Read-only file system / no connectivity on IConnect
MrReview
Post by MrReview »
Hi all,
a few days ago my Meteohub / iConnect stopped working. I can access the device through its regular IP with my browser, but it will prompt me a "system read only" message whenever I try to make changes. The Meteohub does not, however, appear in the network and I cannot access it through the Explorer.
The flash drive works nicely in Ubuntu and I can read / write from and to it. There is plenty of space left on the partitions. Still Meteohub comes up with "cannot write file, system read-only" message in any kind of menu that I try to work on.
Another strange thing: the iConnect ALWAYS blinks 192.168.2.123 after reboot, even if I limit the IP range to 192.168.1.xxx.
The system log reads:
2016-02-08T15:43:09.918340+01:00 localhost rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c3 as the first rsyslogd option.
2016-02-08T15:43:09.918368+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2016-02-08T15:43:09.918383+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2016-02-08T15:43:09.918400+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
/home/meteohub/wear.sh: line 37: /home/meteohub/wear: Read-only file system
mv: cannot move `/home/meteohub/wmr928fulleval.conf' to `/home/meteohub/wmr928fulleval.do.conf': Read-only file system
/home/meteohub/wmr928fulleval: line 8: /home/meteohub/wmr928fulleval.stage: Read-only file system
/home/meteohub/wmr928fulleval: line 10: /home/meteohub/wmr928fulleval.stage: Read-only file system
/home/meteohub/wmr928fulleval: line 12: /home/meteohub/wmr928fulleval.stage: Read-only file system
/home/meteohub/wmr928fulleval: line 14: /home/meteohub/wmr928fulleval.stage: Read-only file system
/home/meteohub/wmr928fulleval: line 16: /home/meteohub/wmr928fulleval.stage: Read-only file system
/home/meteohub/wmr928fulleval: line 18: /home/meteohub/wmr928fulleval.stage: Read-only file system
/home/meteohub/wmr928fulleval: line 20: /home/meteohub/wmr928fulleval.stage: Read-only file system
/home/meteohub/wmr928fulleval: line 22: /home/meteohub/wmr928fulleval.stage: Read-only file system
/home/meteohub/wmr928fulleval: line 24: /home/meteohub/wmr928fulleval.stage: Read-only file system
/home/meteohub/histeval3: line 13: /home/meteohub/histeval3.running: Read-only file system
This is from the dmesg log:
USB:
Bus 001 Device 004: ID 0403:8e79 Future Technology Devices International, Ltd
Bus 001 Device 003: ID 8564:1000
Bus 001 Device 002: ID 058f:6254 Alcor Micro Corp. USB Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
PCI:
00:00.0 0580: 11ab:6281 (rev 02)
00:01.0 0280: 1814:3090
Partitions:
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda1 851256 572780 235236 71% /
tmpfs 127312 4 127308 1% /lib/init/rw
udev 10240 728 9512 8% /dev
tmpfs 127312 0 127312 0% /dev/shm
/dev/sda3 6749928 1374960 5032084 22% /data
tmpfs 8192 0 8192 0% /var/lock
tmpfs 32768 1636 31132 5% /var/run
tmpfs 32768 24 32744 1% /var/log
I can't make any sense of this. Anyone here with an idea?
Cheers
Chris
Re: Read-only file system / no connectivity on IConnect
USB stick failed.
