I am still having issues with alarms not triggering when they should.
I have two alarm conditions, each compliments of each other. The raise condition on alarm #1 is identical to the clear condition on alarm #2, and vice versa. Whenever alarm #1 is raised, alarm #2 should be cleared at the same instant and vice versa. This works 99% of the time, but once in a while one of the alarms will be raised and the other is not cleared. This means that the identical condition was matched for one rule and not the other.
I don't know how to debug this issue because there are no logs that I know of. The best we have is the tooltip showing the raise and clear conditions for each alarm, but those only show the last 30 seconds or so.
Alarm Conditions Not Triggering **solved**
Re: Alarm Conditions Not Triggering
Could you please share your alarm definitions with us?
May be your initial idea that the definitions are complementary is wrong.
The raise condition from alarm #1 is pasted to the clear condition of alarm #2 and vice versa. I did discover that the alarm was raised, but for the first time in over 1,000 email messages from meteobridge over the years Google marked it as spam.
