can't open device /dev/ttyMH
gand
Post by gand »
Hi
I need to boot the Meteobridge once a day. Normally it will run for month, I get this error:
logger (25.08.2016 15:43:20): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
The system will not upload HTTP and FTP.
Any clues what might be wrong?
I'm running Meteobridge 3.1 (Aug 17 2016, build 10256), FW 1.4
Rgds
Gert
droiddk
Re: can't open device /dev/ttyMH
Post by droiddk »
Hi
Reboot Vantage (Pro2?) - Take out batteries and pull out power-jack.
gand
Post by gand »
Hi
Thanks, i'll try that.
Rgds
Gert
Are you using the mandatory USB hub?
gand
Post by gand »
Hi
Yes, i'm using the USB Hub and normally the system will run for months.
Rgds
Gert
Can you please post outcome of
http://ip-of-your-meteobridge/cgi-bin/system.cgi?dmesg
http://ip-of-your-meteobridge/cgi-bin/system.cgi?lsusb
http://ip-of-your-meteobridge/cgi-bin/system.cgi?ls -la /dev
This might help to understand why the USB serial device is not set up.
gand
Post by gand »
Hi
Currently I'm not at the local network and I can't access the Meteobridge with the WAN Ip.
As soon as I'm connected to the local network, I'll get the information.
Thanks for your help.
Rgds
Gert
