Database is gone... ***solved***
DAP
Post by DAP »
I noticed that at 5:40 AM today my metobridge pro had stopped reporting rain rate to weather underground. When I got home from work, the rain rate on the display was "--".
When I looked at the log file, the log had overflowed with errors about the database being read-only.
I clicked on the "check and repair database on the next boot", and restarted the meteobridge pro.
This is the boot log;
oled (09.04.2016 00:54:58): process started.
dbrepair (08.04.2016 17:56:35): database size is
dbrepair (08.04.2016 17:56:35): test integrity of database
dbrepair (08.04.2016 17:56:35): database integrity is fine, nothing to do
database (08.04.2016 17:56:37): process started.
wnetd (08.04.2016 17:56:37): process started.
logger (08.04.2016 17:56:38): database connected.
logger (08.04.2016 17:56:38): Historical data loaded (0 records).
logger (08.04.2016 17:56:38): data logger (version 5.0p, build 9757) started.
logger (08.04.2016 17:56:40): connect station 0 (Meteostick Vantage via USB serial).
logger (08.04.2016 17:56:40): connect station 9 (System Data via Plug-in).
logger (08.04.2016 17:56:41): transmitter 1 registered as ISS
logger (08.04.2016 17:56:41): Meteostick Version 2.4
logger (08.04.2016 17:56:41): debug off
logger (08.04.2016 17:56:41): verbose off
logger (08.04.2016 17:56:41): output raw (8 bytes)
logger (08.04.2016 17:56:41): output raw (10 bytes)
logger (08.04.2016 17:56:41): filter on
logger (08.04.2016 17:56:42): rx threshold set to -70db
logger (08.04.2016 17:56:42): listening to transmitter 1
logger (08.04.2016 17:56:42): bandwidth narrow
logger (08.04.2016 17:56:42): chip authentication ok: 14
logger (08.04.2016 17:56:42): frequency band 915MHz (US)
logger (08.04.2016 17:56:46): parent process received termination signal (15).
logger (08.04.2016 17:56:46): child process received termination signal (15).
logger (08.04.2016 17:56:46): disconnect station 0 (Meteostick Vantage): exit
logger (08.04.2016 17:56:46): disconnect station 9 (System Data): exit
database (08.04.2016 17:56:47): process terminated normally.
test5m (08.04.2016 17:56:48): USB storage remounted: /dev/sda
database (08.04.2016 17:56:48): process started.
logger (08.04.2016 17:56:48): database connected.
logger (08.04.2016 17:56:48): Historical data loaded (0 records).
logger (08.04.2016 17:56:48): data logger (version 5.0p, build 9757) started.
logger (08.04.2016 17:56:49): connect station 0 (Meteostick Vantage via USB serial).
logger (08.04.2016 17:56:49): connect station 9 (System Data via Plug-in).
logger (08.04.2016 17:56:51): transmitter 1 registered as ISS
logger (08.04.2016 17:56:51): Meteostick Version 2.4
logger (08.04.2016 17:56:51): debug off
logger (08.04.2016 17:56:51): verbose off
logger (08.04.2016 17:56:51): output raw (8 bytes)
logger (08.04.2016 17:56:51): output raw (10 bytes)
logger (08.04.2016 17:56:51): filter on
logger (08.04.2016 17:56:51): rx threshold set to -70db
logger (08.04.2016 17:56:51): listening to transmitter 1
logger (08.04.2016 17:56:51): bandwidth narrow
logger (08.04.2016 17:56:51): chip authentication ok: 14
logger (08.04.2016 17:56:51): frequency band 915MHz (US)
My database is completely gone. The meteobridge is working again, but its entire history is lost.
This is not terrible for me since the reported rain was not being recorded correctly, so I had not started using the meteobridge pro as my primary data source, but it bothers me that it is so fragile, and prone to spontaneous corruption.
Edit:
This just happened:
logger (08.04.2016 18:08:22): wind0 data incomplete (missing outdoor temp for windchill)
logger (08.04.2016 18:08:24): wind0 data incomplete (missing outdoor temp for windchill)
logger (08.04.2016 18:08:27): wind0 data incomplete (missing outdoor temp for windchill)
logger (08.04.2016 18:08:29): wind0 data incomplete (missing outdoor temp for windchill)
logger (08.04.2016 18:08:32): wind0 data incomplete (missing outdoor temp for windchill)
logger (08.04.2016 18:08:35): wind0 data incomplete (missing outdoor temp for windchill)
logger (08.04.2016 18:08:37): wind0 data incomplete (missing outdoor temp for windchill)
logger (08.04.2016 18:08:42): wind0 data incomplete (missing outdoor temp for windchill)
logger (08.04.2016 18:08:45): wind0 data incomplete (missing outdoor temp for windchill)
logger (08.04.2016 18:08:47): wind0 data incomplete (missing outdoor temp for windchill)
logger (08.04.2016 18:08:50): wind0 data incomplete (missing outdoor temp for windchill)
logger (08.04.2016 18:11:40): parent process received termination signal (15).
logger (08.04.2016 18:11:40): child process received termination signal (15).
logger (08.04.2016 18:11:40): disconnect station 0 (Meteostick Vantage): exit
logger (08.04.2016 18:11:40): disconnect station 9 (System Data): exit
database (08.04.2016 18:11:40): process terminated normally.
test5m (08.04.2016 18:11:41): USB storage remounted: /dev/sda
database (08.04.2016 18:11:41): process started.
logger (08.04.2016 18:11:42): database connected.
logger (08.04.2016 18:11:42): Historical data loaded (45 records).
logger (08.04.2016 18:11:42): data logger (version 5.0p, build 9757) started.
logger (08.04.2016 18:11:43): connect station 0 (Meteostick Vantage via USB serial).
logger (08.04.2016 18:11:43): connect station 9 (System Data via Plug-in).
logger (08.04.2016 18:11:44): transmitter 1 registered as ISS
logger (08.04.2016 18:11:44): Meteostick Version 2.4
logger (08.04.2016 18:11:44): debug off
logger (08.04.2016 18:11:44): verbose off
logger (08.04.2016 18:11:44): output raw (8 bytes)
logger (08.04.2016 18:11:44): output raw (10 bytes)
logger (08.04.2016 18:11:44): filter on
logger (08.04.2016 18:11:44): rx threshold set to -70db
logger (08.04.2016 18:11:45): listening to transmitter 1
logger (08.04.2016 18:11:45): bandwidth narrow
logger (08.04.2016 18:11:45): chip authentication ok: 14
logger (08.04.2016 18:11:45): frequency band 915MHz (US)
Also the programmed display is not happening. It has been displaying the smartbedded/license/IP page since it booted.
DAP
Re: Database is gone...
Post by DAP »
The process restart is now happening every 5 minutes and filling the log.
This is the reason that the display did not start. When I set the repeat rate to 2 minutes, the display started, previously it was at 10 minutes, and it did not start.
Would you allow me to remotely login as explained here:
viewtopic.php?f=57&t=9885
Please send URL and password to "info(at)meteobrideg.com".
DAP
Post by DAP »
admin wrote:Would you allow me to remotely login as explained here:
This info was sent previously for the thread titled: "Need clerification on how rain is measured..."
I'll send it again anyway...
DAP
Re: Database is gone... ***solved***
Post by DAP »
It was determined that the unit I had, had bad memory. I returned it an now have a new unit that is working.
