Strange Problem
ajlacy
Strange Problem
Post by ajlacy »
I have
TP-LINK TL-MR3020 (plus USB hub)
Meteobridge 2.6 (Oct 5 2015, build 7126), FW 1.4
Yesterday at about 1:30 AM EDT it quit uploading to Weather Underground, The Weather Network page still shows checks by Station ID and Password. I get emails from Weather Underground saying the PWS is down. Live data shows "Weather Underground: No weather network traffic" But if I click "Save" on the Weather Network pages, the clicks stay and I get an email from Weather Underground saying the PWS is up. But no weather shows on the the Weather Underground page http://www.wunderground.com/personal-we ... =KGATOCCO3 and later I get another email saying it is down. I have it send me an email every midnight with some stats and that works, it also FTPs data to my personal website and that works
I thought it might be the Meteobridge so I had it back up a version and
Meteobridge 2.5 (Jul 31 2015, build 6790), FW 1.4
Loaded but same results.
Note my live data screen doesn't look like http://meteobridge.com/wiki/index.php/Live_Data
I am attaching a copy of what it looks like.
Live Data page
Live Data page
Re: Strange Problem
As you can see in the empty live data section there is no data coming in from the weather station.
Therefore, the weather networks are not fed anymore.
Please have a look at the messages section on "system" tab to find out why.
ajlacy
Re: Strange Problem
Post by ajlacy »
It repeats as shown
logger (15.10.2015 14:48:39): Historical data loaded (19 records).
logger (15.10.2015 14:48:39): data logger (version 5.0j, build 7126) started.
logger (15.10.2015 14:48:39): connect station 0 (WH-1080/3080 via USB HID).
logger (15.10.2015 14:59:09): child process received timeout signal (14).
logger (15.10.2015 14:59:10): disconnect station 0 (WH-1080/3080): exit
logger (15.10.2015 14:59:10): data logger stopped.
logger (15.10.2015 14:59:10): Historical data loaded (19 records).
logger (15.10.2015 14:59:10): data logger (version 5.0j, build 7126) started.
logger (15.10.2015 14:59:10): connect station 0 (WH-1080/3080 via USB HID).
logger (15.10.2015 15:09:40): child process received timeout signal (14).
logger (15.10.2015 15:09:41): disconnect station 0 (WH-1080/3080): exit
logger (15.10.2015 15:09:41): data logger stopped.
logger (15.10.2015 15:09:41): Historical data loaded (19 records).
logger (15.10.2015 15:09:41): data logger (version 5.0j, build 7126) started.
logger (15.10.2015 15:09:41): connect station 0 (WH-1080/3080 via USB HID).
logger (15.10.2015 15:20:11): child process received timeout signal (14).
logger (15.10.2015 15:20:11): disconnect station 0 (WH-1080/3080): exit
logger (15.10.2015 15:20:12): data logger stopped.
logger (15.10.2015 15:20:12): Historical data loaded (19 records).
logger (15.10.2015 15:20:12): data logger (version 5.0j, build 7126) started.
logger (15.10.2015 15:20:12): connect station 0 (WH-1080/3080 via USB HID).
logger (15.10.2015 15:30:42): child process received timeout signal (14).
logger (15.10.2015 15:30:42): disconnect station 0 (WH-1080/3080): exit
logger (15.10.2015 15:30:43): data logger stopped.
logger (15.10.2015 15:30:43): Historical data loaded (19 records).
logger (15.10.2015 15:30:43): data logger (version 5.0j, build 7126) started.
logger (15.10.2015 15:30:43): connect station 0 (WH-1080/3080 via USB HID).
ajlacy
Re: Strange Problem
Post by ajlacy »
Before posting the problem, I had tried rebooting Meteobridge, when that didn't work, I powered it down then up which also didn't work.
But with you saying the message was due to "no data coming in from the weather station" I powered down meteobridge then reset the weather unit, once the unit was displaying information, I powered up meteobridge and that has fixed it for now.
Re: Strange Problem
USB port of your weather station has hung up. Please disconnect
weather station from USB, power supply and take out batteries.
Wait a minute then connect and power up again.
ajlacy
Re: Strange Problem
Post by ajlacy »
I forgot to mention that I after powering down meteobridge, I did disconnect the USB cable but instead of powering down the Ambient Weather unit, I reset it. In the past it had problem where it always showed the outside temp as 140° and power down then up didn't fix that problem. Ambient Weather told me to reset it by holding the up arrow until all the LCD segments lit and then turn it loose. So this is what I did this time after disconnecting the USB cable. As I said that worked.
Thanks for the quick response, which gave me the idea to try the reset.
Colinw
Re: Strange Problem
Post by Colinw »
Hi there
I have the same problem. My Ws1093 was working via a usb hub to meteobridge reciving live data and sending it on to wunderground. Around the 5th Oct the upload to wunderground stopped and I have not been able to get it going since
The live data page on meteobridge is not showing sensor data and no data uploads. I have tried rebooting, restarting the weather station, new usb hub and multiple setting changes, all to no effect. The weather station works with cumulas software via the same usb cable (when unplugged from meteobridge) so it appears to be something that has changed on the meteobridge.
Has something changed on the latest software version that can cause this?
Any help would be appreciated
Cheers
Re: Strange Problem
When the problem persists, please give me remote access as described here:
viewtopic.php?f=57&t=9885
