MB PRO: [rain0total-daysum] summing
tofe
Post by tofe »
Hello
Version 3.0, released July 31, 2016
I miss the logfile the possibility that rainfall output summed.
I would be grateful if this could be supported in logfils.
Example (works):
[YYYY]-[MM]-[DD] [hh]:[mm], [rain0total-sum.1:x]
2016-07-30 00:00, 0.0
2016-07-30 00:01, 0.2
2016-07-30 00:02, 0.2
2016-07-30 00:03, 0.0
2016-07-30 00:04, 0.0
2016-07-30 00:05, 0.2
2016-07-30 00:06, 0.0
2016-07-30 00:07, 0.0
2016-07-30 00:08, 0.2
2016-07-30 00:09, 0.0
2016-07-30 00:10, 0.0
2016-07-30 23:55, 0.4
2016-07-30 23:56, 0.2
2016-07-30 23:57, 0.2
2016-07-30 23:58, 0.4
2016-07-30 23:59, 0.2
Request with daysum (x are from):
[YYYY]-[MM]-[DD] [hh]:[mm], [rain0total-daysum.1:x]
2016-07-30 00:02, 0.4
2016-07-30 00:03, 0.4
2016-07-30 00:04, 0.4
2016-07-30 00:05, 0.6
2016-07-30 00:06, 0.6
2016-07-30 00:07, 0.6
2016-07-30 00:08, 0.8
2016-07-30 00:09, 0.8
2016-07-30 00:10, 0.8
2016-07-30 23:55, 8.6
2016-07-30 23:56, 8.8
2016-07-30 23:57, 9.0
2016-07-30 23:58, 9.4
2016-07-30 23:59, 9.6
Desired function in logfile:
[rain0total-sum.1:x] = sum in a minute (at every minute resolution)
[rain0total-daysum.1:x] = Added up from the current day
[rain0total-monthsum.1:x] = Added up from the current month
[rain0total-yearsum.1:x] = Added up from the current year
[rain0total-allsum.1:x] = Added up since the start of measurement
Thank you very much. :)
Re: MB PRO: [rain0total-daysum] summing
It is not supported yet. Export function more or less dumps out data from the database and does not do
math on the results. One could image "min", "max", "sum", "avg" as modifiers that do math on the so far
delivered values.
Will further explore and may put it onto todo list.
