Meteobridge image disturbance **solved**
MeteoOudkarspel
- Senior Boarder
I'm behind last night (before there was nothing to advance) that the images in the MeteoBridge webintervice are no longer visible where under the ticks and crosses on the tab Live Data and Weather Station is not the text no show there is now
The image of the MeteoBridge itself used is no longer visible on the System tab.
Featherweight he just works and submit all data again.
Forgot to mention when I have a MeteoBridge TP-LINK TL-MR3020 (plus USB hub)
SW Version: Weather Bridge 2.8 (18 Apr 2016, build 9778), FW 1.4
Did you do this?
Did you do this?
Sincerely,
Re: Meteobridge image disturbance
I can confirm that images are missing from the web interface on Meteobridge Pro as well. Brand new system started today running software v2.8, firmware v1.4.
No such issues here with MB or MB Pro for FW versions 2.5 and the latest 2.8
No problems in 2.7 on a TP link running FW 1.2 or 1.4
Is the problem still there with the latest build from April 23?
- wsnoordbergum
I'm having the same issue with missing images the crosses and checks are missing but not all of them.
Also with the release of 23 April a big difference on raintotal/day with console and the amount gathered by meteobridge.
Now 4.8 mm on console and meteobridge is showing just 1 mm.
Rain rate is ok.
I'm using meteostick version 2.5 with Davis vantage pro2.
All the other data is ok.
Seems like the latest version does not fix this problem.
At first everything was working fine since a test of mine it is gone bad.
Also when booting I get a message no such file or directory for a few times before it is able to recognize the meteostick.
Gr. Tjeerd
Rain rate is ok.
Gr. Tjeerd
MeteoOudkarspel
- Senior Boarder
Unfortunately, updated April 23, 2015 the same problemadmin wrote:Is the problem still there with the latest build from April 23?
Sincerely,
Strange one? With April 23 release I can't fault the rain totals, so far all spot on, yes rain rate has always been spot on. This is a MB Pro (red) via RF from a Vue which was a problem prior to April 23. The MB rain total via Envoy/IP from the same station was always ok.wsnoordbergum wrote: .... Also with the release of 23 April a big difference on raintotal/day with console and the amount gathered by meteobridge.
Rain rate is ok.
- wsnoordbergum
I am now using version 2.6 and yesterday the rain total was 0.2 mm less on my meteobridge.
Today it's spot on both the console and meteobridge read 3 mm of rain.
Hope it stays spot on.
When booting the latest version 2.7 I get the following message:
Can't open device, no such file or directory etc.
It does so for a period of time before it is able to complete the boot process.
With version 2.6 everything is going smooth.
So for now I'll stick with 2.6
Still missing the cross images on the weatherstation tab, strange as they are not all missing
See attached file.
Gr. Tjeerd.
See attached file.
Gr. Tjeerd.
- Naamloos.png (61.41 KiB) Viewed 7170 times
This looks fine to me. Only the ones that are not connected for sure are marked red X. The ones connected for sure are marked green V. The ones Meteobridge does not know by looking at the interfaces are left blank.
MeteoOudkarspel
- Senior Boarder
Re: Meteobridge image disturbance **solved**
I can tell you that the pictures do it again in the meteobridge.
Sincerely,
