurs again with 1.7e or later, we should dig into it.
binbags
Post by binbags »
Hi Boris
Second rain gauge has been removed by about 1 week, although I have kept the receiver running as this appears to be on the same frequency as the wmr928nx rain gauge and gives me daily totals from 9 days back history. The wmr928 rain gauge as you know, only gives 1 day history.:)
alan
