Sunset/Sunrise variables not working yet **solved*
cbhiii
Post by cbhiii »
I like the new variables that you added. However, I noticed that some of them aren't working right yet.
On Saturday May 24 today the sunrise was 06:10 and sunset will be at 21:09 as reported by WU and my Vantage Pro.
Below I've highlighted the entries that are in error with the data above.
actual_sunrise_standard_utc 10:06 (3 min off should be 6:10)
actual_sunrise_standard_local 06: -54
actual_sunset_standard_utc 25:04 (5 min off should be 01:09)
actual_sunset_standard_local 21:-56
Re:Sunset/Sunrise variables not working yet
Negative or too big numbers that result from conversion from UTC to local time will be covered by the next update.
WebDog
Post by WebDog »
najbo
Re:Sunset/Sunrise variables not working yet (2.3e)
Post by najbo »
I patched from 2.3c to d and then to e version. But still not possible to show sunset / sunrise variable.
It shows [actual_sunrise_civiltwilight_local] instead of value.
Here's the link : http://www.jan-boesch.net/index.php?meteo
Any idea ?
Thank you !
Jan
Unconnected
Post by Unconnected »
najbo wrote:It shows [actual_sunrise_civiltwilight_local] instead of value.
your coordinates aren't in the configfile yet, as shown by these variables on the bottom of your site:
[actual_station_latitude_decimal]
[actual_station_longitude_decimal]
you have to press 'save' on the corresponding settings-page in meteohub to activate these variables.
najbo
{solved} Sunset/Sunrise variables not working yet
Post by najbo »
It worked ! thank you very much. I had to change one of the values first.
cbhiii
Re:{solved} Sunset/Sunrise variables not working yet
Post by cbhiii »
Your website looks nice!
