Problems with pass-through to cumulus MX
jmelan
Post by jmelan »
Hi, thanks for the great program!
I am using meteobridge versions 2.6-2.8 on a tp link 3040 with the davis usb logger and recommended belkin usb hub. I am uploading to WU directly from meteobridge and then using passthrough to cumulus mx installed on ubuntu.
with 2.6, I get a reported connection made, but an inconsistent connection to cumulus mx with dropouts occurring that cause cumulus to stop recording data until restarted
- initial attempt fails to transmit data often but eventually after multiple attempts it will start to work for a few weeks then suddenly stop
strangely, with 2.7 and 2.8, all attempts to connect to cumulus mx fail, and in addition, after the attempted connection from cumulus mx, meteobridge stops uploading to WU as well
hard to figure out what side the issue is coming from (cumulus mx vs meteobridge)
please let me know if I should provide any other information!
thanks
jmelan
Re: Problems with pass-through to cumulus MX
Post by jmelan »
well since it has been a couple of weeks, thought I would ask again :)
is there an issue with passthrough in general with 2.7 and 2.8?
with 2.7 and 2.8, all attempts to connect with cumulus mx fail, and in addition, after the attempted connection from cumulus mx, meteobridge stops uploading to WU as well
