Meteobridge Won't Upload Live Data: Help, Please
swood
Post by swood »
My Meteobridge TL-MR3020 worked perfectly with my Davis Vantage Pro2 via USB (with a USB hub) via my wireless LAN for over a year. However, I recently changed wireless routers and since that time I have been unable to upload live data via Meteobridge. Meteobridge software version is Meteobridge 2.5 (Jul 3 2015, build 6646), FW 1.1. The problem began when I reconnected the MR3020 to my new wireless LAN.
The Vantage Pro2 is on AC power and the batteries are fresh. I have reset the Vp2 and rebooted the MR-3020 many times. Other than replacing my wireless router there have been no hardware changes - same VP2, same MR-3020. Historical data uploads daily without any problem. There is no live data.
Excerpts from my message log:
logger (04.07.2015 11:20:29): gettime request sent.
logger (04.07.2015 11:20:30): Historical data loaded (15 records).
logger (04.07.2015 11:20:30): data logger (version 5.0i, build 6646) started.
logger (04.07.2015 11:20:31): connect station 0 (Vantage via USB serial).
logger (04.07.2015 11:20:31): wakeup sent.
logger (04.07.2015 11:20:31): internal logger activated.
logger (04.07.2015 11:20:31): syncing.
logger (04.07.2015 11:20:41): gettime request sent.
logger (04.07.2015 11:20:51): gettime request sent.
logger (04.07.2015 11:20:51): communication blocked because incompatible Davis data logger or console/envoy on weak batteries.
logger (04.07.2015 11:21:01): gettime request sent.
logger (04.07.2015 11:21:11): disconnect station 0 (Vantage): timeout
logger (04.07.2015 11:21:41): connect station 0 (Vantage via USB serial).
logger (04.07.2015 11:21:41): wakeup sent.
logger (04.07.2015 11:21:41): internal logger activated.
logger (04.07.2015 11:21:41): syncing.
logger (04.07.2015 11:21:51): gettime request sent.
logger (04.07.2015 11:22:01): gettime request sent.
logger (04.07.2015 11:22:01): communication blocked because incompatible Davis data logger or console/envoy on weak batteries.
Screenshots of set up network tab, system tab data and live tab:
Any help would be appreciated! Thanks!
Re: Meteobridge Won't Upload Live Data: Help, Please
Looks like the data logger port of your Vantage console has locked up.
Please make the VP2 console powerless (put batteries out, remove power supply,
remove data logger). Then insert data logger and power-up console again.
